11 #ifndef SIMPLEX_TREE_H_    12 #define SIMPLEX_TREE_H_    14 #include <gudhi/Simplex_tree/Simplex_tree_node_explicit_storage.h>    15 #include <gudhi/Simplex_tree/Simplex_tree_siblings.h>    16 #include <gudhi/Simplex_tree/Simplex_tree_iterators.h>    17 #include <gudhi/Simplex_tree/indexing_tag.h>    20 #include <gudhi/graph_simplicial_complex.h>    21 #include <gudhi/Debug_utils.h>    23 #include <boost/container/flat_map.hpp>    24 #include <boost/iterator/transform_iterator.hpp>    25 #include <boost/graph/adjacency_list.hpp>    26 #include <boost/range/adaptor/reversed.hpp>    29 #include <tbb/parallel_sort.h>    37 #include <initializer_list>    44 struct Simplex_tree_options_full_featured;
    59 template<
typename SimplexTreeOptions = Simplex_tree_options_full_featured>
    78   typedef Simplex_tree_node_explicit_storage<Simplex_tree> Node;
    83   typedef typename boost::container::flat_map<Vertex_handle, Node> Dictionary;
    87   typedef Simplex_tree_siblings<Simplex_tree, Dictionary> Siblings;
    89   struct Key_simplex_base_real {
    90     Key_simplex_base_real() : key_(-1) {}
    92     Simplex_key
key()
 const {
return key_; }
    96   struct Key_simplex_base_dummy {
    97     Key_simplex_base_dummy() {}
   100     Simplex_key
key()
const;
   102   typedef typename std::conditional<Options::store_key, Key_simplex_base_real, Key_simplex_base_dummy>::type
   105   struct Filtration_simplex_base_real {
   106     Filtration_simplex_base_real() : filt_(0) {}
   108     Filtration_value
filtration()
 const {
return filt_; }
   110     Filtration_value filt_;
   112   struct Filtration_simplex_base_dummy {
   113     Filtration_simplex_base_dummy() {}
   114     void assign_filtration(Filtration_value GUDHI_CHECK_code(f)) { GUDHI_CHECK(f == 0,
"filtration value specified for a complex that does not store them"); }
   115     Filtration_value
filtration()
 const {
return 0; }
   118     Filtration_simplex_base_dummy>::type Filtration_simplex_base;
   126   typedef typename Dictionary::iterator Dictionary_it;
   127   typedef typename Dictionary_it::value_type Dit_value_t;
   129   struct return_first {
   130     Vertex_handle operator()(
const Dit_value_t& p_sh)
 const {
   193                                 boost::make_transform_iterator(root_.members_.begin(), return_first()),
   194                                 boost::make_transform_iterator(root_.members_.end(), return_first()));
   237     if (filtration_vect_.empty()) {
   240     return filtration_vect_;
   269   template<
class SimplexHandle>
   282       root_(nullptr, null_vertex_),
   289     std::cout <<
"Simplex_tree copy constructor" << std::endl;
   290 #endif  // DEBUG_TRACES   291     copy_from(complex_source);
   299     std::cout <<
"Simplex_tree move constructor" << std::endl;
   300 #endif  // DEBUG_TRACES   301     move_from(complex_source);
   305     complex_source.dimension_ = -1;
   310     root_members_recursive_deletion();
   316     std::cout <<
"Simplex_tree copy assignment" << std::endl;
   317 #endif  // DEBUG_TRACES   319     if (&complex_source !=
this) {
   321       root_members_recursive_deletion();
   323       copy_from(complex_source);
   333     std::cout <<
"Simplex_tree move assignment" << std::endl;
   334 #endif  // DEBUG_TRACES   336     if (&complex_source !=
this) {
   338       root_members_recursive_deletion();
   340       move_from(complex_source);
   349     null_vertex_ = complex_source.null_vertex_;
   350     filtration_vect_.clear();
   351     dimension_ = complex_source.dimension_;
   352     auto root_source = complex_source.root_;
   355     root_.members() = Dictionary(boost::container::ordered_unique_range, root_source.members().begin(), root_source.members().end());
   357     for (
auto& map_el : root_.members()) {
   358       map_el.second.assign_children(&root_);
   360     rec_copy(&root_, &root_source);
   364   void rec_copy(Siblings *sib, Siblings *sib_source) {
   365     for (
auto sh = sib->members().begin(), sh_source = sib_source->members().begin();
   366          sh != sib->members().end(); ++sh, ++sh_source) {
   368         Siblings * newsib =
