Implicit_manifold_intersection_oracle.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Siargey Kachanovich
4  *
5  * Copyright (C) 2019 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef IMPLICIT_MANIFOLD_INTERSECTION_ORACLE_H_
12 #define IMPLICIT_MANIFOLD_INTERSECTION_ORACLE_H_
13
14 #include <Eigen/Dense>
15
16 #include <gudhi/Permutahedral_representation/face_from_indices.h>
17 #include <gudhi/Functions/Constant_function.h>
18 #include <gudhi/Functions/PL_approximation.h>
19 #include <gudhi/Coxeter_triangulation/Query_result.h>
20 #include <gudhi/Debug_utils.h> // for GUDHI_CHECK
21
22 #include <vector>
23 #include <limits> // for std::numeric_limits<>
24 #include <cmath> // for std::fabs
25
26 namespace Gudhi {
27
28 namespace coxeter_triangulation {
29
40 template <class Function_, class Domain_function_ = Constant_function>
42  /* Computes the affine coordinates of the intersection point of the implicit manifold
43  * and the affine hull of the simplex. */
44  template <class Simplex_handle, class Triangulation>
45  Eigen::VectorXd compute_lambda(const Simplex_handle& simplex, const Triangulation& triangulation) const {
46  std::size_t cod_d = this->cod_d();
47  Eigen::MatrixXd matrix(cod_d + 1, cod_d + 1);
48  for (std::size_t i = 0; i < cod_d + 1; ++i) matrix(0, i) = 1;
49  std::size_t j = 0;
50  for (auto v : simplex.vertex_range()) {
51  Eigen::VectorXd v_coords = fun_(triangulation.cartesian_coordinates(v));
52  for (std::size_t i = 1; i < cod_d + 1; ++i) matrix(i, j) = v_coords(i - 1);
53  j++;
54  }
55  Eigen::VectorXd z(cod_d + 1);
56  z(0) = 1;
57  for (std::size_t i = 1; i < cod_d + 1; ++i) z(i) = 0;
58  Eigen::VectorXd lambda = matrix.colPivHouseholderQr().solve(z);
59  if (!z.isApprox(matrix*lambda)) {
60  // NaN non valid results
61  for (std::size_t i = 0; i < (std::size_t)lambda.size(); ++i) lambda(i) =
62  std::numeric_limits<double>::quiet_NaN();
63  }
64  return lambda;
65  }
66
67  /* Computes the affine coordinates of the intersection point of the boundary
68  * of the implicit manifold and the affine hull of the simplex. */
69  template <class Simplex_handle, class Triangulation>
70  Eigen::VectorXd compute_boundary_lambda(const Simplex_handle& simplex, const Triangulation& triangulation) const {
71  std::size_t cod_d = this->cod_d();
72  Eigen::MatrixXd matrix(cod_d + 2, cod_d + 2);
73  for (std::size_t i = 0; i < cod_d + 2; ++i) matrix(0, i) = 1;
74  std::size_t j = 0;
75  for (auto v : simplex.vertex_range()) {
76  Eigen::VectorXd v_coords = fun_(triangulation.cartesian_coordinates(v));
77  for (std::size_t i = 1; i < cod_d + 1; ++i) matrix(i, j) = v_coords(i - 1);
78  Eigen::VectorXd bv_coords = domain_fun_(triangulation.cartesian_coordinates(v));
79  matrix(cod_d + 1, j) = bv_coords(0);
80  j++;
81  }
82  Eigen::VectorXd z(cod_d + 2);
83  z(0) = 1;
84  for (std::size_t i = 1; i < cod_d + 2; ++i) z(i) = 0;
85  Eigen::VectorXd lambda = matrix.colPivHouseholderQr().solve(z);
86  if (!z.isApprox(matrix*lambda)) {
87  // NaN non valid results
88  for (std::size_t i = 0; i < (std::size_t)lambda.size(); ++i) lambda(i) =
89  std::numeric_limits<double>::quiet_NaN();
90  }
91  return lambda;
92  }
93
94  /* Computes the intersection result for a given simplex in a triangulation. */
95  template <class Simplex_handle, class Triangulation>
96  Query_result<Simplex_handle> intersection_result(const Eigen::VectorXd& lambda, const Simplex_handle& simplex,
97  const Triangulation& triangulation) const {
99  std::size_t amb_d = triangulation.dimension();
100  std::size_t cod_d = simplex.dimension();
101  for (std::size_t i = 0; i < (std::size_t)lambda.size(); ++i) {
102  if (std::isnan(lambda(i))) return QR({Eigen::VectorXd(), false});
103  GUDHI_CHECK((std::fabs(lambda(i) - 1.) > std::numeric_limits<double>::epsilon() &&
104  std::fabs(lambda(i) - 0.) > std::numeric_limits<double>::epsilon()),
105  std::invalid_argument("A vertex of the triangulation lies exactly on the manifold"));
106  if (lambda(i) < 0. || lambda(i) > 1.) return QR({Eigen::VectorXd(), false});
107  }
108  Eigen::MatrixXd vertex_matrix(cod_d + 1, amb_d);
109  auto v_range = simplex.vertex_range();
110  auto v_it = v_range.begin();
111  for (std::size_t i = 0; i < cod_d + 1 && v_it != v_range.end(); ++v_it, ++i) {
112  Eigen::VectorXd v_coords = triangulation.cartesian_coordinates(*v_it);
113  for (std::size_t j = 0; j < amb_d; ++j) vertex_matrix(i, j) = v_coords(j);
114  }
