Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Persistence_landscape.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Pawel Dlotko
4  *
5  * Copyright (C) 2016 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef PERSISTENCE_LANDSCAPE_H_
12 #define PERSISTENCE_LANDSCAPE_H_
13
14 // gudhi include
15 #include <gudhi/read_persistence_from_file.h>
16 #include <gudhi/common_persistence_representations.h>
17
18 // standard include
19 #include <cmath>
20 #include <iostream>
21 #include <vector>
22 #include <limits>
23 #include <fstream>
24 #include <sstream>
25 #include <algorithm>
26 #include <string>
27 #include <utility>
28 #include <functional>
29
30 namespace Gudhi {
31 namespace Persistence_representations {
32
33 // pre declaration
35 template <typename operation>
36 Persistence_landscape operation_on_pair_of_landscapes(const Persistence_landscape& land1,
37  const Persistence_landscape& land2);
38
61  public:
65  Persistence_landscape() { this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals(); }
66
70  Persistence_landscape(const std::vector<std::pair<double, double> >& p,
71  size_t number_of_levels = std::numeric_limits<size_t>::max());
72
78  Persistence_landscape(const char* filename, size_t dimension = std::numeric_limits<unsigned>::max(),
79  size_t number_of_levels = std::numeric_limits<size_t>::max());
80
84  void load_landscape_from_file(const char* filename);
85
89  void print_to_file(const char* filename) const;
90
95  double compute_integral_of_landscape() const;
96
100  double compute_integral_of_a_level_of_a_landscape(size_t level) const;
101
106  double compute_integral_of_landscape(double p) const; // this function compute integral of p-th power of landscape.
107
113  double compute_value_at_a_given_point(unsigned level, double x) const;
114
120  friend std::ostream& operator<<(std::ostream& out, Persistence_landscape& land);
121
122  template <typename operation>
123  friend Persistence_landscape operation_on_pair_of_landscapes(const Persistence_landscape& land1,
124  const Persistence_landscape& land2);
125
130  const Persistence_landscape& land2) {
131  return operation_on_pair_of_landscapes<std::plus<double> >(land1, land2);
132  }
133
138  const Persistence_landscape& land2) {
139  return operation_on_pair_of_landscapes<std::minus<double> >(land1, land2);
140  }
141
146  return add_two_landscapes(first, second);
147  }
148
153  return subtract_two_landscapes(first, second);
154  }
155
159  friend Persistence_landscape operator*(const Persistence_landscape& first, double con) {
160  return first.multiply_lanscape_by_real_number_not_overwrite(con);
161  }
162
166  friend Persistence_landscape operator*(double con, const Persistence_landscape& first) {
167  return first.multiply_lanscape_by_real_number_not_overwrite(con);
168  }
169
174  *this = *this + rhs;
175  return *this;
176  }
177
182  *this = *this - rhs;
183  return *this;
184  }
185
191  *this = *this * x;
192  return *this;
193  }
194
199  if (x == 0) throw("In operator /=, division by 0. Program terminated.");
200  *this = *this * (1 / x);
201  return *this;
202  }
203
207  bool operator==(const Persistence_landscape& rhs) const;
208
212  bool operator!=(const Persistence_landscape& rhs) const { return !((*this) == rhs); }
213
217  double compute_maximum() const {
218  double maxValue = 0;
219  if (this->land.size()) {
220  maxValue = -std::numeric_limits<int>::max();
221  for (size_t i = 0; i != this->land[0].size(); ++i) {
222  if (this->land[0][i].second > maxValue) maxValue = this->land[0][i].second;
223  }
224  }
225  return maxValue;
226  }
227
231  double compute_minimum() const {
232  double minValue = 0;
233  if (this->land.size()) {
234  minValue = std::numeric_limits<int>::max();
235  for (size_t i = 0; i != this->land[0].size(); ++i) {
236  if (this->land[0][i].second < minValue) minValue = this->land[0][i].second;
237  }
238  }
239  return minValue;
240  }
241
245  double compute_norm_of_landscape(double i) {
247  if (i < std::numeric_limits<double>::max()) {
248  return compute_distance_of_landscapes(*this, l, i);
249  } else {
251  }
252  }
253
257  double operator()(unsigned level, double x) const { return this->compute_value_at_a_given_point(level, x); }
258
263  const Persistence_landscape& second);
264
268  friend double compute_distance_of_landscapes(const Persistence_landscape& first, const Persistence_landscape& second,
269  double p);
270
278
279  Persistence_landscape* new_abs();
280
284  size_t size() const { return this->land.size(); }
285
289  double find_max(unsigned lambda) const;
290
294  friend double compute_inner_product(const Persistence_landscape& l1, const Persistence_landscape& l2);
295
296  // Implementations of functions for various concepts.
297
306  double project_to_R(int number_of_function) const {
307  return this->compute_integral_of_a_level_of_a_landscape((size_t)number_of_function);
308  }
309
314  size_t number_of_projections_to_R() const { return this->number_of_functions_for_projections_to_reals; }
315
320  std::vector<double> vectorize(int number_of_function) const {
321  // TODO(PD) think of something smarter over here
322  std::vector<double> v;
323  if ((size_t)number_of_function > this->land.size()) {
324  return v;
325  }
326  v.reserve(this->land[number_of_function].size());
327  for (size_t i = 0; i != this->land[number_of_function].size(); ++i) {
328  v.push_back(this->land[number_of_function][i].second);
329  }
330  return v;
331  }
336  size_t number_of_vectorize_functions() const { return this->number_of_functions_for_vectorization; }
337
342  void compute_average(const std::vector<Persistence_landscape*>& to_average) {
343  bool dbg = false;
344
345  if (dbg) {
346  std::cerr << "to_average.size() : " << to_average.size() << std::endl;
347  }
348
349  std::vector<Persistence_landscape*> nextLevelMerge(to_average.size());
350  for (size_t i = 0; i != to_average.size(); ++i) {
351  nextLevelMerge[i] = to_average[i];
352  }
353  bool is_this_first_level = true; // in the loop, we will create dynamically a number of intermediate complexes. We
354  // have to clean that up, but we cannot erase the initial landscapes we have
355  // to average. In this case, we simply check if the nextLevelMerge are the input landscapes or the ones created in
356  // that loop by using this extra variable.