new Siblings(sib, sh_source->first);
   369         newsib->members_.reserve(sh_source->second.children()->members().size());
   370         for (
auto & child : sh_source->second.children()->members())
   371           newsib->members_.emplace_hint(newsib->members_.end(), child.first, Node(newsib, child.second.filtration()));
   372         rec_copy(newsib, sh_source->second.children());
   373         sh->second.assign_children(newsib);
   380     null_vertex_ = std::move(complex_source.null_vertex_);
   381     root_ = std::move(complex_source.root_);
   382     filtration_vect_ = std::move(complex_source.filtration_vect_);
   383     dimension_ = std::move(complex_source.dimension_);
   386     for (
   387       if (map_el.second.children() != &(complex_source.root_)) {
   389         map_el.second.children()->oncles_ = &root_;
   392         GUDHI_CHECK(map_el.second.children()->oncles_ ==
nullptr,
   393                     std::invalid_argument(
"Simplex_tree move constructor from an invalid Simplex_tree"));
   395         map_el.second.assign_children(&root_);
   401   void root_members_recursive_deletion() {
   402     for (
auto sh = root_.members().begin(); sh != root_.members().end(); ++sh) {
   404         rec_delete(sh->second.children());
   407     root_.members().clear();
   411   void rec_delete(Siblings * sib) {
   412     for (
auto sh = sib->members().begin(); sh != sib->members().end(); ++sh) {
   414         rec_delete(sh->second.children());
   423     if ((null_vertex_ != st2.null_vertex_) ||
   424         (dimension_ != st2.dimension_))
   426     return rec_equal(&root_, &st2.root_);
   431     return (!(*
this == st2));
   436   bool rec_equal(Siblings* s1, Siblings* s2) {
   437     if (s1->members().size() != s2->members().size())
   439     for (
auto sh1 = s1->members().begin(), sh2 = s2->members().begin();
   440          (sh1 != s1->members().end() && sh2 != s2->members().end()); ++sh1, ++sh2) {
   441       if (sh1->first != sh2->first || sh1->second.filtration() != sh2->second.filtration())
   447         if (!rec_equal(sh1->second.children(), sh2->second.children()))
   459   static Simplex_key
key(Simplex_handle sh) {
   460     return sh->second.key();
   468   Simplex_handle
simplex(Simplex_key idx)
 const {
   469     return filtration_vect_[idx];
   479       return sh->second.filtration();
   481       return std::numeric_limits<Filtration_value>::infinity();
   490                 std::invalid_argument(
"Simplex_tree::assign_filtration - cannot assign filtration on null_simplex"));
   491     sh->second.assign_filtration(fv);
   499     return Dictionary_it(
nullptr);
   516     return root_.members_.size();
   528     auto sib_begin = sib->members().begin();
   529     auto sib_end = sib->members().end();
   530     size_t simplices_number = sib_end - sib_begin;
   531     for (
auto sh = sib_begin; sh != sib_end; ++sh) {
   536     return simplices_number;
   546     while (curr_sib !=
nullptr) {
   548       curr_sib = curr_sib->oncles();
   563     if (dimension_to_be_lowered_)
   564       lower_upper_bound_dimension();
   570   template<
   573     return (sh->second.children()->parent() == sh->first);
   583   template<
class InputVertexRange = std::initializer_list<Vertex_handle>>
   584   Simplex_handle
find(
const InputVertexRange & s) {
   585     auto first = std::begin(s);
   586     auto last = std::end(s);
   592     std::vector<Vertex_handle> copy(first, last);
   593     std::sort(std::begin(copy), std::end(copy));
   594     return find_simplex(copy);
   599   Simplex_handle find_simplex(
const std::vector<Vertex_handle> &
simplex) {
   600     Siblings * tmp_sib = &root_;
   601     Dictionary_it tmp_dit;
   602     auto vi = simplex.begin();
   605       GUDHI_CHECK(contiguous_vertices(),
"non-contiguous vertices");
   606       Vertex_handle v = *vi++;
   607       if(v < 0 || v >= static_cast<Vertex_handle>(root_.members_.size()))
   609       tmp_dit = root_.members_.begin() + v;
   610       if (vi == simplex.end())
   614       tmp_sib = tmp_dit->second.children();
   617       tmp_dit = tmp_sib->members_.find(*vi++);
