Alpha_complex_3d.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2018 Inria
6  *
7  * Modification(s):
8  * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL and Eigen3
9  * - YYYY/MM Author: Description of the modification
10  */
11
12 #ifndef ALPHA_COMPLEX_3D_H_
13 #define ALPHA_COMPLEX_3D_H_
14
15 #include <boost/version.hpp>
16 #include <boost/variant.hpp>
17
18 #include <gudhi/Debug_utils.h>
19 #include <gudhi/Alpha_complex_options.h>
20
21 #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
22 #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
23 #include <CGAL/Delaunay_triangulation_3.h>
24 #include <CGAL/Periodic_3_Delaunay_triangulation_traits_3.h>
25 #include <CGAL/Periodic_3_Delaunay_triangulation_3.h>
26 #include <CGAL/Periodic_3_regular_triangulation_traits_3.h>
27 #include <CGAL/Periodic_3_regular_triangulation_3.h>
28 #include <CGAL/Regular_triangulation_3.h>
29 #include <CGAL/Alpha_shape_3.h>
30 #include <CGAL/Alpha_shape_cell_base_3.h>
31 #include <CGAL/Alpha_shape_vertex_base_3.h>
32
33 #include <CGAL/Object.h>
34 #include <CGAL/tuple.h>
35 #include <CGAL/iterator.h>
36 #include <CGAL/version.h> // for CGAL_VERSION_NR
37
38 #include <Eigen/src/Core/util/Macros.h> // for EIGEN_VERSION_AT_LEAST
39
40 #include <boost/container/static_vector.hpp>
41
42 #include <iostream>
43 #include <vector>
44 #include <unordered_map>
45 #include <stdexcept>
46 #include <cstddef> // for std::size_t
47 #include <memory> // for std::unique_ptr
48 #include <type_traits> // for std::conditional and std::enable_if
49 #include <limits> // for numeric_limits<>
50
51 // Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
52 #if CGAL_VERSION_NR < 1041101000
53 # error Alpha_complex_3d is only available for CGAL >= 4.11
54 #endif
55
56 #if !EIGEN_VERSION_AT_LEAST(3,1,0)
57 # error Alpha_complex_3d is only available for Eigen3 >= 3.1.0 installed with CGAL
58 #endif
59
60 namespace Gudhi {
61
62 namespace alpha_complex {
63
64 #ifdef GUDHI_CAN_USE_CXX11_THREAD_LOCAL
65 thread_local
66 #endif // GUDHI_CAN_USE_CXX11_THREAD_LOCAL
67  double RELATIVE_PRECISION_OF_TO_DOUBLE = 0.00001;
68
69 // Value_from_iterator returns the filtration value from an iterator on alpha shapes values
70 //
71 // FAST SAFE EXACT
72 // CGAL::to_double(*iterator) CGAL::to_double(*iterator) CGAL::to_double(iterator->exact())
73
74 template <complexity Complexity>
75 struct Value_from_iterator {
76  template <typename Iterator>
77  static double perform(Iterator it) {
78  // Default behaviour
79  return CGAL::to_double(*it);
80  }
81 };
82
83 template <>
84 struct Value_from_iterator<complexity::EXACT> {
85  template <typename Iterator>
86  static double perform(Iterator it) {
87  return CGAL::to_double(it->exact());
88  }
89 };
90
126 template <complexity Complexity = complexity::SAFE, bool Weighted = false, bool Periodic = false>
128  // Epick = Exact_predicates_inexact_constructions_kernel
129  // Epeck = Exact_predicates_exact_constructions_kernel
130  // Exact_alpha_comparison_tag = exact version of CGAL Alpha_shape_3 and of its objects (Alpha_shape_vertex_base_3 and
131  // Alpha_shape_cell_base_3). Not available if weighted or periodic.
132  // Can be CGAL::Tag_false or CGAL::Tag_true. Default is False.