357
358  while (nextLevelMerge.size() != 1) {
359  if (dbg) {
360  std::cerr << "nextLevelMerge.size() : " << nextLevelMerge.size() << std::endl;
361  }
362  std::vector<Persistence_landscape*> nextNextLevelMerge;
363  nextNextLevelMerge.reserve(to_average.size());
364  for (size_t i = 0; i < nextLevelMerge.size(); i = i + 2) {
365  if (dbg) {
366  std::cerr << "i : " << i << std::endl;
367  }
369  if (i + 1 != nextLevelMerge.size()) {
370  (*l) = (*nextLevelMerge[i]) + (*nextLevelMerge[i + 1]);
371  } else {
372  (*l) = *nextLevelMerge[i];
373  }
374  nextNextLevelMerge.push_back(l);
375  }
376  if (dbg) {
377  std::cerr << "After this iteration \n";
378  getchar();
379  }
380
381  if (!is_this_first_level) {
382  // deallocate the memory if the vector nextLevelMerge do not consist of the initial landscapes
383  for (size_t i = 0; i != nextLevelMerge.size(); ++i) {
384  delete nextLevelMerge[i];
385  }
386  }
387  is_this_first_level = false;
388  nextLevelMerge.swap(nextNextLevelMerge);
389  }
390  (*this) = (*nextLevelMerge[0]);
391  (*this) *= 1 / static_cast<double>(to_average.size());
392  }
393
400  double distance(const Persistence_landscape& second, double power = 1) const {
401  if (power < std::numeric_limits<double>::max()) {
402  return compute_distance_of_landscapes(*this, second, power);
403  } else {
404  return compute_max_norm_distance_of_landscapes(*this, second);
405  }
406  }
407
413  double compute_scalar_product(const Persistence_landscape& second) const {
414  return compute_inner_product((*this), second);
415  }
416  // end of implementation of functions needed for concepts.
417
422  std::pair<double, double> get_y_range(size_t level = 0) const {
423  std::pair<double, double> result;
424  if (level < this->land.size()) {
425  double maxx = this->compute_maximum();
426  double minn = this->compute_minimum();
427  result = std::make_pair(minn, maxx);
428  } else {
429  result = std::make_pair(0, 0);
430  }
431  return result;
432  }
433
434  // a function used to create a gnuplot script for visualization of landscapes
435  void plot(const char* filename, double xRangeBegin = std::numeric_limits<double>::max(),
436  double xRangeEnd = std::numeric_limits<double>::max(),
437  double yRangeBegin = std::numeric_limits<double>::max(),
438  double yRangeEnd = std::numeric_limits<double>::max(), int from = std::numeric_limits<int>::max(),
439  int to = std::numeric_limits<int>::max());
440
441  protected:
442  std::vector<std::vector<std::pair<double, double> > > land;
443  size_t number_of_functions_for_vectorization;
444  size_t number_of_functions_for_projections_to_reals;
445
446  void construct_persistence_landscape_from_barcode(const std::vector<std::pair<double, double> >& p,
447  size_t number_of_levels = std::numeric_limits<size_t>::max());
448  Persistence_landscape multiply_lanscape_by_real_number_not_overwrite(double x) const;
449  void multiply_lanscape_by_real_number_overwrite(double x);
450  friend double compute_maximal_distance_non_symmetric(const Persistence_landscape& pl1,
451  const Persistence_landscape& pl2);
452
453  void set_up_numbers_of_functions_for_vectorization_and_projections_to_reals() {
454  // warning, this function can be only called after filling in the intervals vector.
455  this->number_of_functions_for_vectorization = this->land.size();
456  this->number_of_functions_for_projections_to_reals = this->land.size();
457  }
458 };
459
460 Persistence_landscape::Persistence_landscape(const char* filename, size_t dimension, size_t number_of_levels) {
461  std::vector<std::pair<double, double> > barcode;
462  if (dimension < std::numeric_limits<double>::max()) {
463  barcode = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
464  } else {
465  barcode = read_persistence_intervals_in_one_dimension_from_file(filename);
466  }
467  this->construct_persistence_landscape_from_barcode(barcode, number_of_levels);
468  this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
469 }
470
471 bool operatorEqualDbg = false;
473  if (this->land.size() != rhs.land.size()) {
474  if (operatorEqualDbg) std::cerr << "1\n";
475  return false;
476  }
477  for (size_t level = 0; level != this->land.size(); ++level) {
478  if (this->land[level].size() != rhs.land[level].size()) {
479  if (operatorEqualDbg) std::cerr << "this->land[level].size() : " << this->land[level].size() << "\n";
480  if (operatorEqualDbg) std::cerr << "rhs.land[level].size() : " << rhs.land[level].size() << "\n";
481  if (operatorEqualDbg) std::cerr << "2\n";
482  return false;
483  }
484  for (size_t i = 0; i != this->land[level].size(); ++i) {
485  if (!(almost_equal(this->land[level][i].first, rhs.land[level][i].first) &&
486  almost_equal(this->land[level][i].second, rhs.land[level][i].second))) {
487  if (operatorEqualDbg)
488  std::cerr << "this->land[level][i] : " << this->land[level][i].first << " " << this->land[level][i].second
489  << "\n";
490  if (operatorEqualDbg)
491  std::cerr << "rhs.land[level][i] : " << rhs.land[level][i].first << " " << rhs.land[level][i].second << "\n";
492  if (operatorEqualDbg) std::cerr << "3\n";
493  return false;
494  }
495  }
496  }
497  return true;
498 }
499
500 Persistence_landscape::Persistence_landscape(const std::vector<std::pair<double, double> >& p,
501  size_t number_of_levels) {
502  this->construct_persistence_landscape_from_barcode(p, number_of_levels);
503  this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
504 }
505
506 void Persistence_landscape::construct_persistence_landscape_from_barcode(
507  const std::vector<std::pair<double, double> >& p, size_t number_of_levels) {
508  bool dbg = false;
509  if (dbg) {
510  std::cerr << "Persistence_landscape::Persistence_landscape( const std::vector< std::pair< double , double > >& p )"
511  << std::endl;
512  }
513
514  // this is a general algorithm to construct persistence landscapes.