   618       if (tmp_dit == tmp_sib->members_.end())
   620       if (vi == simplex.end())
   624       tmp_sib = tmp_dit->second.children();
   630   Simplex_handle find_vertex(Vertex_handle v) {
   632       assert(contiguous_vertices());
   633       return root_.members_.begin() + v;
   635       return root_.members_.find(v);
   641   bool contiguous_vertices()
 const {
   642     if (root_.members_.empty())
return true;
   643     if (root_.members_.begin()->first != 0)
return false;
   644     if (std::prev(root_.members_.end())->first != static_cast<Vertex_handle>(root_.members_.size() - 1))
return false;
   663   std::pair<Simplex_handle, bool> insert_vertex_vector(
const std::vector<Vertex_handle>& simplex,
   665     Siblings * curr_sib = &root_;
   666     std::pair<Simplex_handle, bool> res_insert;
   667     auto vi = simplex.begin();
   668     for (; vi != simplex.end() - 1; ++vi) {
   669       GUDHI_CHECK(*vi !=
null_vertex(),
"cannot use the dummy null_vertex() as a real vertex");
   670       res_insert = curr_sib->members_.emplace(*vi, Node(curr_sib, filtration));
   672         res_insert.first->second.assign_children(
new Siblings(curr_sib, *vi));
   674       curr_sib = res_insert.first->second.children();
   676     GUDHI_CHECK(*vi !=
null_vertex(),
   677     res_insert = curr_sib->members_.emplace(*vi, Node(curr_sib, filtration));
   678     if (!res_insert.second) {
   680       if (res_insert.first->second.filtration() >
filtration) {
   682         res_insert.first->second.assign_filtration(filtration);
   686       return std::pair<Simplex_handle, bool>(
null_simplex(),
false);
   689     if (static_cast<int>(simplex.size()) - 1 > dimension_) {
   691       dimension_ =
static_cast<int>(simplex.size()) - 1;
   720   template<
   722                                                  Filtration_value filtration = 0) {
   723     auto first = std::begin(simplex);
   724     auto last = std::end(simplex);
   727       return std::pair<Simplex_handle, bool>(
null_simplex(),
true);
   730     std::vector<Vertex_handle> copy(first, last);
   731     std::sort(std::begin(copy), std::end(copy));
   732     return insert_vertex_vector(copy, filtration);
   749   template<
   751             Filtration_value filtration = 0) {
   752     auto first = std::begin(Nsimplex);
   753     auto last = std::end(Nsimplex);
   760 #ifdef GUDHI_CAN_USE_CXX11_THREAD_LOCAL   762 #endif  // GUDHI_CAN_USE_CXX11_THREAD_LOCAL   763     std::vector<Vertex_handle> copy;
   765     copy.insert(copy.end(), first, last);
   766     std::sort(copy.begin(), copy.end());
   767     auto last_unique = std::unique(copy.begin(), copy.end());
   768     copy.erase(last_unique, copy.end());
   770       for (Vertex_handle v : copy)
   771         GUDHI_CHECK(v !=
null_vertex(),
   774     dimension_ = (std::max)(dimension_,
static_cast<int>(std::distance(copy.begin(), copy.end())) - 1);
   776     return rec_insert_simplex_and_subfaces_sorted(
root(), copy.begin(), copy.end(),
filtration);
   781   template<
class ForwardVertexIterator>
   782   std::pair<Simplex_handle, bool> rec_insert_simplex_and_subfaces_sorted(Siblings* sib,
   783        ForwardVertexIterator first,
   784        ForwardVertexIterator last,
   785        Filtration_value filt) {
   790     Vertex_handle vertex_one = *first;
   791     auto&& dict = sib->members();
   792     auto insertion_result = dict.emplace(vertex_one, Node(sib, filt));
   793     Simplex_handle simplex_one = insertion_result.first;
   794     bool one_is_new = insertion_result.second;
   803     if (++first == last)
return insertion_result;
   806       simplex_one->second.assign_children(
new Siblings(sib, vertex_one));
   807     auto res = rec_insert_simplex_and_subfaces_sorted(simplex_one->second.children(), first, last, filt);
   809     if (res.first !=
null_simplex()) rec_insert_simplex_and_subfaces_sorted(sib, first, last, filt);
   817     sh->second.assign_key(key);
   823   std::pair<Simplex_handle, Simplex_handle>
endpoints(Simplex_handle sh) {
   825     return { find_vertex(sh->first), find_vertex(
self_siblings(sh)->parent()) };