133  // cf. https://doc.cgal.org/latest/Alpha_shapes_3/classCGAL_1_1Alpha__shape__3.html
134  //
135  // We could use Epick + CGAL::Tag_true for not weighted nor periodic, but during benchmark, we found a bug
136  // https://github.com/CGAL/cgal/issues/3460
137  // This is the reason we only use Epick + CGAL::Tag_false, or Epeck
138  //
139  // FAST SAFE EXACT
140  // Epick + CGAL::Tag_false Epeck Epeck
141  using Predicates = typename std::conditional<(Complexity == complexity::FAST),
142  CGAL::Exact_predicates_inexact_constructions_kernel,
143  CGAL::Exact_predicates_exact_constructions_kernel>::type;
144
145  // The other way to do a conditional type. Here there are 3 possibilities
146  template <typename Predicates, bool Weighted_version, bool Periodic_version>
147  struct Kernel_3 {};
148
149  template <typename Predicates, bool Is_periodic>
150  struct Kernel_3<Predicates, Is_periodic, false> {
151  using Kernel = Predicates;
152  };
153
154  template <typename Predicates>
155  struct Kernel_3<Predicates, false, true> {
156  using Kernel = CGAL::Periodic_3_Delaunay_triangulation_traits_3<Predicates>;
157  };
158  template <typename Predicates>
159  struct Kernel_3<Predicates, true, true> {
160  using Kernel = CGAL::Periodic_3_regular_triangulation_traits_3<Predicates>;
161  };
162
163  using Kernel = typename Kernel_3<Predicates, Weighted, Periodic>::Kernel;
164
165  using TdsVb = typename std::conditional<Periodic, CGAL::Periodic_3_triangulation_ds_vertex_base_3<>,
166  CGAL::Triangulation_ds_vertex_base_3<>>::type;
167
168  using Tvb = typename std::conditional<Weighted, CGAL::Regular_triangulation_vertex_base_3<Kernel, TdsVb>,
169  CGAL::Triangulation_vertex_base_3<Kernel, TdsVb>>::type;
170
171  using Vb = CGAL::Alpha_shape_vertex_base_3<Kernel, Tvb>;
172
173  using TdsCb = typename std::conditional<Periodic, CGAL::Periodic_3_triangulation_ds_cell_base_3<>,
174  CGAL::Triangulation_ds_cell_base_3<>>::type;
175
176  using Tcb = typename std::conditional<Weighted, CGAL::Regular_triangulation_cell_base_3<Kernel, TdsCb>,
177  CGAL::Triangulation_cell_base_3<Kernel, TdsCb>>::type;
178
179  using Cb = CGAL::Alpha_shape_cell_base_3<Kernel, Tcb>;
180  using Tds = CGAL::Triangulation_data_structure_3<Vb, Cb>;
181
182  // The other way to do a conditional type. Here there 4 possibilities, cannot use std::conditional
183  template <typename Kernel, typename Tds, bool Weighted_version, bool Periodic_version>
184  struct Triangulation_3 {};
185
186  template <typename Kernel, typename Tds>
187  struct Triangulation_3<Kernel, Tds, false, false> {
188  using Dt = CGAL::Delaunay_triangulation_3<Kernel, Tds>;
189  using Weighted_point_3 = void;
190  };
191  template <typename Kernel, typename Tds>
192  struct Triangulation_3<Kernel, Tds, true, false> {
193  using Dt = CGAL::Regular_triangulation_3<Kernel, Tds>;
194  using Weighted_point_3 = typename Dt::Weighted_point;
195  };
196  template <typename Kernel, typename Tds>
197  struct Triangulation_3<Kernel, Tds, false, true> {
198  using Dt = CGAL::Periodic_3_Delaunay_triangulation_3<Kernel, Tds>;
199  using Weighted_point_3 = void;
200  };
201  template <typename Kernel, typename Tds>
202  struct Triangulation_3<Kernel, Tds, true, true> {
203  using Dt = CGAL::Periodic_3_regular_triangulation_3<Kernel, Tds>;
204  using Weighted_point_3 = typename Dt::Weighted_point;
205  };
206
214  using Dt = typename Triangulation_3<Kernel, Tds, Weighted, Periodic>::Dt;
215
216  public:
222  using Alpha_shape_3 = CGAL::Alpha_shape_3<Dt>;
223
226  using FT = typename Alpha_shape_3::FT;
227
237  using Bare_point_3 = typename Kernel::Point_3;
238
250  using Weighted_point_3 = typename Triangulation_3<Kernel, Tds, Weighted, Periodic>::Weighted_point_3;
251
255  using Point_3 = typename Alpha_shape_3::Point;
256
257  private:
258  using Dispatch =
259  CGAL::Dispatch_output_iterator<CGAL::cpp11::tuple<CGAL::Object, FT>,
