#include <gudhi/Persistence_vectors.h>
#include <iostream>
#include <sstream>
#include <limits>
#include <vector>
int main(int argc, char** argv) {
std::cout << "This program compute distance of persistence vectors stored in a file (the file needs to be created "
"beforehand). \n";
std::cout << "The first parameter of a program is an integer p. The program compute l^p distance of the vectors. For "
"l^infty distance choose p = -1. \n";
std::cout << "The remaining parameters of this programs are names of files with persistence vectors.\n";
if (argc < 3) {
std::cout << "Wrong number of parameters, the program will now terminate \n";
return 1;
int pp = atoi(argv[1]);
double p = std::numeric_limits<double>::max();
if (pp != -1) {
p = pp;
std::vector<const char*> filenames;
for (int i = 2; i < argc; ++i) {
filenames.push_back(argv[i]);
std::vector<Vector_distances_in_diagram> vectors;
vectors.reserve(filenames.size());
for (size_t file_no = 0; file_no != filenames.size(); ++file_no) {
vectors.push_back(l);
std::vector<std::vector<double> > distance(filenames.size());
for (size_t i = 0; i != filenames.size(); ++i) {
std::vector<double> v(filenames.size(), 0);
distance[i] = v;
for (size_t i = 0; i != vectors.size(); ++i) {
for (size_t j = i + 1; j != vectors.size(); ++j) {
distance[i][j] = distance[j][i] = vectors[i].distance(vectors[j], p);
std::ofstream out;
out.open("distance.vect");
for (size_t i = 0; i != distance.size(); ++i) {
for (size_t j = 0; j != distance.size(); ++j) {
std::cout << distance[i][j] << " ";
std::cout << std::endl;
out << std::endl;
out.close();
std::cout << "Distance can be found in 'distance.vect' file\n";
return 0;