   829   template<
   831     if (sh->second.children()->parent() == sh->first)
   832       return sh->second.children()->oncles();
   834       return sh->second.children();
   848     dimension_to_be_lowered_ =
false;
   863     filtration_vect_.clear();
   866       filtration_vect_.push_back(sh);
   878     tbb::parallel_sort(filtration_vect_.begin(), filtration_vect_.end(), is_before_in_filtration(
this));
   880     std::stable_sort(filtration_vect_.begin(), filtration_vect_.end(), is_before_in_filtration(
this));
   897   void rec_coface(std::vector<Vertex_handle> &vertices, Siblings *curr_sib,
int curr_nbVertices,
   898                   std::vector<Simplex_handle>& cofaces,
bool star,
int nbVertices) {
   899     if (!(star || curr_nbVertices <= nbVertices))
   901     for (Simplex_handle simplex = curr_sib->members().begin(); simplex != curr_sib->members().end(); ++
simplex) {
   902       if (vertices.empty()) {
   907         bool addCoface = (star || curr_nbVertices == nbVertices);
   909           cofaces.push_back(simplex);
   911           rec_coface(vertices, simplex->second.children(), curr_nbVertices + 1, cofaces, star, nbVertices);
   913         if (simplex->first == vertices.back()) {
   915           bool equalDim = (star || curr_nbVertices == nbVertices);
   916           bool addCoface = vertices.size() == 1 && equalDim;
   918             cofaces.push_back(simplex);
   921             Vertex_handle tmp = vertices.back();
   923             rec_coface(vertices, simplex->second.children(), curr_nbVertices + 1, cofaces, star, nbVertices);
   924             vertices.push_back(tmp);
   926         }
else if (simplex->first > vertices.back()) {
   931             rec_coface(vertices, simplex->second.children(), curr_nbVertices + 1, cofaces, star, nbVertices);
   955     Cofaces_simplex_range cofaces;
   957     assert(codimension >= 0);
   959     std::vector<Vertex_handle> copy(rg.begin(), rg.end());
   960     if (codimension + static_cast<int>(copy.size()) > dimension_ + 1 ||
   961         (codimension == 0 && static_cast<int>(copy.size()) > dimension_))
   964     assert(std::is_sorted(copy.begin(), copy.end(), std::greater<Vertex_handle>()));
   965     bool star = codimension == 0;
   966     rec_coface(copy, &root_, 1, cofaces, star, codimension + static_cast<int>(copy.size()));
   978   bool reverse_lexicographic_order(Simplex_handle sh1, Simplex_handle sh2) {
   981     Simplex_vertex_iterator it1 = rg1.begin();
   982     Simplex_vertex_iterator it2 = rg2.begin();
   983     while (it1 != rg1.end() && it2 != rg2.end()) {
   991     return ((it1 == rg1.end()) && (it2 != rg2.end()));
  1000   struct is_before_in_filtration {
  1004     bool operator()(
const Simplex_handle sh1,
const Simplex_handle sh2)
 const {
  1006       if (sh1->second.filtration() != sh2->second.filtration()) {
  1007         return sh1->second.filtration() < sh2->second.filtration();
  1010       return st_->reverse_lexicographic_order(sh1, sh2);
  1040   template<
class OneSkeletonGraph>
  1045     if (boost::num_vertices(skel_graph) == 0) {
  1048     if (num_edges(skel_graph) == 0) {
  1054     root_.members_.reserve(boost::num_vertices(skel_graph));
  1056     typename boost::graph_traits<OneSkeletonGraph>::vertex_iterator v_it,
  1058     for (std::tie(v_it, v_it_end) = boost::vertices(skel_graph); v_it != v_it_end;
  1060       root_.members_.emplace_hint(
  1061                                   root_.members_.end(), *v_it,
  1062                                   Node(&root_, boost::get(vertex_filtration_t(), skel_graph, *v_it)));
  1064     std::pair<typename boost::graph_traits<OneSkeletonGraph>::edge_iterator,
  1065               typename boost::graph_traits<OneSkeletonGraph>::edge_iterator> boost_edges = boost::edges(skel_graph);
  1068     for (; boost_edges.first != boost_edges.second; boost_edges.first++) {
  1069       auto edge = *(boost_edges.first);
  1070       auto u = source(edge, skel_graph);
  1071       auto v = target(edge, skel_graph);
  1072       if (u == v)
throw "Self-loops are not simplicial";
  1080       if (v < u) std::swap(u, v);
  1081       auto sh = find_vertex(u);
