11 #ifndef READER_UTILS_H_ 12 #define READER_UTILS_H_ 14 #include <gudhi/graph_simplicial_complex.h> 15 #include <gudhi/Debug_utils.h> 17 #include <boost/function_output_iterator.hpp> 18 #include <boost/graph/adjacency_list.hpp> 46 inline void read_points(std::string file_name, std::vector<std::vector<double>>& points) {
47 std::ifstream in_file(file_name.c_str(), std::ios::in);
48 if (!in_file.is_open()) {
49 std::cerr <<
"Unable to open file " << file_name << std::endl;
55 while (getline(in_file, line)) {
56 std::vector<double> point;
57 std::istringstream iss(line);
62 if (!point.empty()) points.push_back(point);
83 template <
typename Graph_t,
typename Filtration_value,
typename Vertex_handle>
85 std::ifstream in_(file_name.c_str(), std::ios::in);
87 std::string error_str(
"read_graph - Unable to open file ");
88 error_str.append(file_name);
89 std::cerr << error_str << std::endl;
90 throw std::invalid_argument(error_str);
93 typedef std::pair<Vertex_handle, Vertex_handle> Edge_t;
94 std::vector<Edge_t> edges;
95 std::vector<Filtration_value> edges_fil;
96 std::map<Vertex_handle, Filtration_value> vertices;
100 Vertex_handle u, v, max_h = -1;
102 while (getline(in_, line)) {
103 std::istringstream iss(line);
119 edges.push_back(Edge_t(u, v));
120 edges_fil.push_back(fil);
129 if ((
size_t)(max_h + 1) != vertices.size()) {
130 std::cerr <<
"Error: vertices must be labeled from 0 to n-1 \n";
133 Graph_t skel_graph(edges.begin(), edges.end(), edges_fil.begin(), vertices.size());
134 auto vertex_prop = boost::get(vertex_filtration_t(), skel_graph);
136 typename boost::graph_traits<Graph_t>::vertex_iterator vi, vi_end;
137 auto v_it = vertices.begin();
138 for (std::tie(vi, vi_end) = boost::vertices(skel_graph); vi != vi_end; ++vi, ++v_it) {
139 boost::put(vertex_prop, *vi, v_it->second);
157 template <
typename Vertex_handle,
typename Filtration_value>
160 if (!(in_ >> dim))
return false;
162 for (
int i = 0; i < dim + 1; ++i) {
163 if (!(in_ >> v))
return false;
164 simplex.push_back(v);
166 if (!(in_ >> fil))
return false;
167 in_.ignore((std::numeric_limits<std::streamsize>::max)(),
'\n');
182 template <
typename Simplex_key,
185 if (!(in_ >> dim))
return false;
191 for (
193 boundary.push_back(key);
219 template <
221 const char separator =
223 std::cout <<
"Using procedure read_lower_triangular_matrix_from_csv_file \n";
224 #endif // DEBUG_TRACES 225 std::vector<std::vector<Filtration_value>> result;
227 in.open(filename.c_str());
235 std::getline(in, line);
236 std::vector<Filtration_value> values_in_this_line;
237 result.push_back(values_in_this_line);
239 int number_of_line = 0;
242 while (std::getline(in, line)) {
244 if (line.size() == 0)
break;
247 if (line[line.size() - 1] == separator) {
253 std::replace(line.begin(), line.end(), separator,
256 std::istringstream iss(line);
259 int number_of_entry = 0;
260 std::vector<Filtration_value> values_in_this_line;
264 if (number_of_entry <= number_of_line) {
265 values_in_this_line.push_back(entry);
269 if (!values_in_this_line.empty()) result.push_back(values_in_this_line);
275 std::cerr <<
"Here is the matrix we read : \n";
276 for (
size_t i = 0; i != result.size(); ++i) {
277 for (
size_t j = 0; j != result[i].size(); ++j) {
278 std::cerr << result[i][j] <<
280 std::cerr << std::endl;
282 #endif // DEBUG_TRACES 294 template <
typename OutputIterator>
297 std::cout <<
"read_persistence_intervals_and_dimension - " << filename << std::endl;
298 #endif // DEBUG_TRACES 299 std::ifstream in(filename);
301 std::string error_str(
"read_persistence_intervals_and_dimension - Unable to open file ");
302 error_str.append(filename);
303 std::cerr << error_str << std::endl;
304 throw std::invalid_argument(error_str);
310 if (line.length() != 0 && line[0] !=
312 int n = sscanf(line.c_str(),
"%lf %lf %lf %lf", &numbers[0], &numbers[1], &numbers[2], &numbers[3]);
314 std::cout <<
"[" << n <<
315 for (
int i = 0; i < n; i++) {
316 std::cout << numbers[i] <<
318 std::cout << std::endl;
319 #endif // DEBUG_TRACES 321 int dim = (n >= 3 ?
static_cast<int>(numbers[n - 3]) : -1);
322 *out++ = std::make_tuple(dim, numbers[n - 2], numbers[n - 1]);
336 std::string
const& filename) {
337 std::map<int, std::vector<std::pair<double, double>>> ret;
339 filename, boost::make_function_output_iterator([&ret](std::tuple<int, double, double> t) {
340 ret[get<0>(t)].push_back(std::make_pair(get<1>(t), get<2>(t)));
356 int only_this_dim = -1) {
357 std::vector<std::pair<double, double>> ret;
359 filename, boost::make_function_output_iterator([only_this_dim, &ret](std::tuple<int, double, double> t) {
360 if (only_this_dim == get<0>(t) || only_this_dim == -1) ret.emplace_back(get<1>(t), get<2>(t));
367 #endif // READER_UTILS_H_ bool read_simplex(std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil)
Read a face from a file.
Definition: reader_utils.h:158
void read_points(std::string file_name, std::vector< std::vector< double >> &points)
Read a set of points to turn it into a vector< vector<double> > by filling points.
Definition: reader_utils.h:46
std::vector< std::pair< double, double > > read_persistence_intervals_in_dimension(std::string const &filename, int only_this_dim=-1)
Definition: reader_utils.h:355
bool read_hasse_simplex(std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil)
Read a hasse simplex from a file.
Definition: reader_utils.h:183
Definition: SimplicialComplexForAlpha.h:14
std::vector< std::vector< Filtration_value > > read_lower_triangular_matrix_from_csv_file(const std::string &filename, const char separator=';')
Read a lower triangular distance matrix from a csv file. We assume that the .csv store the whole (squ...
Definition: reader_utils.h:220
std::map< int, std::vector< std::pair< double, double > > > read_persistence_intervals_grouped_by_dimension(std::string const &filename)
Definition: reader_utils.h:335
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
void read_persistence_intervals_and_dimension(std::string const &filename, OutputIterator out)
Definition: reader_utils.h:295
Graph_t read_graph(std::string file_name)
Read a graph from a file.
Definition: reader_utils.h:84