515  std::vector<std::pair<double, double> > bars;
516  bars.insert(bars.begin(), p.begin(), p.end());
517  std::sort(bars.begin(), bars.end(), compare_points_sorting);
518
519  if (dbg) {
520  std::cerr << "Bars : \n";
521  for (size_t i = 0; i != bars.size(); ++i) {
522  std::cerr << bars[i].first << " " << bars[i].second << "\n";
523  }
524  getchar();
525  }
526
527  std::vector<std::pair<double, double> > characteristicPoints(p.size());
528  for (size_t i = 0; i != bars.size(); ++i) {
529  characteristicPoints[i] =
530  std::make_pair((bars[i].first + bars[i].second) / 2.0, (bars[i].second - bars[i].first) / 2.0);
531  }
532  std::vector<std::vector<std::pair<double, double> > > Persistence_landscape;
533  size_t number_of_levels_in_the_landscape = 0;
534  while (!characteristicPoints.empty()) {
535  if (dbg) {
536  for (size_t i = 0; i != characteristicPoints.size(); ++i) {
537  std::cout << "(" << characteristicPoints[i].first << " " << characteristicPoints[i].second << ")\n";
538  }
539  std::cin.ignore();
540  }
541
542  std::vector<std::pair<double, double> > lambda_n;
543  lambda_n.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
544  lambda_n.push_back(std::make_pair(minus_length(characteristicPoints[0]), 0));
545  lambda_n.push_back(characteristicPoints[0]);
546
547  if (dbg) {
548  std::cerr << "1 Adding to lambda_n : (" << -std::numeric_limits<int>::max() << " " << 0 << ") , ("
549  << minus_length(characteristicPoints[0]) << " " << 0 << ") , (" << characteristicPoints[0].first << " "
550  << characteristicPoints[0].second << ") \n";
551  }
552
553  size_t i = 1;
554  std::vector<std::pair<double, double> > newCharacteristicPoints;
555  while (i < characteristicPoints.size()) {
556  size_t p = 1;
557  if ((minus_length(characteristicPoints[i]) >= minus_length(lambda_n[lambda_n.size() - 1])) &&
558  (birth_plus_deaths(characteristicPoints[i]) > birth_plus_deaths(lambda_n[lambda_n.size() - 1]))) {
559  if (minus_length(characteristicPoints[i]) < birth_plus_deaths(lambda_n[lambda_n.size() - 1])) {
560  std::pair<double, double> point = std::make_pair(
561  (minus_length(characteristicPoints[i]) + birth_plus_deaths(lambda_n[lambda_n.size() - 1])) / 2,
562  (birth_plus_deaths(lambda_n[lambda_n.size() - 1]) - minus_length(characteristicPoints[i])) / 2);
563  lambda_n.push_back(point);
564  if (dbg) {
565  std::cerr << "2 Adding to lambda_n : (" << point.first << " " << point.second << ")\n";
566  }
567
568  if (dbg) {
569  std::cerr << "characteristicPoints[i+p] : " << characteristicPoints[i + p].first << " "
570  << characteristicPoints[i + p].second << "\n";
571  std::cerr << "point : " << point.first << " " << point.second << "\n";
572  getchar();
573  }
574
575  while ((i + p < characteristicPoints.size()) &&
576  (almost_equal(minus_length(point), minus_length(characteristicPoints[i + p]))) &&
577  (birth_plus_deaths(point) <= birth_plus_deaths(characteristicPoints[i + p]))) {
578  newCharacteristicPoints.push_back(characteristicPoints[i + p]);
579  if (dbg) {
580  std::cerr << "3.5 Adding to newCharacteristicPoints : (" << characteristicPoints[i + p].first << " "
581  << characteristicPoints[i + p].second << ")\n";
582  getchar();
583  }
584  ++p;
585  }
586
587  newCharacteristicPoints.push_back(point);
588  if (dbg) {
589  std::cerr << "4 Adding to newCharacteristicPoints : (" << point.first << " " << point.second << ")\n";
590  }
591
592  while ((i + p < characteristicPoints.size()) &&
593  (minus_length(point) <= minus_length(characteristicPoints[i + p])) &&
594  (birth_plus_deaths(point) >= birth_plus_deaths(characteristicPoints[i + p]))) {
595  newCharacteristicPoints.push_back(characteristicPoints[i + p]);
596  if (dbg) {
597  std::cerr << "characteristicPoints[i+p] : " << characteristicPoints[i + p].first << " "
598  << characteristicPoints[i + p].second << "\n";
599  std::cerr << "point : " << point.first << " " << point.second << "\n";
600  std::cerr << "characteristicPoints[i+p] birth and death : " << minus_length(characteristicPoints[i + p])
601  << " , " << birth_plus_deaths(characteristicPoints[i + p]) << "\n";
602  std::cerr << "point birth and death : " << minus_length(point) << " , " << birth_plus_deaths(point)
603  << "\n";
604
605  std::cerr << "3 Adding to newCharacteristicPoints : (" << characteristicPoints[i + p].first << " "
606  << characteristicPoints[i + p].second << ")\n";
607  getchar();
608  }
609  ++p;
610  }
611
612  } else {
613  lambda_n.push_back(std::make_pair(birth_plus_deaths(lambda_n[lambda_n.size() - 1]), 0));
614  lambda_n.push_back(std::make_pair(minus_length(characteristicPoints[i]), 0));
615  if (dbg) {
616  std::cerr << "5 Adding to lambda_n : (" << birth_plus_deaths(lambda_n[lambda_n.size() - 1]) << " " << 0
617  << ")\n";
618  std::cerr << "5 Adding to lambda_n : (" << minus_length(characteristicPoints[i]) << " " << 0 << ")\n";
619  }
620  }
621  lambda_n.push_back(characteristicPoints[i]);
622  if (dbg) {
623  std::cerr << "6 Adding to lambda_n : (" << characteristicPoints[i].first << " "
624  << characteristicPoints[i].second << ")\n";
625  }
626  } else {
627  newCharacteristicPoints.push_back(characteristicPoints[i]);
628  if (dbg) {
629  std::cerr << "7 Adding to newCharacteristicPoints : (" << characteristicPoints[i].first << " "
630  << characteristicPoints[i].second << ")\n";
631  }
632  }
633  i = i + p;
634  }
635  lambda_n.push_back(std::make_pair(birth_plus_deaths(lambda_n[lambda_n.size() - 1]), 0));
636  lambda_n.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
637
638  characteristicPoints = newCharacteristicPoints;
639
640  lambda_n.erase(std::unique(lambda_n.begin(), lambda_n.end()), lambda_n.end());
641  this->land.push_back(lambda_n);
642
643  ++number_of_levels_in_the_landscape;
644  if (number_of_levels == number_of_levels_in_the_landscape) {
645  break;
646  }
647  }
648 }
649
650 // this function find maximum of lambda_n
651 double Persistence_landscape::find_max(unsigned lambda) const {
652  if (this->land.size() < lambda) return 0;
653  double maximum = -std::numeric_limits<int>::max();
654  for (size_t i = 0; i != this->land[lambda].size(); ++i) {
655  if (this->land[lambda][i].second > maximum) maximum = this->land[lambda][i].second;
656  }
657  return maximum;
658 }
659
661  double result = 0;
662  for (size_t i = 0; i != this->land.size(); ++i) {
663  for (size_t nr = 2; nr != this->land[i].size() - 1; ++nr) {
664  // it suffices to compute every planar integral and then sum them up for each lambda_n
665  result += 0.5 * (this->land[i][nr].first - this->land[i][nr - 1].first) *
666  (this->land[i][nr].second + this->land[i][nr - 1].second);
667  }
668  }
669  return result;
670 }
671
673  double result = 0;
674  if (level >= this->land.size()) {
675  // this landscape function is constantly equal 0, so is the integral.
676  return result;
677  }
678  // also negative landscapes are assumed to be zero.