  1083         sh->second.assign_children(
new Siblings(&root_, sh->first));
  1086       sh->second.children()->members().emplace(v,
  1087           Node(sh->second.children(), boost::get(edge_filtration_t(), skel_graph, edge)));
  1103     if (max_dim <= 1)
return;
  1104     dimension_ = max_dim;
  1105     for (Dictionary_it root_it = root_.members_.begin();
  1106          root_it != root_.members_.end(); ++root_it) {
  1108         siblings_expansion(root_it->second.children(), max_dim - 1);
  1111     dimension_ = max_dim - dimension_;
  1116   void siblings_expansion(Siblings * siblings,
  1118     if (dimension_ > k) {
  1123     Dictionary_it next = siblings->members().begin();
  1126 #ifdef GUDHI_CAN_USE_CXX11_THREAD_LOCAL  1128 #endif  // GUDHI_CAN_USE_CXX11_THREAD_LOCAL  1129     std::vector<std::pair<Vertex_handle, Node> > inter;
  1130     for (Dictionary_it s_h = siblings->members().begin();
  1131          s_h != siblings->members().end(); ++s_h, ++next) {
  1132       Simplex_handle root_sh = find_vertex(s_h->first);
  1137                      siblings->members().end(),
  1138                      root_sh->second.children()->members().begin(),
  1139                      root_sh->second.children()->members().end(),
  1140                      s_h->second.filtration());
  1141         if (inter.size() != 0) {
  1142           Siblings * new_sib =
new Siblings(siblings,
  1146           s_h->second.assign_children(new_sib);
  1147           siblings_expansion(new_sib, k - 1);
  1150           s_h->second.assign_children(siblings);
  1159   static void intersection(std::vector<std::pair<Vertex_handle, Node> >& intersection,
  1160                            Dictionary_it begin1, Dictionary_it end1,
  1161                            Dictionary_it begin2, Dictionary_it end2,
  1162                            Filtration_value filtration_) {
  1163     if (begin1 == end1 || begin2 == end2)
  1166       if (begin1->first == begin2->first) {
  1167         Filtration_value filt = (std::max)({begin1->second.filtration(), begin2->second.filtration(), filtration_});
  1168         intersection.emplace_back(begin1->first, Node(
nullptr, filt));
  1169         if (++begin1 == end1 || ++begin2 == end2)
  1171       }
else if (begin1->first < begin2->first) {
  1172         if (++begin1 == end1)
  1175         if (++begin2 == end2)
  1200   template<
typename Blocker >
  1203     for (
auto& simplex : boost::adaptors::reverse(root_.members())) {
  1205         siblings_expansion_with_blockers(simplex.second.children(), max_dim, max_dim - 1, block_simplex);
  1212   template<
typename Blocker >
  1213   void siblings_expansion_with_blockers(Siblings* siblings,
int max_dim,
int k, Blocker block_simplex) {
  1214     if (dimension_ < max_dim - k) {
  1215       dimension_ = max_dim - k;
  1220     if (siblings->members().size() < 2)
  1223     for (
auto simplex = siblings->members().rbegin() + 1; simplex != siblings->members().rend(); simplex++) {
  1224       std::vector<std::pair<Vertex_handle, Node> > intersection;
  1225       for(
auto next = siblings->members().rbegin(); next !=
simplex; next++) {
  1226         bool to_be_inserted =
true;
  1227         Filtration_value filt = simplex->second.filtration();
  1230           Simplex_handle border_child = find_child(border, next->first);
  1232             to_be_inserted=
false;
  1235           filt = (std::max)(filt,
filtration(border_child));
  1237         if (to_be_inserted) {
  1238           intersection.emplace_back(next->first, Node(
nullptr, filt));
  1241       if (intersection.size() != 0) {
  1243         Siblings * new_sib =
  1245                                           boost::adaptors::reverse(intersection));
  1246         std::vector<Vertex_handle> blocked_new_sib_vertex_list;
  1248         for (
auto new_sib_member = new_sib->members().begin();
  1249              new_sib_member != new_sib->members().end();
  1251            bool blocker_result = block_simplex(new_sib_member);
  1254            if (blocker_result) {
  1255              blocked_new_sib_vertex_list.push_back(new_sib_member->first);
