Persistence_diagram.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author: François Godi
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
12 #define CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
13
14 namespace Gudhi {
15
16 namespace persistence_diagram {
17
25 struct DiagramPoint{};
26
33
34 } // namespace persistence_diagram
35
36 } // namespace Gudhi
37
38 #endif // CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
Concept of persistence diagram. It is a range of DiagramPoint. std::begin(diagram) and std::end(diagr...
Definition: Persistence_diagram.h:32
Definition: SimplicialComplexForAlpha.h:14
Concept of point in a persistence diagram. std::get<0>(point) must return the birth of the correspond...
Definition: Persistence_diagram.h:25
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