679  if (level < 0) return 0;
680
681  for (size_t nr = 2; nr != this->land[level].size() - 1; ++nr) {
682  // it suffices to compute every planar integral and then sum them up for each lambda_n
683  result += 0.5 * (this->land[level][nr].first - this->land[level][nr - 1].first) *
684  (this->land[level][nr].second + this->land[level][nr - 1].second);
685  }
686
687  return result;
688 }
689
691  bool dbg = false;
692  double result = 0;
693  for (size_t i = 0; i != this->land.size(); ++i) {
694  for (size_t nr = 2; nr != this->land[i].size() - 1; ++nr) {
695  if (dbg) std::cout << "nr : " << nr << "\n";
696  // In this interval, the landscape has a form f(x) = ax+b. We want to compute integral of (ax+b)^p = 1/a *
697  // (ax+b)^{p+1}/(p+1)
698  std::pair<double, double> coef = compute_parameters_of_a_line(this->land[i][nr], this->land[i][nr - 1]);
699  double a = coef.first;
700  double b = coef.second;
701
702  if (dbg)
703  std::cout << "(" << this->land[i][nr].first << "," << this->land[i][nr].second << ") , "
704  << this->land[i][nr - 1].first << "," << this->land[i][nr].second << ")" << std::endl;
705  if (this->land[i][nr].first == this->land[i][nr - 1].first) continue;
706  if (a != 0) {
707  result += 1 / (a * (p + 1)) *
708  (pow((a * this->land[i][nr].first + b), p + 1) - pow((a * this->land[i][nr - 1].first + b), p + 1));
709  } else {
710  result += (this->land[i][nr].first - this->land[i][nr - 1].first) * (pow(this->land[i][nr].second, p));
711  }
712  if (dbg) {
713  std::cout << "a : " << a << " , b : " << b << std::endl;
714  std::cout << "result : " << result << std::endl;
715  }
716  }
717  }
718  return result;
719 }
720
721 // this is O(log(n)) algorithm, where n is number of points in this->land.
722 double Persistence_landscape::compute_value_at_a_given_point(unsigned level, double x) const {
723  bool compute_value_at_a_given_pointDbg = false;
724  // in such a case lambda_level = 0.
725  if (level >= this->land.size()) return 0;
726
727  // we know that the points in this->land[level] are ordered according to x coordinate. Therefore, we can find the
728  // point by using bisection:
729  unsigned coordBegin = 1;
730  unsigned coordEnd = this->land[level].size() - 2;
731
732  if (compute_value_at_a_given_pointDbg) {
733  std::cerr << "Here \n";
734  std::cerr << "x : " << x << "\n";
735  std::cerr << "this->land[level][coordBegin].first : " << this->land[level][coordBegin].first << "\n";
736  std::cerr << "this->land[level][coordEnd].first : " << this->land[level][coordEnd].first << "\n";
737  }
738
739  // in this case x is outside the support of the landscape, therefore the value of the landscape is 0.
740  if (x <= this->land[level][coordBegin].first) return 0;
741  if (x >= this->land[level][coordEnd].first) return 0;
742
743  if (compute_value_at_a_given_pointDbg) std::cerr << "Entering to the while loop \n";
744
745  while (coordBegin + 1 != coordEnd) {
746  if (compute_value_at_a_given_pointDbg) {
747  std::cerr << "coordBegin : " << coordBegin << "\n";
748  std::cerr << "coordEnd : " << coordEnd << "\n";
749  std::cerr << "this->land[level][coordBegin].first : " << this->land[level][coordBegin].first << "\n";
750  std::cerr << "this->land[level][coordEnd].first : " << this->land[level][coordEnd].first << "\n";
751  }
752
753  unsigned newCord = (unsigned)floor((coordEnd + coordBegin) / 2.0);
754
755  if (compute_value_at_a_given_pointDbg) {
756  std::cerr << "newCord : " << newCord << "\n";
757  std::cerr << "this->land[level][newCord].first : " << this->land[level][newCord].first << "\n";
758  std::cin.ignore();
759  }
760
761  if (this->land[level][newCord].first <= x) {
762  coordBegin = newCord;
763  if (this->land[level][newCord].first == x) return this->land[level][newCord].second;
764  } else {
765  coordEnd = newCord;
766  }
767  }
768
769  if (compute_value_at_a_given_pointDbg) {
770  std::cout << "x : " << x << " is between : " << this->land[level][coordBegin].first << " a "
771  << this->land[level][coordEnd].first << "\n";
772  std::cout << "the y coords are : " << this->land[level][coordBegin].second << " a "
773  << this->land[level][coordEnd].second << "\n";
774  std::cerr << "coordBegin : " << coordBegin << "\n";
775  std::cerr << "coordEnd : " << coordEnd << "\n";
776  std::cin.ignore();
777  }
778  return function_value(this->land[level][coordBegin], this->land[level][coordEnd], x);
779 }
780
781 std::ostream& operator<<(std::ostream& out, Persistence_landscape& land) {
782  for (size_t level = 0; level != land.land.size(); ++level) {
783  out << "Lambda_" << level << ":" << std::endl;
784  for (size_t i = 0; i != land.land[level].size(); ++i) {
785  if (land.land[level][i].first == -std::numeric_limits<int>::max()) {
786  out << "-inf";
787  } else {
788  if (land.land[level][i].first == std::numeric_limits<int>::max()) {
789  out << "+inf";
790  } else {
791  out << land.land[level][i].first;
792  }
793  }
794  out << " , " << land.land[level][i].second << std::endl;
795  }
796  }
797  return out;
798 }
799
800 void Persistence_landscape::multiply_lanscape_by_real_number_overwrite(double x) {
801  for (size_t dim = 0; dim != this->land.size(); ++dim) {
802  for (size_t i = 0; i != this->land[dim].size(); ++i) {
803  this->land[dim][i].second *= x;
804  }
805  }
806 }
807
808 bool AbsDbg = false;
810  Persistence_landscape result;
811  for (size_t level = 0; level != this->land.size(); ++level) {
812  if (AbsDbg) {
813  std::cout << "level: " << level << std::endl;
814  }
815  std::vector<std::pair<double, double> > lambda_n;
816  lambda_n.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
817  for (size_t i = 1; i != this->land[level].size(); ++i) {
818  if (AbsDbg) {
819  std::cout << "this->land[" << level << "][" << i << "] : " << this->land[level][i].first << " "
820  << this->land[level][i].second << std::endl;
821  }
822  // if a line segment between this->land[level][i-1] and this->land[level][i] crosses the x-axis, then we have to
823  // add one landscape point t o result
824  if ((this->land[level][i - 1].second) * (this->land[level][i].second) < 0) {
825  double zero =