  1258         if (blocked_new_sib_vertex_list.size() == new_sib->members().size()) {
  1262           simplex->second.assign_children(siblings);
  1264           for (
auto& blocked_new_sib_member : blocked_new_sib_vertex_list) {
  1265             new_sib->members().erase(blocked_new_sib_member);
  1268           simplex->second.assign_children(new_sib);
  1269           siblings_expansion_with_blockers(new_sib, max_dim, k - 1, block_simplex);
  1273         simplex->second.assign_children(siblings);
  1282   Simplex_handle find_child(Simplex_handle sh, Vertex_handle vh)
 const {
  1286     Simplex_handle child = sh->second.children()->find(vh);
  1289     if (child == sh->second.children()->members().end())
  1307         os <<
key(b_sh) <<
  1322     bool modified =
false;
  1324     for (
  1326         modified |= rec_make_filtration_non_decreasing(simplex.second.children());
  1337   bool rec_make_filtration_non_decreasing(Siblings * sib) {
  1338     bool modified =
false;
  1341     for (
auto& simplex : boost::adaptors::reverse(sib->members())) {
  1344       Boundary_simplex_iterator max_border = std::max_element(std::begin(boundary), std::end(boundary),
  1345                                                               [](Simplex_handle sh1, Simplex_handle sh2) {
  1349       Filtration_value max_filt_border_value =
filtration(*max_border);
  1350       if (simplex.second.filtration() < max_filt_border_value) {
  1353         simplex.second.assign_filtration(max_filt_border_value);
  1356         modified |= rec_make_filtration_non_decreasing(simplex.second.children());
  1375     return rec_prune_above_filtration(
root(), filtration);
  1379   bool rec_prune_above_filtration(Siblings* sib, Filtration_value filt) {
  1380     auto&& list = sib->members();
  1381     auto last = std::remove_if(list.begin(), list.end(), [=](Dit_value_t&
simplex) {
  1382         if (simplex.second.filtration() <= filt)
return false;
  1383         if (
has_children(&simplex)) rec_delete(simplex.second.children());
  1385         dimension_to_be_lowered_ =
true;
  1389     bool modified = (last != list.end());
  1390     if (last == list.begin() && sib !=
root()) {
  1392       sib->oncles()->members()[sib->parent()].assign_children(sib->oncles());
  1395       dimension_to_be_lowered_ =
true;
  1399       list.erase(last, list.end());
  1400       for (
auto&& simplex : list)
  1402           modified |= rec_prune_above_filtration(simplex.second.children(), filt);
  1413   bool lower_upper_bound_dimension() {
  1415     dimension_to_be_lowered_ =
false;
  1416     int new_dimension = -1;
  1421         std::cout <<
" " << vertex;
  1423       std::cout << std::endl;
  1424 #endif  // DEBUG_TRACES  1427       if (sh_dimension >= dimension_)
  1430       new_dimension = (std::max)(new_dimension, sh_dimension);
  1432     dimension_ = new_dimension;
  1450                 std::invalid_argument(
"Simplex_tree::remove_maximal_simplex - argument has children"));
  1453     Siblings* child = sh->second.children();
  1455     if ((child->size() > 1) || (child ==
root())) {
  1461       child->oncles()->members().at(child->parent()).assign_children(child->oncles());
  1464       dimension_to_be_lowered_ =
true;
  1469   Vertex_handle null_vertex_;
  1474   std::vector<Simplex_handle> filtration_vect_;
  1477   bool dimension_to_be_lowered_ =
false;
  1481 template<
typename...T>
  1493 template<
typename...T>
  1496   std::vector<typename ST::Vertex_handle>
simplex;
  1497   typename ST::Filtration_value fil;
  1502     int dim =
static_cast<int> (simplex.size() - 1);
  1503     if (max_dim < dim) {
  1524   static const bool store_key =
true;
  1525   static const bool store_filtration =
true;
  1526   static const bool contiguous_vertices =
false;
  1540   static const bool store_key =
true;
  1541   static const bool store_filtration =
true;
  1542   static const bool contiguous_vertices =
true;
  1549 #endif  // SIMPLEX_TREE_H_ Simplex_tree_skeleton_simplex_iterator< Simplex_tree > Skeleton_simplex_iterator
Iterator over the simplices of the skeleton of the simplicial complex, for a given dimension...
