Euclidean_strong_witness_complex.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Siargey Kachanovich
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL and Eigen3
9  * - YYYY/MM Author: Description of the modification
10  */
11
12 #ifndef EUCLIDEAN_STRONG_WITNESS_COMPLEX_H_
13 #define EUCLIDEAN_STRONG_WITNESS_COMPLEX_H_
14
15 #include <gudhi/Strong_witness_complex.h>
16 #include <gudhi/Active_witness/Active_witness.h>
17 #include <gudhi/Kd_tree_search.h>
18
19 #include <CGAL/version.h> // for CGAL_VERSION_NR
20
21 #include <Eigen/src/Core/util/Macros.h> // for EIGEN_VERSION_AT_LEAST
22
23 #include <utility>
24 #include <vector>
25
26 // Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
27 #if CGAL_VERSION_NR < 1041101000
28 # error Euclidean_strong_witness_complex is only available for CGAL >= 4.11
29 #endif
30
31 #if !EIGEN_VERSION_AT_LEAST(3,1,0)
32 # error Euclidean_strong_witness_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
33 #endif
34
35 namespace Gudhi {
36
37 namespace witness_complex {
38
48 template< class Kernel_ >
50  : public Strong_witness_complex<std::vector<typename Gudhi::spatial_searching::Kd_tree_search<Kernel_,
51  std::vector<typename Kernel_::Point_d>>::INS_range>> {
52  private:
53  typedef Kernel_ K;
54  typedef typename K::Point_d Point_d;
55  typedef std::vector<Point_d> Point_range;
57  typedef typename Kd_tree::INS_range Nearest_landmark_range;
58  typedef typename std::vector<Nearest_landmark_range> Nearest_landmark_table;
59
60  typedef typename Nearest_landmark_range::Point_with_transformed_distance Id_distance_pair;
61  typedef typename Id_distance_pair::first_type Landmark_id;
62  typedef Landmark_id Vertex_handle;
63
64  private:
65  Point_range landmarks_;
66  Kd_tree landmark_tree_;
68
69  public:
71  /* @name Constructor
72  */
73
75
82  template< typename LandmarkRange,
83  typename WitnessRange >
84  Euclidean_strong_witness_complex(const LandmarkRange & landmarks,
85  const WitnessRange & witnesses)
86  : landmarks_(std::begin(landmarks), std::end(landmarks)), landmark_tree_(landmarks_) {
87  nearest_landmark_table_.reserve(boost::size(witnesses));
88  for (auto w : witnesses)
89  nearest_landmark_table_.push_back(landmark_tree_.incremental_nearest_neighbors(w));
90  }
91
94  template <typename Vertex_handle>
95  Point_d get_point(Vertex_handle vertex) const {
96  return landmarks_[vertex];
97  }
98
100 };
101
102 } // namespace witness_complex
103
104 } // namespace Gudhi
105
106 #endif // EUCLIDEAN_STRONG_WITNESS_COMPLEX_H_
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:111
Definition: SimplicialComplexForAlpha.h:14
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:201
Constructs strong witness complex for given sets of witnesses and landmarks in Euclidean space...
Definition: Euclidean_strong_witness_complex.h:49
Returns the point corresponding to the given vertex.
Definition: Euclidean_strong_witness_complex.h:95
Euclidean_strong_witness_complex(const LandmarkRange &landmarks, const WitnessRange &witnesses)
Initializes member variables before constructing simplicial complex.
Definition: Euclidean_strong_witness_complex.h:84
Constructs strong witness complex for a given table of nearest landmarks with respect to witnesses...
Definition: Strong_witness_complex.h:40
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
