#include <gudhi/Alpha_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epeck_d.h>
#include <iostream>
#include <vector>
using Kernel = CGAL::Epeck_d< CGAL::Dimension_tag<2> >;
using Point = Kernel::Point_d;
using Vector_of_points = std::vector<Point>;
int main() {
Vector_of_points points;
points.push_back(Point(1.0, 1.0));
points.push_back(Point(7.0, 0.0));
points.push_back(Point(4.0, 6.0));
points.push_back(Point(9.0, 6.0));
points.push_back(Point(0.0, 14.0));
points.push_back(Point(2.0, 19.0));
points.push_back(Point(9.0, 17.0));
std::cout <<
"Alpha complex is of dimension " << simplex.
dimension() <<
std::cout << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
std::cout << " ( ";
std::cout << vertex << " ";
std::cout <<
"[" << simplex.
filtration(f_simplex) <<
std::cout << std::endl;
return 0;