826  find_zero_of_a_line_segment_between_those_two_points(this->land[level][i - 1], this->land[level][i]);
827
828  lambda_n.push_back(std::make_pair(zero, 0));
829  lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
830  if (AbsDbg) {
831  std::cout << "Adding pair : (" << zero << ",0)" << std::endl;
832  std::cout << "In the same step adding pair : (" << this->land[level][i].first << ","
833  << fabs(this->land[level][i].second) << ") " << std::endl;
834  std::cin.ignore();
835  }
836  } else {
837  lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
838  if (AbsDbg) {
839  std::cout << "Adding pair : (" << this->land[level][i].first << "," << fabs(this->land[level][i].second)
840  << ") " << std::endl;
841  std::cin.ignore();
842  }
843  }
844  }
845  result.land.push_back(lambda_n);
846  }
847  return result;
848 }
849
850 Persistence_landscape* Persistence_landscape::new_abs() {
851  Persistence_landscape* result = new Persistence_landscape(*this);
852  for (size_t level = 0; level != this->land.size(); ++level) {
853  if (AbsDbg) {
854  std::cout << "level: " << level << std::endl;
855  }
856  std::vector<std::pair<double, double> > lambda_n;
857  lambda_n.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
858  for (size_t i = 1; i != this->land[level].size(); ++i) {
859  if (AbsDbg) {
860  std::cout << "this->land[" << level << "][" << i << "] : " << this->land[level][i].first << " "
861  << this->land[level][i].second << std::endl;
862  }
863  // if a line segment between this->land[level][i-1] and this->land[level][i] crosses the x-axis, then we have to
864  // add one landscape point t o result
865  if ((this->land[level][i - 1].second) * (this->land[level][i].second) < 0) {
866  double zero =
867  find_zero_of_a_line_segment_between_those_two_points(this->land[level][i - 1], this->land[level][i]);
868
869  lambda_n.push_back(std::make_pair(zero, 0));
870  lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
871  if (AbsDbg) {
872  std::cout << "Adding pair : (" << zero << ",0)" << std::endl;
873  std::cout << "In the same step adding pair : (" << this->land[level][i].first << ","
874  << fabs(this->land[level][i].second) << ") " << std::endl;
875  std::cin.ignore();
876  }
877  } else {
878  lambda_n.push_back(std::make_pair(this->land[level][i].first, fabs(this->land[level][i].second)));
879  if (AbsDbg) {
880  std::cout << "Adding pair : (" << this->land[level][i].first << "," << fabs(this->land[level][i].second)
881  << ") " << std::endl;
882  std::cin.ignore();
883  }
884  }
885  }
886  result->land.push_back(lambda_n);
887  }
888  return result;
889 }
890
891 Persistence_landscape Persistence_landscape::multiply_lanscape_by_real_number_not_overwrite(double x) const {
892  std::vector<std::vector<std::pair<double, double> > > result(this->land.size());
893  for (size_t dim = 0; dim != this->land.size(); ++dim) {
894  std::vector<std::pair<double, double> > lambda_dim(this->land[dim].size());
895  for (size_t i = 0; i != this->land[dim].size(); ++i) {
896  lambda_dim[i] = std::make_pair(this->land[dim][i].first, x * this->land[dim][i].second);
897  }
898  result[dim] = lambda_dim;
899  }
901  // CHANGE
902  // res.land = result;
903  res.land.swap(result);
904  return res;
905 } // multiply_lanscape_by_real_number_overwrite
906
907 void Persistence_landscape::print_to_file(const char* filename) const {
908  std::ofstream write;
909  write.open(filename);
910  for (size_t dim = 0; dim != this->land.size(); ++dim) {
911  write << "#lambda_" << dim << std::endl;
912  for (size_t i = 1; i != this->land[dim].size() - 1; ++i) {
913  write << this->land[dim][i].first << " " << this->land[dim][i].second << std::endl;
914  }
915  }
916  write.close();
917 }
918
920  bool dbg = false;
921  // removing the current content of the persistence landscape.
922  this->land.clear();
923
924  // this constructor reads persistence landscape form a file. This file have to be created by this software before head
925  std::ifstream in;
926  in.open(filename);
927  if (!in.good()) {
928  std::cerr << "The file : " << filename << " do not exist. The program will now terminate \n";
929  throw "The persistence landscape file do not exist. The program will now terminate \n";
930  }
931
932  std::string line;
933  std::vector<std::pair<double, double> > landscapeAtThisLevel;
934
935  bool isThisAFirsLine = true;
936  while (in.good()) {
937  getline(in, line);
938  if (!(line.length() == 0 || line[0] == '#')) {
939  std::stringstream lineSS;
940  lineSS << line;
941  double beginn, endd;
942  lineSS >> beginn;
943  lineSS >> endd;
944  landscapeAtThisLevel.push_back(std::make_pair(beginn, endd));
945  if (dbg) {
946  std::cerr << "Reading a point : " << beginn << " , " << endd << std::endl;
947  }
948  } else {
949  if (dbg) {
950  std::cout << "IGNORE LINE\n";
951  getchar();
952  }
953  if (!isThisAFirsLine) {
954  landscapeAtThisLevel.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
955  this->land.push_back(landscapeAtThisLevel);
956  std::vector<std::pair<double, double> > newLevelOdLandscape;
957  landscapeAtThisLevel.swap(newLevelOdLandscape);
958  }
959  landscapeAtThisLevel.push_back(std::make_pair(-std::numeric_limits<int>::max(), 0));
960  isThisAFirsLine = false;
961  }
962  }
963  if (landscapeAtThisLevel.size() > 1) {
964  // seems that the last line of the file is not finished with the newline sign. We need to put what we have in
965  // landscapeAtThisLevel to the constructed landscape.
966  landscapeAtThisLevel.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
967  this->land.push_back(landscapeAtThisLevel);
968  }
969
970  in.close();
971 }
972
973 template <typename T>
974 Persistence_landscape operation_on_pair_of_landscapes(const Persistence_landscape& land1,
975  const Persistence_landscape& land2) {
976  bool operation_on_pair_of_landscapesDBG = false;
977  if (operation_on_pair_of_landscapesDBG) {
978  std::cout << "operation_on_pair_of_landscapes\n";
979  std::cin.ignore();
980  }
981  Persistence_landscape result;
982  std::vector<std::vector<std::pair<double, double> > > land(std::max(land1.land.size(), land2.land.size()));
983  result.land = land;
984  T oper;
985
986  if (operation_on_pair_of_landscapesDBG) {
