#include <gudhi/Rips_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits>
int main() {
  using Point = std::vector<double>;
  std::vector<Point> points;
  points.push_back({1.0, 1.0});
  points.push_back({7.0, 0.0});
  points.push_back({4.0, 6.0});
  points.push_back({9.0, 6.0});
  points.push_back({0.0, 14.0});
  points.push_back({2.0, 19.0});
  points.push_back({9.0, 17.0});
  double threshold = 12.0;
  std::cout <<
"Rips complex is of dimension " << stree.
dimension() <<
  std::cout << "Iterator on Rips complex simplices in the filtration order, with [filtration value]:" <<
               std::endl;
    std::cout << "   ( ";
      std::cout << vertex << " ";
    std::cout <<
"[" << stree.
filtration(f_simplex) <<
    std::cout << std::endl;
  return 0;
