Gudhi::Persistence_representations::squared_distance_from_diagonal_scaling Class Reference
Detailed Description
This is one of a scaling functions used to weight points depending on their persistence and/or location in the diagram. The scaling given by this function to a point (b,d) is a square of Euclidean distance of (b,d) from diagonal.
Examples:
Persistence_representations/persistence_heat_maps/create_p_h_m_weighted_by_squared_diag_distance.cpp.
The documentation for this class was generated from the following file:
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13