987  for (size_t i = 0; i != std::min(land1.land.size(), land2.land.size()); ++i) {
988  std::cerr << "land1.land[" << i << "].size() : " << land1.land[i].size() << std::endl;
989  std::cerr << "land2.land[" << i << "].size() : " << land2.land[i].size() << std::endl;
990  }
991  getchar();
992  }
993
994  for (size_t i = 0; i != std::min(land1.land.size(), land2.land.size()); ++i) {
995  std::vector<std::pair<double, double> > lambda_n;
996  size_t p = 0;
997  size_t q = 0;
998  while ((p + 1 < land1.land[i].size()) && (q + 1 < land2.land[i].size())) {
999  if (operation_on_pair_of_landscapesDBG) {
1000  std::cerr << "p : " << p << "\n";
1001  std::cerr << "q : " << q << "\n";
1002  std::cerr << "land1.land.size() : " << land1.land.size() << std::endl;
1003  std::cerr << "land2.land.size() : " << land2.land.size() << std::endl;
1004  std::cerr << "land1.land[" << i << "].size() : " << land1.land[i].size() << std::endl;
1005  std::cerr << "land2.land[" << i << "].size() : " << land2.land[i].size() << std::endl;
1006  std::cout << "land1.land[i][p].first : " << land1.land[i][p].first << "\n";
1007  std::cout << "land2.land[i][q].first : " << land2.land[i][q].first << "\n";
1008  }
1009
1010  if (land1.land[i][p].first < land2.land[i][q].first) {
1011  if (operation_on_pair_of_landscapesDBG) {
1012  std::cout << "first \n";
1013  std::cout << " function_value(land2.land[i][q-1],land2.land[i][q],land1.land[i][p].first) : "
1014  << function_value(land2.land[i][q - 1], land2.land[i][q], land1.land[i][p].first) << "\n";
1015  }
1016  lambda_n.push_back(
1017  std::make_pair(land1.land[i][p].first,
1018  oper(static_cast<double>(land1.land[i][p].second),
1019  function_value(land2.land[i][q - 1], land2.land[i][q], land1.land[i][p].first))));
1020  ++p;
1021  continue;
1022  }
1023  if (land1.land[i][p].first > land2.land[i][q].first) {
1024  if (operation_on_pair_of_landscapesDBG) {
1025  std::cout << "Second \n";
1026  std::cout << "function_value(" << land1.land[i][p - 1].first << " " << land1.land[i][p - 1].second << " ,"
1027  << land1.land[i][p].first << " " << land1.land[i][p].second << ", " << land2.land[i][q].first
1028  << " ) : " << function_value(land1.land[i][p - 1], land1.land[i][p - 1], land2.land[i][q].first)
1029  << "\n";
1030  std::cout << "oper( " << function_value(land1.land[i][p], land1.land[i][p - 1], land2.land[i][q].first) << ","
1031  << land2.land[i][q].second << " : "
1032  << oper(land2.land[i][q].second,
1033  function_value(land1.land[i][p], land1.land[i][p - 1], land2.land[i][q].first))
1034  << "\n";
1035  }
1036  lambda_n.push_back(std::make_pair(
1037  land2.land[i][q].first, oper(function_value(land1.land[i][p], land1.land[i][p - 1], land2.land[i][q].first),
1038  land2.land[i][q].second)));
1039  ++q;
1040  continue;
1041  }
1042  if (land1.land[i][p].first == land2.land[i][q].first) {
1043  if (operation_on_pair_of_landscapesDBG) std::cout << "Third \n";
1044  lambda_n.push_back(
1045  std::make_pair(land2.land[i][q].first, oper(land1.land[i][p].second, land2.land[i][q].second)));
1046  ++p;
1047  ++q;
1048  }
1049  if (operation_on_pair_of_landscapesDBG) {
1050  std::cout << "Next iteration \n";
1051  }
1052  }
1053  while ((p + 1 < land1.land[i].size()) && (q + 1 >= land2.land[i].size())) {
1054  if (operation_on_pair_of_landscapesDBG) {
1055  std::cout << "New point : " << land1.land[i][p].first
1056  << " oper(land1.land[i][p].second,0) : " << oper(land1.land[i][p].second, 0) << std::endl;
1057  }
1058  lambda_n.push_back(std::make_pair(land1.land[i][p].first, oper(land1.land[i][p].second, 0)));
1059  ++p;
1060  }
1061  while ((p + 1 >= land1.land[i].size()) && (q + 1 < land2.land[i].size())) {
1062  if (operation_on_pair_of_landscapesDBG) {
1063  std::cout << "New point : " << land2.land[i][q].first
1064  << " oper(0,land2.land[i][q].second) : " << oper(0, land2.land[i][q].second) << std::endl;
1065  }
1066  lambda_n.push_back(std::make_pair(land2.land[i][q].first, oper(0, land2.land[i][q].second)));
1067  ++q;
1068  }
1069  lambda_n.push_back(std::make_pair(std::numeric_limits<int>::max(), 0));
1070  // CHANGE
1071  // result.land[i] = lambda_n;
1072  result.land[i].swap(lambda_n);
1073  }
1074  if (land1.land.size() > std::min(land1.land.size(), land2.land.size())) {
1075  if (operation_on_pair_of_landscapesDBG) {
1076  std::cout << "land1.land.size() > std::min( land1.land.size() , land2.land.size() )" << std::endl;
1077  }
1078  for (size_t i = std::min(land1.land.size(), land2.land.size()); i != std::max(land1.land.size(), land2.land.size());
1079  ++i) {
1080  std::vector<std::pair<double, double> > lambda_n(land1.land[i]);
1081  for (size_t nr = 0; nr != land1.land[i].size(); ++nr) {
1082  lambda_n[nr] = std::make_pair(land1.land[i][nr].first, oper(land1.land[i][nr].second, 0));
1083  }
1084  // CHANGE
1085  // result.land[i] = lambda_n;
1086  result.land[i].swap(lambda_n);
1087  }
1088  }
1089  if (land2.land.size() > std::min(land1.land.size(), land2.land.size())) {
1090  if (operation_on_pair_of_landscapesDBG) {
1091  std::cout << "( land2.land.size() > std::min( land1.land.size() , land2.land.size() ) ) " << std::endl;
1092  }
1093  for (size_t i = std::min(land1.land.size(), land2.land.size()); i != std::max(land1.land.size(), land2.land.size());
1094  ++i) {
1095  std::vector<std::pair<double, double> > lambda_n(land2.land[i]);
1096  for (size_t nr = 0; nr != land2.land[i].size(); ++nr) {
1097  lambda_n[nr] = std::make_pair(land2.land[i][nr].first, oper(0, land2.land[i][nr].second));
1098  }
1099  // CHANGE
1100  // result.land[i] = lambda_n;
1101  result.land[i].swap(lambda_n);
1102  }
1103  }
1104  if (operation_on_pair_of_landscapesDBG) {
1105  std::cout << "operation_on_pair_of_landscapes END\n";
1106  std::cin.ignore();
1107  }
1108  return result;
1109 } // operation_on_pair_of_landscapes
1110
1111 double compute_maximal_distance_non_symmetric(const Persistence_landscape& pl1, const Persistence_landscape& pl2) {
1112  bool dbg = false;
1113  if (dbg) std::cerr << " compute_maximal_distance_non_symmetric \n";
1114  // this distance is not symmetric. It compute ONLY distance between inflection points of pl1 and pl2.
