#include <gudhi/Tangential_complex.h>
#include <gudhi/sparsify_point_set.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Random.h>
#include <array>
#include <vector>
typedef CGAL::Epick_d<CGAL::Dimension_tag < 3 >> Kernel;
typedef Kernel::FT FT;
typedef Kernel::Point_d Point;
typedef Kernel::Vector_d Vector;
typedef tc::Tangential_complex<
Kernel, CGAL::Dimension_tag<2>,
CGAL::Parallel_tag> TC;
int main(void) {
  const int INTRINSIC_DIM = 2;
  const int AMBIENT_DIM = 3;
  const int NUM_POINTS = 50;
  Kernel k;
  CGAL::Random_points_on_sphere_d<Point> generator(AMBIENT_DIM, 3.);
  std::vector<Point> points;
  points.reserve(NUM_POINTS);
  for (int i = 0; i < NUM_POINTS; ++i)
    points.push_back(*generator++);
  std::vector<Point> sparsified_points;
                               std::back_inserter(sparsified_points));
  sparsified_points.swap(points);
  TC tc(points, INTRINSIC_DIM, k);
  tc.compute_tangential_complex();
  tc.fix_inconsistencies_using_perturbation(0.05, 10);
  tc.create_complex(stree);
  return 0;