260  CGAL::cpp11::tuple<std::back_insert_iterator<std::vector<CGAL::Object>>,
261  std::back_insert_iterator<std::vector<FT>>>>;
262
263  using Cell_handle = typename Alpha_shape_3::Cell_handle;
264  using Facet = typename Alpha_shape_3::Facet;
265  using Edge = typename Alpha_shape_3::Edge;
266  using Alpha_vertex_handle = typename Alpha_shape_3::Vertex_handle;
267  using Vertex_list = boost::container::static_vector<Alpha_vertex_handle, 4>;
268
269  public:
279  template <typename InputPointRange>
280  Alpha_complex_3d(const InputPointRange& points) {
281  static_assert(!Periodic, "This constructor is not available for periodic versions of Alpha_complex_3d");
282
283  alpha_shape_3_ptr_ = std::unique_ptr<Alpha_shape_3>(
284  new Alpha_shape_3(std::begin(points), std::end(points), 0, Alpha_shape_3::GENERAL));
285  }
286
301  template <typename InputPointRange, typename WeightRange>
302  Alpha_complex_3d(const InputPointRange& points, WeightRange weights) {
303  static_assert(Weighted, "This constructor is not available for non-weighted versions of Alpha_complex_3d");
304  static_assert(!Periodic, "This constructor is not available for periodic versions of Alpha_complex_3d");
305  GUDHI_CHECK((weights.size() == points.size()),
306  std::invalid_argument("Points number in range different from weights range number"));
307
308  std::vector<Weighted_point_3> weighted_points_3;
309
310  std::size_t index = 0;
311  weighted_points_3.reserve(points.size());
312  while ((index < weights.size()) && (index < points.size())) {
313  weighted_points_3.push_back(Weighted_point_3(points[index], weights[index]));
314  index++;
315  }
316
317  alpha_shape_3_ptr_ = std::unique_ptr<Alpha_shape_3>(
318  new Alpha_shape_3(std::begin(weighted_points_3), std::end(weighted_points_3), 0, Alpha_shape_3::GENERAL));
319  }
320
341  template <typename InputPointRange>
342  Alpha_complex_3d(const InputPointRange& points, FT x_min, FT y_min,
343  FT z_min, FT x_max, FT y_max, FT z_max) {
344  static_assert(Periodic, "This constructor is not available for non-periodic versions of Alpha_complex_3d");
345  // Checking if the cuboid is the same in x,y and z direction. If not, CGAL will not process it.
346  GUDHI_CHECK(
347  (x_max - x_min == y_max - y_min) && (x_max - x_min == z_max - z_min) && (z_max - z_min == y_max - y_min),
348  std::invalid_argument("The size of the cuboid in every directions is not the same."));
349
350  // Define the periodic cube
351  Dt pdt(typename Kernel::Iso_cuboid_3(x_min, y_min, z_min, x_max, y_max, z_max));
352  // Heuristic for inserting large point sets (if pts is reasonably large)
353  pdt.insert(std::begin(points), std::end(points), true);
354  // As pdt won't be modified anymore switch to 1-sheeted cover if possible
355  if (!pdt.is_triangulation_in_1_sheet()) {
356  throw std::invalid_argument("Unable to construct a triangulation within a single periodic domain.");
357  }
358  pdt.convert_to_1_sheeted_covering();
359
360  // alpha shape construction from points. CGAL has a strange behavior in REGULARIZED mode. This is the default mode
361  // Maybe need to set it to GENERAL mode
362  alpha_shape_3_ptr_ = std::unique_ptr<Alpha_shape_3>(new Alpha_shape_3(pdt, 0, Alpha_shape_3::GENERAL));
363  }
364
389  template <typename InputPointRange, typename WeightRange>
390  Alpha_complex_3d(const InputPointRange& points, WeightRange weights, FT x_min, FT y_min,
391  FT z_min, FT x_max, FT y_max, FT z_max) {
392  static_assert(Weighted, "This constructor is not available for non-weighted versions of Alpha_complex_3d");
393  static_assert(Periodic, "This constructor is not available for non-periodic versions of Alpha_complex_3d");
394  GUDHI_CHECK((weights.size() == points.size()),
395  std::invalid_argument("Points number in range different from weights range number"));
396  // Checking if the cuboid is the same in x,y and z direction. If not, CGAL will not process it.
