Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Simplex_tree/graph_expansion_with_blocker.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Vincent Rouvreau
* Copyright (C) 2014 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Simplex_tree.h>
#include <iostream>
using Simplex_handle = Simplex_tree::Simplex_handle;
int main(int argc, char* const argv[]) {
// Construct the Simplex Tree with a 1-skeleton graph example
Simplex_tree stree;
stree.insert_simplex({0, 1}, 0.);
stree.insert_simplex({0, 2}, 1.);
stree.insert_simplex({0, 3}, 2.);
stree.insert_simplex({1, 2}, 3.);
stree.insert_simplex({1, 3}, 4.);
stree.insert_simplex({2, 3}, 5.);
stree.insert_simplex({2, 4}, 6.);
stree.insert_simplex({3, 6}, 7.);
stree.insert_simplex({4, 5}, 8.);
stree.insert_simplex({4, 6}, 9.);
stree.insert_simplex({5, 6}, 10.);
stree.insert_simplex({6}, 10.);
stree.expansion_with_blockers(3, [&](Simplex_handle sh) {
bool result = false;
std::cout << "Blocker on [";
// User can loop on the vertices from the given simplex_handle i.e.
for (auto vertex : stree.simplex_vertex_range(sh)) {
// We block the expansion, if the vertex '6' is in the given list of vertices
if (vertex == 6) result = true;
std::cout << vertex << ", ";
std::cout << "] ( " << stree.filtration(sh);
// User can re-assign a new filtration value directly in the blocker (default is the maximal value of boudaries)
stree.assign_filtration(sh, stree.filtration(sh) + 1.);
std::cout << " + 1. ) = " << result << std::endl;
return result;
std::cout << "********************************************************************\n";
std::cout << "* The complex contains " << stree.num_simplices() << " simplices";
std::cout << " - dimension " << stree.dimension() << "\n";
std::cout << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
for (auto f_simplex : stree.filtration_simplex_range()) {
std::cout << " "
<< "[" << stree.filtration(f_simplex) << "] ";
for (auto vertex : stree.simplex_vertex_range(f_simplex)) std::cout << "(" << vertex << ")";
std::cout << std::endl;
return 0;
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