Definition: Simplex_tree.h:174
Simplex_tree & operator=(const Simplex_tree &complex_source)
User-defined copy assignment reproduces the whole tree structure.
Definition: Simplex_tree.h:314
Dictionary::iterator Simplex_handle
Handle type to a simplex contained in the simplicial complex represented by the simplex tree...
Definition: Simplex_tree.h:123
bool prune_above_filtration(Filtration_value filtration)
Prune above filtration value given as parameter.
Definition: Simplex_tree.h:1374
void expansion(int max_dim)
Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
Definition: Simplex_tree.h:1102
Filtration_simplex_range::const_iterator Filtration_simplex_iterator
Iterator over the simplices of the simplicial complex, ordered by the filtration. ...
Definition: Simplex_tree.h:183
Tag for a linear ordering of simplices.
Definition: indexing_tag.h:20
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:60
Siblings * self_siblings(SimplexHandle sh)
Definition: Simplex_tree.h:830
std::pair< Simplex_handle, bool > insert_simplex_and_subfaces(const InputVertexRange &Nsimplex, Filtration_value filtration=0)
Insert a N-simplex and all his subfaces, from a N-simplex represented by a range of Vertex_handles...
Definition: Simplex_tree.h:750
void assign_key(Simplex_handle sh, Simplex_key key)
Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'.
Definition: Simplex_tree.h:816
bool read_simplex(std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil)
Read a face from a file.
Definition: reader_utils.h:158
bool operator==(Simplex_tree &st2)
Checks if two simplex trees are equal.
Definition: Simplex_tree.h:422
Concept describing an indexing scheme (see FilteredComplex) for applying continuous maps to a cell co...
Definition: IndexingTag.h:18
static Simplex_key key(Simplex_handle sh)
Returns the key associated to a simplex.
Definition: Simplex_tree.h:459
static Simplex_handle null_simplex()
Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simpli...
Definition: Simplex_tree.h:498
static constexpr bool contiguous_vertices
If true, the list of vertices present in the complex must always be 0, ..., num_vertices-1, without any hole.
Definition: SimplexTreeOptions.h:29
boost::iterator_range< Complex_vertex_iterator > Complex_vertex_range
Range over the vertices of the simplicial complex.
Definition: Simplex_tree.h:149
Vertex_handle null_vertex() const
Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicia...
Definition: Simplex_tree.h:510
Simplex_tree_simplex_vertex_iterator< Simplex_tree > Simplex_vertex_iterator
Iterator over the vertices of a simplex.
Definition: Simplex_tree.h:153
Definition: SimplicialComplexForAlpha.h:14
void print_hasse(std::ostream &os)
Write the hasse diagram of the simplicial complex in os.
Definition: Simplex_tree.h:1302
Key type used as simplex identifier.
Definition: SimplexKey.h:15
Siblings * root()
Definition: Simplex_tree.h:839
Options::Simplex_key Simplex_key
Key associated to each simplex.
Definition: Simplex_tree.h:71
bool operator!=(Simplex_tree &st2)
Checks if two simplex trees are different.
Definition: Simplex_tree.h:430
bool make_filtration_non_decreasing()
This function ensures that each simplex has a higher filtration value than its faces by increasing th...
Definition: Simplex_tree.h:1321
std::vector< Simplex_handle > Filtration_simplex_range
Range over the simplices of the simplicial complex, ordered by the filtration.
Definition: Simplex_tree.h:179
int dimension()
Returns the dimension of the simplicial complex.
Definition: Simplex_tree.h:562
Filtration_simplex_range const  & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration...
Definition: Simplex_tree.h:236
void initialize_filtration()
Initializes the filtrations, i.e. sort the simplices according to their order in the filtration and i...
Definition: Simplex_tree.h:862
Simplex_handle find(const InputVertexRange &s)
Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex ...
Definition: Simplex_tree.h:584
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Cofaces_simplex_range cofaces_simplex_range(const Simplex_handle simplex, int codimension)
Compute the cofaces of a n simplex.
Definition: Simplex_tree.h:954
Complex_simplex_range complex_simplex_range()
Returns a range over the simplices of the simplicial complex.
Definition: Simplex_tree.h:202
Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>.
Definition: SimplexTreeOptions.h:15
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:515
void assign_filtration(Simplex_handle sh, Filtration_value fv)
Sets the filtration value of a simplex.