397  GUDHI_CHECK(
398  (x_max - x_min == y_max - y_min) && (x_max - x_min == z_max - z_min) && (z_max - z_min == y_max - y_min),
399  std::invalid_argument("The size of the cuboid in every directions is not the same."));
400
401  std::vector<Weighted_point_3> weighted_points_3;
402
403  std::size_t index = 0;
404  weighted_points_3.reserve(points.size());
405
406 #ifdef GUDHI_DEBUG
407  // Defined in GUDHI_DEBUG to avoid unused variable warning for GUDHI_CHECK
408  FT maximal_possible_weight = 0.015625 * (x_max - x_min) * (x_max - x_min);
409 #endif
410
411  while ((index < weights.size()) && (index < points.size())) {
412  GUDHI_CHECK((weights[index] < maximal_possible_weight) && (weights[index] >= 0),
413  std::invalid_argument("Invalid weight at index " + std::to_string(index + 1) +
414  ". Must be positive and less than maximal possible weight = 1/64*cuboid length "
415  "squared, which is not an acceptable input."));
416  weighted_points_3.push_back(Weighted_point_3(points[index], weights[index]));
417  index++;
418  }
419
420  // Define the periodic cube
421  Dt pdt(typename Kernel::Iso_cuboid_3(x_min, y_min, z_min, x_max, y_max, z_max));
422  // Heuristic for inserting large point sets (if pts is reasonably large)
423  pdt.insert(std::begin(weighted_points_3), std::end(weighted_points_3), true);
424  // As pdt won't be modified anymore switch to 1-sheeted cover if possible
425  if (!pdt.is_triangulation_in_1_sheet()) {
426  throw std::invalid_argument("Unable to construct a triangulation within a single periodic domain.");
427  }
428  pdt.convert_to_1_sheeted_covering();
429
430  // alpha shape construction from points. CGAL has a strange behavior in REGULARIZED mode. This is the default mode
431  // Maybe need to set it to GENERAL mode
432  alpha_shape_3_ptr_ = std::unique_ptr<Alpha_shape_3>(new Alpha_shape_3(pdt, 0, Alpha_shape_3::GENERAL));
433  }
434
449  template <typename SimplicialComplexForAlpha3d,
451  bool create_complex(SimplicialComplexForAlpha3d& complex,
452  Filtration_value max_alpha_square = std::numeric_limits<Filtration_value>::infinity()) {
453  if (complex.num_vertices() > 0) {
454  std::cerr << "Alpha_complex_3d create_complex - complex is not empty\n";
455  return false; // ----- >>
456  }
457
458  using Complex_vertex_handle = typename SimplicialComplexForAlpha3d::Vertex_handle;
459  using Simplex_tree_vector_vertex = std::vector<Complex_vertex_handle>;
460
461 #ifdef DEBUG_TRACES
462  std::size_t count_vertices = 0;
463  std::size_t count_edges = 0;
464  std::size_t count_facets = 0;
465  std::size_t count_cells = 0;
466 #endif // DEBUG_TRACES
467  std::vector<CGAL::Object> objects;
468  std::vector<FT> alpha_values;
469
470  Dispatch dispatcher = CGAL::dispatch_output<CGAL::Object, FT>(std::back_inserter(objects),
471  std::back_inserter(alpha_values));
472
473  alpha_shape_3_ptr_->filtration_with_alpha_values(dispatcher);
474 #ifdef DEBUG_TRACES
475  std::cout << "filtration_with_alpha_values returns : " << objects.size() << " objects" << std::endl;
476 #endif // DEBUG_TRACES
477
478  using Alpha_value_iterator = typename std::vector<FT>::const_iterator;
479  Alpha_value_iterator alpha_value_iterator = alpha_values.begin();
480  for (auto object_iterator : objects) {
481  Vertex_list vertex_list;
482
483  // Retrieve Alpha shape vertex list from object
484  if (const Cell_handle* cell = CGAL::object_cast<Cell_handle>(&object_iterator)) {
485  for (auto i = 0; i < 4; i++) {
486 #ifdef DEBUG_TRACES
487  std::cout << "from cell[" << i << "] - Point coordinates (" << (*cell)->vertex(i)->point() << ")"
488  << std::endl;
489 #endif // DEBUG_TRACES
490  vertex_list.push_back((*cell)->vertex(i));
491  }
492 #ifdef DEBUG_TRACES
493  count_cells++;
494 #endif // DEBUG_TRACES
495  } else if (const Facet* facet = CGAL::object_cast<Facet>(&object_iterator)) {
496  for (auto i = 0; i < 4; i++) {
497  if ((*facet).second != i) {
498 #ifdef DEBUG_TRACES
499  std::cout << "from facet=[" << i << "] - Point coordinates (" << (*facet).first->vertex(i)->point() << ")"