1115  double maxDist = 0;
1116  size_t minimalNumberOfLevels = std::min(pl1.land.size(), pl2.land.size());
1117  for (size_t level = 0; level != minimalNumberOfLevels; ++level) {
1118  if (dbg) {
1119  std::cerr << "Level : " << level << std::endl;
1120  std::cerr << "PL1 : \n";
1121  for (size_t i = 0; i != pl1.land[level].size(); ++i) {
1122  std::cerr << "(" << pl1.land[level][i].first << "," << pl1.land[level][i].second << ") \n";
1123  }
1124  std::cerr << "PL2 : \n";
1125  for (size_t i = 0; i != pl2.land[level].size(); ++i) {
1126  std::cerr << "(" << pl2.land[level][i].first << "," << pl2.land[level][i].second << ") \n";
1127  }
1128  std::cin.ignore();
1129  }
1130
1131  int p2Count = 0;
1132  // In this case, I consider points at the infinity
1133  for (size_t i = 1; i != pl1.land[level].size() - 1; ++i) {
1134  while (true) {
1135  if ((pl1.land[level][i].first >= pl2.land[level][p2Count].first) &&
1136  (pl1.land[level][i].first <= pl2.land[level][p2Count + 1].first))
1137  break;
1138  p2Count++;
1139  }
1140  double val =
1141  fabs(function_value(pl2.land[level][p2Count], pl2.land[level][p2Count + 1], pl1.land[level][i].first) -
1142  pl1.land[level][i].second);
1143  if (maxDist <= val) maxDist = val;
1144
1145  if (dbg) {
1146  std::cerr << pl1.land[level][i].first << "in [" << pl2.land[level][p2Count].first << ","
1147  << pl2.land[level][p2Count + 1].first << "] \n";
1148  std::cerr << "pl1[level][i].second : " << pl1.land[level][i].second << std::endl;
1149  std::cerr << "function_value( pl2[level][p2Count] , pl2[level][p2Count+1] , pl1[level][i].first ) : "
1150  << function_value(pl2.land[level][p2Count], pl2.land[level][p2Count + 1], pl1.land[level][i].first)
1151  << std::endl;
1152  std::cerr << "val : " << val << std::endl;
1153  std::cin.ignore();
1154  }
1155  }
1156  }
1157
1158  if (dbg) std::cerr << "minimalNumberOfLevels : " << minimalNumberOfLevels << std::endl;
1159
1160  if (minimalNumberOfLevels < pl1.land.size()) {
1161  for (size_t level = minimalNumberOfLevels; level != pl1.land.size(); ++level) {
1162  for (size_t i = 0; i != pl1.land[level].size(); ++i) {
1163  if (dbg) std::cerr << "pl1[level][i].second : " << pl1.land[level][i].second << std::endl;
1164  if (maxDist < pl1.land[level][i].second) maxDist = pl1.land[level][i].second;
1165  }
1166  }
1167  }
1168  return maxDist;
1169 }
1170
1172  double p) {
1173  bool dbg = false;
1174  // This is what we want to compute: (\int_{- \infty}^{+\infty}| first-second |^p)^(1/p). We will do it one step at a
1175  // time:
1176
1177  // first-second :
1178  Persistence_landscape lan = first - second;
1179
1180  //| first-second |:
1181  lan = lan.abs();
1182
1183  if (dbg) {
1184  std::cerr << "Abs of difference ; " << lan << std::endl;
1185  getchar();
1186  }
1187
1188  if (p < std::numeric_limits<double>::max()) {
1189  // \int_{- \infty}^{+\infty}| first-second |^p
1190  double result;
1191  if (p != 1) {
1192  if (dbg) std::cerr << "Power != 1, compute integral to the power p\n";
1193  result = lan.compute_integral_of_landscape(p);
1194  } else {
1195  if (dbg) std::cerr << "Power = 1, compute integral \n";
1196  result = lan.compute_integral_of_landscape();
1197  }
1198  // (\int_{- \infty}^{+\infty}| first-second |^p)^(1/p)
1199  return pow(result, 1.0 / p);
1200  } else {
1201  // p == infty
1202  if (dbg) std::cerr << "Power = infty, compute maximum \n";
1203  return lan.compute_maximum();
1204  }
1205 }
1206
1208  const Persistence_landscape& second) {
1209  return std::max(compute_maximal_distance_non_symmetric(first, second),
1210  compute_maximal_distance_non_symmetric(second, first));
1211 }
1212
1213 bool comparePairsForMerging(std::pair<double, unsigned> first, std::pair<double, unsigned> second) {
1214  return (first.first < second.first);
1215 }
1216
1218  bool dbg = false;
1219  double result = 0;
1220
1221  for (size_t level = 0; level != std::min(l1.size(), l2.size()); ++level) {
1222  if (dbg) {
1223  std::cerr << "Computing inner product for a level : " << level << std::endl;
1224  getchar();
1225  }
1226  auto&& l1_land_level = l1.land[level];
1227  auto&& l2_land_level = l2.land[level];
1228
1229  if (l1_land_level.size() * l2_land_level.size() == 0) continue;
1230
1231  // endpoints of the interval on which we will compute the inner product of two locally linear functions:
1232  double x1 = -std::numeric_limits<int>::max();
1233  double x2;
1234  if (l1_land_level[1].first < l2_land_level[1].first) {
1235  x2 = l1_land_level[1].first;
1236  } else {
1237  x2 = l2_land_level[1].first;
1238  }
1239
1240  // iterators for the landscapes l1 and l2
1241  size_t l1It = 0;
1242  size_t l2It = 0;
1243
1244  while ((l1It < l1_land_level.size() - 1) && (l2It < l2_land_level.size() - 1)) {
1245  // compute the value of a inner product on a interval [x1,x2]
1246
1247  double a, b, c, d;
1248
1249  if (l1_land_level[l1It + 1].first != l1_land_level[l1It].first) {
1250  a = (l1_land_level[l1It + 1].second - l1_land_level[l1It].second) /
1251  (l1_land_level[l1It + 1].first - l1_land_level[l1It].first);
1252  } else {
1253  a = 0;
1254  }
1255  b = l1_land_level[l1It].second - a * l1_land_level[l1It].first;
1256  if (l2_land_level[l2It + 1].first != l2_land_level[l2It].first) {
1257  c = (l2_land_level[l2It + 1].second - l2_land_level[l2It].second) /
1258  (l2_land_level[l2It + 1].first - l2_land_level[l2It].first);
1259  } else {
1260  c = 0;
1261  }
1262  d = l2_land_level[l2It].second - c * l2_land_level[l2It].first;
1263
1264  double contributionFromThisPart = (a * c * x2 * x2 * x2 / 3 + (a * d + b * c) * x2 * x2 / 2 + b * d * x2) -
1265  (a * c * x1 * x1 * x1 / 3 + (a * d + b * c) * x1 * x1 / 2 + b * d * x1);
1266
1267  result += contributionFromThisPart;
1268
1269  if (dbg) {
1270  std::cerr << "[l1_land_level[l1It].first,l1_land_level[l1It+1].first] : " << l1_land_level[l1It].first
1271  << " , " << l1_land_level[l1It + 1].first << std::endl;
1272  std::cerr << "[l2_land_level[l2It].first,l2_land_level[l2It+1].first] : " << l2_land_level[l2It].first
1273  << " , " << l2_land_level[l2It + 1].first << std::endl;
1274  std::cerr << "a : " << a << ", b : " << b << " , c: " << c << ", d : " << d << std::endl;
1275  std::cerr << "x1 : " << x1 << " , x2 : " << x2 << std::endl;
1276  std::cerr << "contributionFromThisPart : " << contributionFromThisPart << std::endl;
1277  std::cerr << "result : " << result << std::endl;
1278  getchar();
1279  }
1280
1281  // we have two intervals in which functions are constant:
1282  // [l1_land_level[l1It].first , l1_land_level[l1It+1].first]
1283  // and
1284  // [l2_land_level[l2It].first , l2_land_level[l2It+1].first]
1285  // We also have an interval [x1,x2]. Since the intervals in the landscapes cover the whole R, then it is clear
1286  // that x2
1287  // is either l1_land_level[l1It+1].first of l2_land_level[l2It+1].first or both. Lets test it.
