Skeleton_blocker_simple_traits.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): David Salinas
4  *
5  * Copyright (C) 2014 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLE_TRAITS_H_
12 #define SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLE_TRAITS_H_
13
14 #include <gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h>
15
16 #include <string>
17 #include <sstream>
18
19 namespace Gudhi {
20
21 namespace skeleton_blocker {
22
39  typedef int boost_vertex_handle;
40
41  explicit Root_vertex_handle(boost_vertex_handle val = -1)
42  : vertex(val) { }
43  boost_vertex_handle vertex;
44
45  bool operator!=(const Root_vertex_handle& other) const {
46  return !(this->vertex == other.vertex);
47  }
48
49  bool operator==(const Root_vertex_handle& other) const {
50  return this->vertex == other.vertex;
51  }
52
53  bool operator<(const Root_vertex_handle& other) const {
54  return this->vertex < other.vertex;
55  }
56
57  friend std::ostream& operator<<(std::ostream& o,
58  const Root_vertex_handle & v) {
59  o << v.vertex;
60  return o;
61  }
62  };
63
64  struct Vertex_handle {
65  typedef int boost_vertex_handle;
66
67  explicit Vertex_handle(boost_vertex_handle val = -1)
68  : vertex(val) { }
69
70  operator int() const {
71  return static_cast<int> (vertex);
72  }
73
74  boost_vertex_handle vertex;
75
76  bool operator==(const Vertex_handle& other) const {
77  return this->vertex == other.vertex;
78  }
79
80  bool operator!=(const Vertex_handle& other) const {
81  return this->vertex != other.vertex;
82  }
83
84  bool operator<(const Vertex_handle& other) const {
85  return this->vertex < other.vertex;
86  }
87
88  friend std::ostream& operator<<(std::ostream& o, const Vertex_handle & v) {
89  o << v.vertex;
90  return o;
91  }
92  };
93
94  class Graph_vertex {
95  bool is_active_;
97
98  public:
99  virtual ~Graph_vertex() { }
100
101  void activate() {
102  is_active_ = true;
103  }
104
105  void deactivate() {
106  is_active_ = false;
107  }
108
109  bool is_active() const {
110  return is_active_;
111  }
112
113  void set_id(Root_vertex_handle i) {
114  id_ = i;
115  }
116
117  Root_vertex_handle get_id() const {
118  return id_;
119  }
120
121  virtual std::string to_string() const {
122  std::ostringstream res;
123  res << id_;
124  return res.str();
125  }
126
127  friend std::ostream& operator<<(std::ostream& o, const Graph_vertex & v) {
128  o << v.to_string();
129  return o;
130  }
131  };
132
133  class Graph_edge {
136  int index_;
137
138  public:
139  Graph_edge()
140  : a_(-1),
141  b_(-1),
142  index_(-1) { }
143
144  int& index() {
145  return index_;
146  }
147
148  int index() const {
149  return index_;
150  }
151
152  void setId(Root_vertex_handle a, Root_vertex_handle b) {
153  a_ = a;
154  b_ = b;
155  }
156
157  Root_vertex_handle first() const {
158  return a_;
159  }
160
161  Root_vertex_handle second() const {
162  return b_;
163  }
164
165  friend std::ostream& operator<<(std::ostream& o, const Graph_edge & v) {
166  o << "(" << v.a_ << "," << v.b_ << " - id = " << v.index();
167  return o;
168  }
169  };
170 };
171
172 } // namespace skeleton_blocker
173
174 namespace skbl = skeleton_blocker;
175
176 } // namespace Gudhi
177
178 #endif // SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLE_TRAITS_H_
Definition: SimplicialComplexForAlpha.h:14
Global and local handle similar to boost subgraphs. Vertices are stored in a vector. For the root simplicial complex, the local and global descriptors are the same. For a subcomplex L and one of its vertices &#39;v&#39;, the local descriptor of &#39;v&#39; is its position in the vertex vector of the subcomplex L whereas its global descriptor is the position of &#39;v&#39; in the vertex vector of the root simplicial complex.
Definition: Skeleton_blocker_simple_traits.h:38
Simple traits that is a model of SkeletonBlockerDS and can be passed as a template argument to Skelet...
Definition: Skeleton_blocker_simple_traits.h:29
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13