500  << std::endl;
501 #endif // DEBUG_TRACES
502  vertex_list.push_back((*facet).first->vertex(i));
503  }
504  }
505 #ifdef DEBUG_TRACES
506  count_facets++;
507 #endif // DEBUG_TRACES
508  } else if (const Edge* edge = CGAL::object_cast<Edge>(&object_iterator)) {
509  for (auto i : {(*edge).second, (*edge).third}) {
510 #ifdef DEBUG_TRACES
511  std::cout << "from edge[" << i << "] - Point coordinates (" << (*edge).first->vertex(i)->point() << ")"
512  << std::endl;
513 #endif // DEBUG_TRACES
514  vertex_list.push_back((*edge).first->vertex(i));
515  }
516 #ifdef DEBUG_TRACES
517  count_edges++;
518 #endif // DEBUG_TRACES
519  } else if (const Alpha_vertex_handle* vertex = CGAL::object_cast<Alpha_vertex_handle>(&object_iterator)) {
520 #ifdef DEBUG_TRACES
521  count_vertices++;
522  std::cout << "from vertex - Point coordinates (" << (*vertex)->point() << ")" << std::endl;
523 #endif // DEBUG_TRACES
524  vertex_list.push_back((*vertex));
525  }
526  // Construction of the vector of simplex_tree vertex from list of alpha_shapes vertex
527  Simplex_tree_vector_vertex the_simplex;
528  for (auto the_alpha_shape_vertex : vertex_list) {
529  auto the_map_iterator = map_cgal_simplex_tree.find(the_alpha_shape_vertex);
530  if (the_map_iterator == map_cgal_simplex_tree.end()) {
531  // alpha shape not found
532  Complex_vertex_handle vertex = map_cgal_simplex_tree.size();
533 #ifdef DEBUG_TRACES
534  std::cout << "Point (" << the_alpha_shape_vertex->point() << ") not found - insert new vertex id " << vertex
535  << std::endl;
536 #endif // DEBUG_TRACES
537  the_simplex.push_back(vertex);
538  map_cgal_simplex_tree.emplace(the_alpha_shape_vertex, vertex);
539  } else {
540  // alpha shape found
541  Complex_vertex_handle vertex = the_map_iterator->second;
542 #ifdef DEBUG_TRACES
543  std::cout << "Point (" << the_alpha_shape_vertex->point() << ") found as vertex id " << vertex << std::endl;
544 #endif // DEBUG_TRACES
545  the_simplex.push_back(vertex);
546  }
547  }
548  // Construction of the simplex_tree
549  Filtration_value filtr = Value_from_iterator<Complexity>::perform(alpha_value_iterator);
550
551 #ifdef DEBUG_TRACES
552  std::cout << "filtration = " << filtr << std::endl;
553 #endif // DEBUG_TRACES
554  complex.insert_simplex(the_simplex, static_cast<Filtration_value>(filtr));
555  GUDHI_CHECK(alpha_value_iterator != alpha_values.end(), "CGAL provided more simplices than values");
556  ++alpha_value_iterator;
557  }
558
559 #ifdef DEBUG_TRACES
560  std::cout << "vertices \t" << count_vertices << std::endl;
561  std::cout << "edges \t\t" << count_edges << std::endl;
562  std::cout << "facets \t\t" << count_facets << std::endl;
563  std::cout << "cells \t\t" << count_cells << std::endl;
564 #endif // DEBUG_TRACES
565  // --------------------------------------------------------------------------------------------
566  // As Alpha value is an approximation, we have to make filtration non decreasing while increasing the dimension
568  // Remove all simplices that have a filtration value greater than max_alpha_square
569  complex.prune_above_filtration(max_alpha_square);
570  // --------------------------------------------------------------------------------------------
571  return true;
572  }
573
580  const Point_3& get_point(std::size_t vertex) {
581  if (map_cgal_simplex_tree.size() != cgal_vertex_iterator_vector.size()) {
582  cgal_vertex_iterator_vector.resize(map_cgal_simplex_tree.size());
583  for (auto map_iterator : map_cgal_simplex_tree) {
584  cgal_vertex_iterator_vector[map_iterator.second] = map_iterator.first;
585  }
586
587  }
588  auto cgal_vertex_iterator = cgal_vertex_iterator_vector.at(vertex);
589  return cgal_vertex_iterator->point();
590  }
591
592  private:
593  // use of a unique_ptr on cgal Alpha_shape_3, as copy and default constructor is not available - no need to be freed
594  std::unique_ptr<Alpha_shape_3> alpha_shape_3_ptr_;
595
596  // Map type to switch from CGAL vertex iterator to simplex tree vertex handle.
