Bitmap_cubical_complex.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Pawel Dlotko
4  *
5  * Copyright (C) 2015 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef BITMAP_CUBICAL_COMPLEX_H_
12 #define BITMAP_CUBICAL_COMPLEX_H_
13
14 #include <gudhi/Bitmap_cubical_complex_base.h>
15 #include <gudhi/Bitmap_cubical_complex_periodic_boundary_conditions_base.h>
16
17 #ifdef GUDHI_USE_TBB
18 #include <tbb/parallel_sort.h>
19 #endif
20
21 #include <limits>
22 #include <utility> // for pair<>
23 #include <algorithm> // for sort
24 #include <vector>
25 #include <numeric> // for iota
26 #include <cstddef>
27
28 namespace Gudhi {
29
30 namespace cubical_complex {
31
32 // global variable, was used just for debugging.
33 const bool globalDbg = false;
34
35 template <typename T>
36 class is_before_in_filtration;
37
47 template <typename T>
48 class Bitmap_cubical_complex : public T {
49  public:
50  //*********************************************//
51  // Typedefs and typenames
52  //*********************************************//
53  typedef std::size_t Simplex_key;
54  typedef typename T::filtration_type Filtration_value;
55  typedef Simplex_key Simplex_handle;
56
57  //*********************************************//
58  // Constructors
59  //*********************************************//
60  // Over here we need to define various input types. I am proposing the following ones:
61  // Perseus style
62  // TODO(PD) H5 files?
63  // TODO(PD) binary files with little endiangs / big endians ?
64  // TODO(PD) constructor from a vector of elements of a type T. ?
65
69  Bitmap_cubical_complex(const char* perseus_style_file)
70  : T(perseus_style_file), key_associated_to_simplex(this->total_number_of_cells + 1) {
71  if (globalDbg) {
72  std::cerr << "Bitmap_cubical_complex( const char* perseus_style_file )\n";
73  }
74  for (std::size_t i = 0; i != this->total_number_of_cells; ++i) {
75  this->key_associated_to_simplex[i] = i;
76  }
77  // we initialize this only once, in each constructor, when the bitmap is constructed.
78  // If the user decide to change some elements of the bitmap, then this procedure need
79  // to be called again.
81  }
82
88  Bitmap_cubical_complex(const std::vector<unsigned>& dimensions,
89  const std::vector<Filtration_value>& top_dimensional_cells)
90  : T(dimensions, top_dimensional_cells), key_associated_to_simplex(this->total_number_of_cells + 1) {
91  for (std::size_t i = 0; i != this->total_number_of_cells; ++i) {
92  this->key_associated_to_simplex[i] = i;
93  }
94  // we initialize this only once, in each constructor, when the bitmap is constructed.
95  // If the user decide to change some elements of the bitmap, then this procedure need
96  // to be called again.
98  }
99
107  Bitmap_cubical_complex(const std::vector<unsigned>& dimensions,
108  const std::vector<Filtration_value>& top_dimensional_cells,
109  std::vector<bool> directions_in_which_periodic_b_cond_are_to_be_imposed)
110  : T(dimensions, top_dimensional_cells, directions_in_which_periodic_b_cond_are_to_be_imposed),
111  key_associated_to_simplex(this->total_number_of_cells + 1) {
112  for (std::size_t i = 0; i != this->total_number_of_cells; ++i) {
113  this->key_associated_to_simplex[i] = i;
114  }
115  // we initialize this only once, in each constructor, when the bitmap is constructed.
116  // If the user decide to change some elements of the bitmap, then this procedure need
117  // to be called again.
119  }
120
125
126  //*********************************************//
127  // Other 'easy' functions
128  //*********************************************//
129
133  std::size_t num_simplices() const { return this->total_number_of_cells; }
134
138  static Simplex_handle null_simplex() {
139  if (globalDbg) {
140  std::cerr << "Simplex_handle null_simplex()\n";
141  }
142  return std::numeric_limits<Simplex_handle>::max();
143  }
144
148  inline std::size_t dimension() const { return this->sizes.size(); }
149
153  inline unsigned dimension(Simplex_handle sh) const {
154  if (globalDbg) {
155  std::cerr << "unsigned dimension(const Simplex_handle& sh)\n";
156  }
157  if (sh != null_simplex()) return this->get_dimension_of_a_cell(sh);
158  return -1;
159  }
160
164  Filtration_value filtration(Simplex_handle sh) {
165  if (globalDbg) {
166  std::cerr << "Filtration_value filtration(const Simplex_handle& sh)\n";
167  }
168  // Returns the filtration value of a simplex.
169  if (sh != null_simplex()) return this->data[sh];
170  return std::numeric_limits<Filtration_value>::infinity();
171  }
172
176  static Simplex_key null_key() {
177  if (globalDbg) {
178  std::cerr << "Simplex_key null_key()\n";
179  }
180  return std::numeric_limits<Simplex_handle>::max();
181  }
182
186  Simplex_key key(Simplex_handle sh) const {
187  if (globalDbg) {
188  std::cerr << "Simplex_key key(const Simplex_handle& sh)\n";
189  }
190  if (sh != null_simplex()) {
191  return this->key_associated_to_simplex[sh];
192  }
193  return this->null_key();
194  }
195
199  Simplex_handle simplex(Simplex_key key) {
200  if (globalDbg) {
201  std::cerr << "Simplex_handle simplex(Simplex_key key)\n";
202  }
203  if (key != null_key()) {
204  return this->simplex_associated_to_key[key];
205  }
206  return null_simplex();
207  }
208
212  void assign_key(Simplex_handle sh, Simplex_key key) {
213  if (globalDbg) {
214  std::cerr << "void assign_key(Simplex_handle& sh, Simplex_key key)\n";
215  }
216  if (key == null_key()) return;
217  this->key_associated_to_simplex[sh] = key;
218  this->simplex_associated_to_key[key] = sh;
219  }
220
225
226  //*********************************************//
227  // Iterators
228  //*********************************************//
229
233  typedef typename std::vector<Simplex_handle>::iterator Boundary_simplex_iterator;
234  typedef typename std::vector<Simplex_handle> Boundary_simplex_range;
235
243
244  class Filtration_simplex_iterator : std::iterator<std::input_iterator_tag, Simplex_handle> {
245  // Iterator over all simplices of the complex in the order of the indexing scheme.
