Classes | |
| class | Gudhi::Lazy_toplex_map |
| Lazy toplex map data structure for representing unfiltered simplicial complexes. More... | |
| class | Gudhi::Toplex_map |
| Toplex map data structure for representing unfiltered simplicial complexes. More... | |
A Toplex_map is a data structure to represent and store a simplicial complex. A "toplex" is the contraction of "top-simplex", also known as a maximal simplex. The plural form of "toplex" will be called "toplices".
Let's consider a simplicial complex, denote by \(d\) its dimension and by \(k\) its number of maximal simplices. Furthermore, denote by \(\Gamma_0\) the maximal number of toplices, i.e. maximal simplices, that contain a same vertex.
The goal of the Toplex Map is both to represent the complex in optimal O(kd) space and to provide fast standard operations such as : insertion, removal, contraction of an edge, collapses and membership of a simplex. The time needed for these operation is linear or quadratic in \(\Gamma_0\) and \(d\).
Toplex map is composed firstly of a raw storage of toplices and secondly of a map which associate any vertex to a set of pointers toward all toplices containing this vertex. The data structure is described in [9] (aka. Simplex Array List or SAL).
The performances are a lot better than the Simplex_tree as soon you use maximal simplices and not simplices (cf. [5] ).
| GUDHI Version 3.1.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13 |