597  std::unordered_map<Alpha_vertex_handle, std::size_t> map_cgal_simplex_tree;
598  // Vector type to switch from simplex tree vertex handle to CGAL vertex iterator.
599  std::vector<Alpha_vertex_handle> cgal_vertex_iterator_vector;
600 };
601
602 } // namespace alpha_complex
603
604 } // namespace Gudhi
605
606 #endif // ALPHA_COMPLEX_3D_H_
bool create_complex(SimplicialComplexForAlpha3d &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity())
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex_3d.h:451
const Point_3 & get_point(std::size_t vertex)
get_point returns the point corresponding to the vertex given as parameter.
Definition: Alpha_complex_3d.h:580
Alpha_complex_3d(const InputPointRange &points, FT x_min, FT y_min, FT z_min, FT x_max, FT y_max, FT z_max)
Alpha_complex constructor from a list of points and an iso-cuboid coordinates.
Definition: Alpha_complex_3d.h:342
Alpha_complex_3d(const InputPointRange &points, WeightRange weights, FT x_min, FT y_min, FT z_min, FT x_max, FT y_max, FT z_max)
Alpha_complex constructor from a list of points, associated weights and an iso-cuboid coordinates...
Definition: Alpha_complex_3d.h:390
Alpha complex data structure for 3d specific case.
Definition: Alpha_complex_3d.h:127
typename Alpha_shape_3::Point Point_3
Alpha_complex_3d::Point_3 type is either a Alpha_complex_3d::Bare_point_3 (Weighted = false) or a Alp...
Definition: Alpha_complex_3d.h:255
Alpha_complex_3d(const InputPointRange &points, WeightRange weights)
Alpha_complex constructor from a list of points and associated weights.
Definition: Alpha_complex_3d.h:302
Definition: SimplicialComplexForAlpha.h:14
typename Triangulation_3< Kernel, Tds, Weighted, Periodic >::Weighted_point_3 Weighted_point_3
Gives public access to the Weighted_point_3 type. A Weighted point can be constructed as follows: ...
Definition: Alpha_complex_3d.h:250
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
void prune_above_filtration(Filtration_value filtration)
The concept SimplicialComplexForAlpha3d describes the requirements for a type to implement a simplici...
Definition: SimplicialComplexForAlpha3d.h:21
CGAL::Alpha_shape_3< Dt > Alpha_shape_3
The CGAL 3D Alpha Shapes type.
Definition: Alpha_complex_3d.h:222
Alpha_complex_3d(const InputPointRange &points)
Alpha_complex constructor from a list of points.
Definition: Alpha_complex_3d.h:280
unspecified Filtration_value
Definition: SimplicialComplexForAlpha3d.h:25
typename Alpha_shape_3::FT FT
The alpha values type. Must be compatible with double.
Definition: Alpha_complex_3d.h:226
complexity
Alpha complex complexity template parameter possible values.
Definition: Alpha_complex_options.h:23
void insert_simplex(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex from a given simplex (represented by a vector of Vertex_handle) in the simplicial c...
unspecified Vertex_handle
Definition: SimplicialComplexForAlpha3d.h:23
typename Kernel::Point_3 Bare_point_3
Gives public access to the Bare_point_3 (bare aka. unweighed) type. Here is a Bare_point_3 constructo...
Definition: Alpha_complex_3d.h:237
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
