Loading [MathJax]/jax/output/HTML-CSS/config.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
PersistentHomology.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Clément Maria
4  *
5  * Copyright (C) 2014 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
14
20  typedef unspecified Filtered_complex;
21
27  typedef unspecified Coefficient_field;
28
29  };
Concept describing the requirements for a class to compute persistent homology.
Definition: PersistentHomology.h:13
Type of coefficients to be used for computing persistent homology.
Definition: PersistentHomology.h:27
Type of filtered cell complex on which persistent homology is computed.
Definition: PersistentHomology.h:20
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