115  Eigen::VectorXd intersection = lambda.transpose() * vertex_matrix;
116  return QR({intersection, true});
117  }
118
119  public:
121  std::size_t amb_d() const { return fun_.amb_d(); }
122
124  std::size_t cod_d() const { return fun_.cod_d(); }
125
127  Eigen::VectorXd seed() const { return fun_.seed(); }
128
149  template <class Simplex_handle, class Triangulation>
150  Query_result<Simplex_handle> intersects(const Simplex_handle& simplex, const Triangulation& triangulation) const {
151  Eigen::VectorXd lambda = compute_lambda(simplex, triangulation);
152  return intersection_result(lambda, simplex, triangulation);
153  }
154
175  template <class Simplex_handle, class Triangulation>
176  Query_result<Simplex_handle> intersects_boundary(const Simplex_handle& simplex,
177  const Triangulation& triangulation) const {
178  //std::cout << "intersects_boundary" << std::endl;
179  Eigen::VectorXd lambda = compute_boundary_lambda(simplex, triangulation);
180  return intersection_result(lambda, simplex, triangulation);
181  }
182
193  template <class Triangulation>
194  bool lies_in_domain(const Eigen::VectorXd& p, const Triangulation& triangulation) const {
195  Eigen::VectorXd pl_p = make_pl_approximation(domain_fun_, triangulation)(p);
196  return pl_p(0) < 0;
197  }
198
200  const Function_& function() const { return fun_; }
201
210  Implicit_manifold_intersection_oracle(const Function_& function, const Domain_function_& domain_function)
211  : fun_(function), domain_fun_(domain_function) {}
212
222  Implicit_manifold_intersection_oracle(const Function_& function)
223  : fun_(function), domain_fun_(function.amb_d(), 1, Eigen::VectorXd::Constant(1, -1)) {}
224
225  private:
226  Function_ fun_;
227  Domain_function_ domain_fun_;
228 };
229
239 template <class Function_, class Domain_function_>
241  const Function_& function, const Domain_function_& domain_function) {
243 }
244
252 template <class Function_>
255 }
256
257 } // namespace coxeter_triangulation
258
259 } // namespace Gudhi
260
261 #endif
An oracle that supports the intersection query on an implicit manifold.
Definition: Implicit_manifold_intersection_oracle.h:41
The seed point of the implicit manifold.
Definition: Implicit_manifold_intersection_oracle.h:127
Implicit_manifold_intersection_oracle(const Function_ &function, const Domain_function_ &domain_function)
Constructs an intersection oracle for an implicit manifold potentially with boundary from given funct...
Definition: Implicit_manifold_intersection_oracle.h:210
Query_result< Simplex_handle > intersects(const Simplex_handle &simplex, const Triangulation &triangulation) const
Intersection query with the relative interior of the manifold.
Definition: Implicit_manifold_intersection_oracle.h:150
Implicit_manifold_intersection_oracle(const Function_ &function)
Constructs an intersection oracle for an implicit manifold without boundary from a given function.
Definition: Implicit_manifold_intersection_oracle.h:222
Ambient dimension of the implicit manifold.
Definition: Implicit_manifold_intersection_oracle.h:121
const Function_ & function() const
Returns the function that defines the interior of the manifold.
Definition: Implicit_manifold_intersection_oracle.h:200
bool lies_in_domain(const Eigen::VectorXd &p, const Triangulation &triangulation) const
Returns true if the input point lies inside the piecewise-linear domain induced by the given ambient ...
Definition: Implicit_manifold_intersection_oracle.h:194
Codimension of the implicit manifold.
Definition: Implicit_manifold_intersection_oracle.h:124
Query_result< Simplex_handle > intersects_boundary(const Simplex_handle &simplex, const Triangulation &triangulation) const
Intersection query with the boundary of the manifold.
Definition: Implicit_manifold_intersection_oracle.h:176
Implicit_manifold_intersection_oracle< Function_ > make_oracle(const Function_ &function)
Static constructor of an intersection oracle from a function without a domain.
Definition: Implicit_manifold_intersection_oracle.h:253
PL_approximation< Function_, Triangulation_ > make_pl_approximation(const Function_ &function, const Triangulation_ &triangulation)
Static constructor of the piecewise-linear approximation of a function induced by an ambient triangul...
Definition: PL_approximation.h:102
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
The result of a query by an oracle such as Implicit_manifold_intersection_oracle.
Definition: Query_result.h:26
