#include <gudhi/Bottleneck.h>
#include <iostream>
#include <vector>
#include <utility>
#include <string>
#include <limits>
int main(int argc, char** argv) {
if (argc < 3) {
std::cout << "To run this program please provide as an input two files with persistence diagrams. Each file" <<
" should contain a birth-death pair per line. Third, optional parameter is an error bound on the bottleneck" <<
" distance (set by default to the smallest positive double value). If you set the error bound to 0, be" <<
" aware this version is exact but expensive. The program will now terminate \n";
return -1;
double tolerance = std::numeric_limits<double>::min();
if (argc == 4) {
tolerance = atof(argv[3]);
std::cout << "The distance between the diagrams is : " << b << ". The tolerance is : " << tolerance << std::endl;
return 0;
