#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
void usage(int nbArgs, char * const progName) {
  std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
  std::cerr << "Usage: " << progName << " filename.csv threshold dim_max [ouput_file.txt]\n";
  std::cerr << "       i.e.: " << progName << " ../../data/distance_matrix/full_square_distance_matrix.csv 1.0 3\n";
  exit(-1);
int main(int argc, char **argv) {
  if ((argc != 4) && (argc != 5)) usage(argc, (argv[0] - 1));
  std::string csv_file_name(argv[1]);
  double threshold = atof(argv[2]);
  int dim_max = atoi(argv[3]);
  using Distance_matrix = std::vector<std::vector<Filtration_value>>;
  Distance_matrix distances = Gudhi::read_lower_triangular_matrix_from_csv_file<Filtration_value>(csv_file_name);
  std::streambuf* streambufffer;
  std::ofstream ouput_file_stream;
  if (argc == 5) {
    ouput_file_stream.open(std::string(argv[4]));
    streambufffer = ouput_file_stream.rdbuf();
  } else {
    streambufffer = std::cout.rdbuf();
  rips_complex_from_file.create_complex(stree, dim_max);
  std::ostream output_stream(streambufffer);
  output_stream <<
"Rips complex is of dimension " << stree.
dimension() <<
  output_stream << "Iterator on Rips complex simplices in the filtration order, with [filtration value]:" <<
                   std::endl;
    output_stream << "   ( ";
      output_stream << vertex << " ";
    output_stream <<
"[" << stree.
filtration(f_simplex) <<
    output_stream << std::endl;
  ouput_file_stream.close();
  return 0;