1288  if (x2 == l1_land_level[l1It + 1].first) {
1289  if (x2 == l2_land_level[l2It + 1].first) {
1290  // in this case, we increment both:
1291  ++l2It;
1292  if (dbg) {
1293  std::cerr << "Incrementing both \n";
1294  }
1295  } else {
1296  if (dbg) {
1297  std::cerr << "Incrementing first \n";
1298  }
1299  }
1300  ++l1It;
1301  } else {
1302  // in this case we increment l2It
1303  ++l2It;
1304  if (dbg) {
1305  std::cerr << "Incrementing second \n";
1306  }
1307  }
1308
1309  if ( l1It + 1 >= l1_land_level.size() )break;
1310  if ( l2It + 1 >= l2_land_level.size() )break;
1311
1312  // Now, we shift x1 and x2:
1313  x1 = x2;
1314  if (l1_land_level[l1It + 1].first < l2_land_level[l2It + 1].first) {
1315  x2 = l1_land_level[l1It + 1].first;
1316  } else {
1317  x2 = l2_land_level[l2It + 1].first;
1318  }
1319  }
1320  }
1321  return result;
1322 }
1323
1324 void Persistence_landscape::plot(const char* filename, double xRangeBegin, double xRangeEnd, double yRangeBegin,
1325  double yRangeEnd, int from, int to) {
1326  // this program create a gnuplot script file that allows to plot persistence diagram.
1327  std::ofstream out;
1328
1329  std::ostringstream gnuplot_script;
1330  gnuplot_script << filename << "_GnuplotScript";
1331  out.open(gnuplot_script.str().c_str());
1332
1333  if ((xRangeBegin != std::numeric_limits<double>::max()) || (xRangeEnd != std::numeric_limits<double>::max()) ||
1334  (yRangeBegin != std::numeric_limits<double>::max()) || (yRangeEnd != std::numeric_limits<double>::max())) {
1335  out << "set xrange [" << xRangeBegin << " : " << xRangeEnd << "]" << std::endl;
1336  out << "set yrange [" << yRangeBegin << " : " << yRangeEnd << "]" << std::endl;
1337  }
1338
1339  if (from == std::numeric_limits<int>::max()) {
1340  from = 0;
1341  }
1342  if (to == std::numeric_limits<int>::max()) {
1343  to = this->land.size();
1344  }
1345
1346  out << "plot ";
1347  for (size_t lambda = std::min((size_t)from, this->land.size()); lambda != std::min((size_t)to, this->land.size());
1348  ++lambda) {
1349  // out << " '-' using 1:2 title 'l" << lambda << "' with lp";
1350  out << " '-' using 1:2 notitle with lp";
1351  if (lambda + 1 != std::min((size_t)to, this->land.size())) {
1352  out << ", \\";
1353  }
1354  out << std::endl;
1355  }
1356
1357  for (size_t lambda = std::min((size_t)from, this->land.size()); lambda != std::min((size_t)to, this->land.size());
1358  ++lambda) {
1359  for (size_t i = 1; i != this->land[lambda].size() - 1; ++i) {
1360  out << this->land[lambda][i].first << " " << this->land[lambda][i].second << std::endl;
1361  }
1362  out << "EOF" << std::endl;
1363  }
1364  std::cout << "To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'"
1365  << gnuplot_script.str().c_str() << "\'\"" << std::endl;
1366 }
1367
1368 } // namespace Persistence_representations
1369 } // namespace Gudhi
1370
1371 #endif // PERSISTENCE_LANDSCAPE_H_
std::pair< double, double > get_y_range(size_t level=0) const
Definition: Persistence_landscape.h:422
Persistence_landscape operator+=(const Persistence_landscape &rhs)
Definition: Persistence_landscape.h:173
friend std::ostream & operator<<(std::ostream &out, Persistence_landscape &land)
Definition: Persistence_landscape.h:781
bool operator==(const Persistence_landscape &rhs) const
Definition: Persistence_landscape.h:472
friend Persistence_landscape subtract_two_landscapes(const Persistence_landscape &land1, const Persistence_landscape &land2)
Definition: Persistence_landscape.h:137
size_t size() const
Definition: Persistence_landscape.h:284
Definition: Persistence_landscape.h:257
Definition: Persistence_landscape.h:65
void print_to_file(const char *filename) const
Definition: Persistence_landscape.h:907
Definition: Persistence_landscape.h:672
void load_landscape_from_file(const char *filename)
Definition: Persistence_landscape.h:919
Definition: Persistence_landscape.h:336
Persistence_landscape abs()
Definition: Persistence_landscape.h:809
Definition: Persistence_landscape.h:314
double distance(const Persistence_landscape &second, double power=1) const
Definition: Persistence_landscape.h:400
Definition: SimplicialComplexForAlpha.h:14
A class implementing persistence landscapes data structures.
Definition: Persistence_landscape.h:60
void compute_average(const std::vector< Persistence_landscape *> &to_average)
Definition: Persistence_landscape.h:342
Definition: Persistence_landscape.h:651
friend double compute_distance_of_landscapes(const Persistence_landscape &first, const Persistence_landscape &second, double p)
Definition: Persistence_landscape.h:1171
double compute_scalar_product(const Persistence_landscape &second) const
Definition: Persistence_landscape.h:413
Definition: Persistence_landscape.h:306
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_landscape.h:320
bool operator!=(const Persistence_landscape &rhs) const
Definition: Persistence_landscape.h:212
Persistence_landscape operator/=(double x)
Definition: Persistence_landscape.h:198
friend Persistence_landscape operator+(const Persistence_landscape &first, const Persistence_landscape &second)
Definition: Persistence_landscape.h:145
friend Persistence_landscape operator*(double con, const Persistence_landscape &first)
Definition: Persistence_landscape.h:166
Definition: Persistence_landscape.h:660
Persistence_landscape operator*=(double x)
Definition: Persistence_landscape.h:190
friend double compute_inner_product(const Persistence_landscape &l1, const Persistence_landscape &l2)
Definition: Persistence_landscape.h:1217
Persistence_landscape operator-=(const Persistence_landscape &rhs)
Definition: Persistence_landscape.h:181
friend Persistence_landscape add_two_landscapes(const Persistence_landscape &land1, const Persistence_landscape &land2)
Definition: Persistence_landscape.h:129
Definition: Persistence_landscape.h:722
Definition: Persistence_landscape.h:217
friend double compute_max_norm_distance_of_landscapes(const Persistence_landscape &first, const Persistence_landscape &second)
Definition: Persistence_landscape.h:1207
friend Persistence_landscape operator*(const Persistence_landscape &first, double con)
Definition: Persistence_landscape.h:159
friend Persistence_landscape operator-(const Persistence_landscape &first, const Persistence_landscape &second)
Definition: Persistence_landscape.h:152
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
