Persistence_representations/persistence_landscapes/average_landscapes.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_landscape.h>
#include <iostream>
#include <vector>
int main(int argc, char** argv) {
std::cout << "This program computes average of persistence landscapes stored in files (the files needs to be "
<< "created beforehand).\n"
<< "The parameters of this programs are names of files with persistence landscapes.\n";
std::vector<const char*> filenames;
if (argc < 3) {
std::cout << "Wrong number of parameters, the program will now terminate \n";
return 1;
for (int i = 1; i < argc; ++i) {
filenames.push_back(argv[i]);
std::vector<Persistence_landscape*> lands;
for (size_t i = 0; i != filenames.size(); ++i) {
l->load_landscape_from_file(filenames[i]);
lands.push_back(l);
av.compute_average(lands);
av.print_to_file("average.land");
delete lands[i];
std::cout << "Average can be found in 'average.land' file\n";
return 0;
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:50 for GUDHI by Doxygen 1.8.13
