This is one of a scaling functions used to weight points depending on their persistence and/or location in the diagram. This particular functionality is a function which always assign value 1 to a point in the diagram.
| GUDHI Version 3.1.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13 |
