Loading [MathJax]/extensions/tex2jax.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Points_off_io.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10 #ifndef POINTS_OFF_IO_H_
11 #define POINTS_OFF_IO_H_
12
13 #include <gudhi/Off_reader.h>
14
15 #include <string>
16 #include <vector>
17 #include <fstream>
18 #include <map>
19
20 namespace Gudhi {
21
25 template<typename Point_d>
27  private:
28  std::vector<Point_d> point_cloud;
29
30  public:
41  void init(int dim, int num_vertices, int num_faces, int num_edges) {
42 #ifdef DEBUG_TRACES
43  std::cout << "Points_off_visitor_reader::init - dim=" << dim << " - num_vertices=" <<
44  num_vertices << " - num_faces=" << num_faces << " - num_edges=" << num_edges << std::endl;
45 #endif // DEBUG_TRACES
46  if (num_faces > 0) {
47  std::cerr << "Points_off_visitor_reader::init faces are not taken into account from OFF file for Points.\n";
48  }
49  if (num_edges > 0) {
50  std::cerr << "Points_off_visitor_reader::init edges are not taken into account from OFF file for Points.\n";
51  }
52  }
53
67  void point(const std::vector<double>& point) {
68 #ifdef DEBUG_TRACES
69  std::cout << "Points_off_visitor_reader::point ";
70  for (auto coordinate : point) {
71  std::cout << coordinate << " | ";
72  }
73  std::cout << std::endl;
74 #endif // DEBUG_TRACES
75  // Fill the point cloud
76  point_cloud.push_back(Point_d(point.begin(), point.end()));
77  }
78
79  // Off_reader visitor maximal_face implementation - Only points are read
80  void maximal_face(const std::vector<int>& face) { }
81
82  // Off_reader visitor done implementation - Only points are read
83  void done() { }
84
89  const std::vector<Point_d>& get_point_cloud() const {
90  return point_cloud;
91  }
92 };
93
121 template<typename Point_d>
123  public:
131  Points_off_reader(const std::string& name_file)
132  : valid_(false) {
133  std::ifstream stream(name_file);
134  if (stream.is_open()) {
135  Off_reader off_reader(stream);
137  valid_ = off_reader.read(off_visitor);
138  if (valid_) {
139  point_cloud = off_visitor.get_point_cloud();
140  }
141  } else {
142  std::cerr << "Points_off_reader::Points_off_reader could not open file " << name_file << "\n";
143  }
144  }
145
150  bool is_valid() const {
151  return valid_;
152  }
153
158  const std::vector<Point_d>& get_point_cloud() const {
159  return point_cloud;
160  }
161
162  private:
164  std::vector<Point_d> point_cloud;
166  bool valid_;
167 };
168
169 } // namespace Gudhi
170
171 #endif // POINTS_OFF_IO_H_
bool read(OffVisitor &off_visitor)
Read an OFF file and calls the following methods :
Definition: Off_reader.h:51
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
OFF file visitor implementation according to Off_reader in order to read points from an OFF file...
Definition: Points_off_io.h:26
Definition: SimplicialComplexForAlpha.h:14
const std::vector< Point_d > & get_point_cloud() const
Point cloud getter.
Definition: Points_off_io.h:158
Points_off_reader(const std::string &name_file)
Reads the OFF file and constructs a vector of points from the points that are in the OFF file...
Definition: Points_off_io.h:131
Point cloud getter.
Definition: Points_off_io.h:89
Off_reader visitor init implementation.
Definition: Points_off_io.h:41
OFF file reader top class visitor.
Definition: Off_reader.h:29
Returns if the OFF file read operation was successful or not.
Definition: Points_off_io.h:150
void point(const std::vector< double > &point)
Off_reader visitor point implementation.
Definition: Points_off_io.h:67
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13