Definition: Simplex_tree.h:488
std::pair< Simplex_handle, Simplex_handle > endpoints(Simplex_handle sh)
Definition: Simplex_tree.h:823
Boundary_simplex_range boundary_simplex_range(SimplexHandle sh)
Returns a range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:270
Complex_vertex_range complex_vertex_range()
Returns a range over the vertices of the simplicial complex. The order is increasing according to < o...
Definition: Simplex_tree.h:191
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh)
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:249
Options::Vertex_handle Vertex_handle
Type for the vertex handle.
Simplex_tree(Simplex_tree &&complex_source)
User-defined move constructor relocates the whole tree structure.
Definition: Simplex_tree.h:297
Simplex_tree & operator=(Simplex_tree &&complex_source)
User-defined move assignment relocates the whole tree structure.
Definition: Simplex_tree.h:331
Skeleton_simplex_range skeleton_simplex_range(int dim)
Returns a range over the simplices of the dim-skeleton of the simplicial complex. ...
Definition: Simplex_tree.h:216
boost::iterator_range< Boundary_simplex_iterator > Boundary_simplex_range
Range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:163
bool has_children(SimplexHandle sh) const
Returns true if the node in the simplex tree pointed by sh has children.
Definition: Simplex_tree.h:571
Cofaces_simplex_range star_simplex_range(const Simplex_handle simplex)
Compute the star of a n simplex.
Definition: Simplex_tree.h:943
void set_dimension(int dimension)
Set a dimension for the simplicial complex.
Definition: Simplex_tree.h:847
int upper_bound_dimension() const
Returns an upper bound on the dimension of the simplicial complex.
Definition: Simplex_tree.h:554
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:543
static Simplex_key null_key()
Returns a key different for all keys associated to the simplices of the simplicial complex...
Definition: Simplex_tree.h:504
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:477
Definition: Simplex_tree.h:1535
Definition: Simplex_tree.h:1519
Simplex_tree(const Simplex_tree &complex_source)
User-defined copy constructor reproduces the whole tree structure.
Definition: Simplex_tree.h:287
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
boost::transform_iterator< return_first, Dictionary_it > Complex_vertex_iterator
Iterator over the vertices of the simplicial complex.
Definition: Simplex_tree.h:147
~Simplex_tree()
Destructor; deallocates the whole tree structure.
Definition: Simplex_tree.h:309
void remove_maximal_simplex(Simplex_handle sh)
Remove a maximal simplex.
Definition: Simplex_tree.h:1447
If true, each simplex has extra storage for one Filtration_value, and this value is propagated by ope...
Definition: SimplexTreeOptions.h:27
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:521
boost::iterator_range< Complex_simplex_iterator > Complex_simplex_range
Range over the simplices of the simplicial complex.
Definition: Simplex_tree.h:169
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:67
Simplex_tree()
Constructs an empty simplex tree.
Definition: Simplex_tree.h:280
Simplex_tree_boundary_simplex_iterator< Simplex_tree > Boundary_simplex_iterator
Iterator over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:161
boost::iterator_range< Skeleton_simplex_iterator > Skeleton_simplex_range
Range over the simplices of the skeleton of the simplicial complex, for a given dimension.
Definition: Simplex_tree.h:177
Simplex_tree_complex_simplex_iterator< Simplex_tree > Complex_simplex_iterator
Iterator over the simplices of the simplicial complex.
Definition: Simplex_tree.h:167
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a 1-skeleton in an empty Simplex_tree.
Definition: Simplex_tree.h:1041
Simplex_handle simplex(Simplex_key idx) const
Returns the simplex that has index idx in the filtration.
Definition: Simplex_tree.h:468
This file includes common file reader for GUDHI.
boost::iterator_range< Simplex_vertex_iterator > Simplex_vertex_range
Range over the vertices of a simplex.
Definition: Simplex_tree.h:155
std::pair< Simplex_handle, bool > insert_simplex(const InputVertexRange &simplex, Filtration_value filtration=0)
Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex.
Definition: Simplex_tree.h:721
void expansion_with_blockers(int max_dim, Blocker block_simplex)
Expands a simplex tree containing only a graph. Simplices corresponding to cliques in the graph are a...
Definition: Simplex_tree.h:1201
std::vector< Simplex_handle > Cofaces_simplex_range
Range over the cofaces of a simplex.
Definition: Simplex_tree.h:157
