| | Persistence_heat_maps () |
| | Persistence_heat_maps (const std::vector< std::pair< double, double > > &interval, std::vector< std::vector< double > > filter=create_Gaussian_filter(5, 1), bool erase_below_diagonal=false, size_t number_of_pixels=1000, double min_=std::numeric_limits< double >::max(), double max_=std::numeric_limits< double >::max()) |
| | Persistence_heat_maps (const char *filename, std::vector< std::vector< double > > filter=create_Gaussian_filter(5, 1), bool erase_below_diagonal=false, size_t number_of_pixels=1000, double min_=std::numeric_limits< double >::max(), double max_=std::numeric_limits< double >::max(), unsigned dimension=std::numeric_limits< unsigned >::max()) |
| | Persistence_heat_maps (const std::vector< std::pair< double, double > > &interval, const std::function< double(std::pair< double, double >, std::pair< double, double >)> &kernel, size_t number_of_x_pixels, size_t number_of_y_pixels, double min_x=0, double max_x=1, double min_y=0, double max_y=1) |
| | Persistence_heat_maps (const std::vector< std::pair< double, double > > &interval, const std::function< double(std::pair< double, double >, std::pair< double, double >)> &kernel) |
| void | compute_mean (const std::vector< Persistence_heat_maps * > &maps) |
| void | compute_median (const std::vector< Persistence_heat_maps * > &maps) |
| void | compute_percentage_of_active (const std::vector< Persistence_heat_maps * > &maps, size_t cutoff=1) |
| void | print_to_file (const char *filename) const |
| void | load_from_file (const char *filename) |
| bool | check_if_the_same (const Persistence_heat_maps &second) const |
| double | get_min () const |
| double | get_max () const |
| bool | operator== (const Persistence_heat_maps &rhs) const |
| bool | operator!= (const Persistence_heat_maps &rhs) const |
| void | plot (const char *filename) const |
| Persistence_heat_maps | multiply_by_scalar (double scalar) const |
| Persistence_heat_maps | operator* (double scalar) |
| Persistence_heat_maps | operator+= (const Persistence_heat_maps &rhs) |
| Persistence_heat_maps | operator-= (const Persistence_heat_maps &rhs) |
| Persistence_heat_maps | operator*= (double x) |
| Persistence_heat_maps | operator/= (double x) |
| std::vector< double > | vectorize (int number_of_function) const |
| size_t | number_of_vectorize_functions () const |
| double | project_to_R (int number_of_function) const |
| size_t | number_of_projections_to_R () const |
| double | distance (const Persistence_heat_maps &second_, double power=1) const |
| void | compute_average (const std::vector< Persistence_heat_maps * > &to_average) |
| double | compute_scalar_product (const Persistence_heat_maps &second_) const |
| std::pair< double, double > | get_x_range () const |
| std::pair< double, double > | get_y_range () const |
This is a version of a representation presented in https://arxiv.org/abs/1412.6821 In that paper the authors are using the representation just to compute kernel. Over here, we extend the usability by far. Note that the version presented here is not exact, since we are discretizing the kernel. The only difference with respect to the original class is the method of creation. We have full (square) image, and for every point (p,q), we add a kernel at (p,q) and the negative kernel at (q,p)
- Examples:
- Persistence_representations/persistence_heat_maps/create_pssk.cpp.
