Cech_complex.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2018 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef CECH_COMPLEX_H_
12 #define CECH_COMPLEX_H_
13
14 #include <gudhi/distance_functions.h> // for Gudhi::Minimal_enclosing_ball_radius
15 #include <gudhi/graph_simplicial_complex.h> // for Gudhi::Proximity_graph
16 #include <gudhi/Debug_utils.h> // for GUDHI_CHECK
17 #include <gudhi/Cech_complex_blocker.h> // for Gudhi::cech_complex::Cech_blocker
18
19 #include <iostream>
20 #include <stdexcept> // for exception management
21 #include <vector>
22
23 namespace Gudhi {
24
25 namespace cech_complex {
26
43 template <typename SimplicialComplexForProximityGraph, typename ForwardPointRange>
44 class Cech_complex {
45  private:
46  // Required by compute_proximity_graph
47  using Vertex_handle = typename SimplicialComplexForProximityGraph::Vertex_handle;
48  using Filtration_value = typename SimplicialComplexForProximityGraph::Filtration_value;
49  using Proximity_graph = Gudhi::Proximity_graph<SimplicialComplexForProximityGraph>;
50
51  // Retrieve Coordinate type from ForwardPointRange
52  using Point_from_range_iterator = typename boost::range_const_iterator<ForwardPointRange>::type;
53  using Point_from_range = typename std::iterator_traits<Point_from_range_iterator>::value_type;
54  using Coordinate_iterator = typename boost::range_const_iterator<Point_from_range>::type;
55  using Coordinate = typename std::iterator_traits<Coordinate_iterator>::value_type;
56
57  public:
58  // Point and Point_cloud type definition
59  using Point = std::vector<Coordinate>;
60  using Point_cloud = std::vector<Point>;
61
62  public:
71  Cech_complex(const ForwardPointRange& points, Filtration_value max_radius) : max_radius_(max_radius) {
72  // Point cloud deep copy
73  point_cloud_.reserve(boost::size(points));
74  for (auto&& point : points) point_cloud_.emplace_back(std::begin(point), std::end(point));
75
76  cech_skeleton_graph_ = Gudhi::compute_proximity_graph<SimplicialComplexForProximityGraph>(
77  point_cloud_, max_radius_, Gudhi::Minimal_enclosing_ball_radius());
78  }
79
88  template <typename SimplicialComplexForCechComplex>
89  void create_complex(SimplicialComplexForCechComplex& complex, int dim_max) {
90  GUDHI_CHECK(complex.num_vertices() == 0,
91  std::invalid_argument("Cech_complex::create_complex - simplicial complex is not empty"));
92
93  // insert the proximity graph in the simplicial complex
94  complex.insert_graph(cech_skeleton_graph_);
95  // expand the graph until dimension dim_max
96  complex.expansion_with_blockers(dim_max,
97  Cech_blocker<SimplicialComplexForCechComplex, Cech_complex>(&complex, this));
98  }
99
101  Filtration_value max_radius() const { return max_radius_; }
102
106  const Point& get_point(Vertex_handle vertex) const { return point_cloud_[vertex]; }
107
108  private:
109  Proximity_graph cech_skeleton_graph_;
110  Filtration_value max_radius_;
111  Point_cloud point_cloud_;
112 };
113
114 } // namespace cech_complex
115
116 } // namespace Gudhi
117
118 #endif // CECH_COMPLEX_H_
Cech_complex(const ForwardPointRange &points, Filtration_value max_radius)
Cech_complex constructor from a list of points.
Definition: Cech_complex.h:71
Definition: SimplicialComplexForAlpha.h:14
Global distance functions.
Compute the radius of the minimal enclosing ball between Points given by a range of coordinates...
Definition: distance_functions.h:64
const Point & get_point(Vertex_handle vertex) const
Definition: Cech_complex.h:106
Cech complex data structure.
Definition: Cech_complex.h:44
Definition: Cech_complex.h:101
void create_complex(SimplicialComplexForCechComplex &complex, int dim_max)
Initializes the simplicial complex from the proximity graph and expands it until a given maximal dime...
Definition: Cech_complex.h:89
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:50 for GUDHI by Doxygen 1.8.13
