Persistence_representations/persistence_landscapes_on_grid/plot_landscapes_on_grid.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_landscape_on_grid.h>
#include <iostream>
#include <sstream>
int main(int argc, char** argv) {
std::cout << "This program creates a gnuplot script from a persistence landscape on grid stored in a file (the file "
<< "needs to be created beforehand). Please call the code with the name of a single landscape on grid file"
<< ".\n";
if (argc != 2) {
std::cout << "Wrong parameter list, the program will now terminate \n";
return 1;
l.plot(argv[1]);
return 0;
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:50 for GUDHI by Doxygen 1.8.13