246  // 'value_type' must be 'Simplex_handle'.
247  public:
248  Filtration_simplex_iterator(Bitmap_cubical_complex* b) : b(b), position(0) {}
249
250  Filtration_simplex_iterator() : b(NULL), position(0) {}
251
252  Filtration_simplex_iterator operator++() {
253  if (globalDbg) {
254  std::cerr << "Filtration_simplex_iterator operator++\n";
255  }
256  ++this->position;
257  return (*this);
258  }
259
260  Filtration_simplex_iterator operator++(int) {
261  Filtration_simplex_iterator result = *this;
262  ++(*this);
263  return result;
264  }
265
266  Filtration_simplex_iterator& operator=(const Filtration_simplex_iterator& rhs) {
267  if (globalDbg) {
268  std::cerr << "Filtration_simplex_iterator operator =\n";
269  }
270  this->b = rhs.b;
271  this->position = rhs.position;
272  return (*this);
273  }
274
275  bool operator==(const Filtration_simplex_iterator& rhs) const {
276  if (globalDbg) {
277  std::cerr << "bool operator == ( const Filtration_simplex_iterator& rhs )\n";
278  }
279  return (this->position == rhs.position);
280  }
281
282  bool operator!=(const Filtration_simplex_iterator& rhs) const {
283  if (globalDbg) {
284  std::cerr << "bool operator != ( const Filtration_simplex_iterator& rhs )\n";
285  }
286  return !(*this == rhs);
287  }
288
289  Simplex_handle operator*() {
290  if (globalDbg) {
291  std::cerr << "Simplex_handle operator*()\n";
292  }
293  return this->b->simplex_associated_to_key[this->position];
294  }
295
296  friend class Filtration_simplex_range;
297
298  private:
300  std::size_t position;
301  };
302
307  // Range over the simplices of the complex in the order of the filtration.
308  // .begin() and .end() return type Filtration_simplex_iterator.
309  public:
310  typedef Filtration_simplex_iterator const_iterator;
311  typedef Filtration_simplex_iterator iterator;
312
314
315  Filtration_simplex_iterator begin() {
316  if (globalDbg) {
317  std::cerr << "Filtration_simplex_iterator begin() \n";
318  }
319  return Filtration_simplex_iterator(this->b);
320  }
321
322  Filtration_simplex_iterator end() {
323  if (globalDbg) {
324  std::cerr << "Filtration_simplex_iterator end()\n";
325  }
326  Filtration_simplex_iterator it(this->b);
327  it.position = this->b->simplex_associated_to_key.size();
328  return it;
329  }
330
331  private:
333  };
334
335  //*********************************************//
336  // Methods to access iterators from the container:
337
342  Boundary_simplex_range boundary_simplex_range(Simplex_handle sh) { return this->get_boundary_of_a_cell(sh); }
343
349  if (globalDbg) {
350  std::cerr << "Filtration_simplex_range filtration_simplex_range()\n";
351  }
352  // Returns a range over the simplices of the complex in the order of the filtration
353  return Filtration_simplex_range(this);
354  }
355  //*********************************************//
356
357  //*********************************************//
358  // Elements which are in Gudhi now, but I (and in all the cases I asked also Marc) do not understand why they are
359  // there.
360  // TODO(PD) the file IndexingTag.h in the Gudhi library contains an empty structure, so
361  // I understand that this is something that was planned (for simplicial maps?)
362  // but was never finished. The only idea I have here is to use the same empty structure from
363  // IndexingTag.h file, but only if the compiler needs it. If the compiler
364  // do not need it, then I would rather not add here elements which I do not understand.
365  // typedef Indexing_tag
366
370  std::pair<Simplex_handle, Simplex_handle> endpoints(Simplex_handle sh) {
371  std::vector<std::size_t> bdry = this->get_boundary_of_a_cell(sh);
372  if (globalDbg) {
373  std::cerr << "std::pair<Simplex_handle, Simplex_handle> endpoints( Simplex_handle sh )\n";
374  std::cerr << "bdry.size() : " << bdry.size() << "\n";
375  }
376  // this method returns two first elements from the boundary of sh.
377  if (bdry.size() < 2)
378  throw(
379  "Error in endpoints in Bitmap_cubical_complex class. The cell have less than two elements in the "
380  "boundary.");
381  return std::make_pair(bdry[0], bdry[1]);
382  }
383
388
389  class Skeleton_simplex_iterator : std::iterator<std::input_iterator_tag, Simplex_handle> {
390  // Iterator over all simplices of the complex in the order of the indexing scheme.
391  // 'value_type' must be 'Simplex_handle'.
392  public:
393  Skeleton_simplex_iterator(Bitmap_cubical_complex* b, std::size_t d) : b(b), dimension(d) {
394  if (globalDbg) {
395  std::cerr << "Skeleton_simplex_iterator ( Bitmap_cubical_complex* b , std::size_t d )\n";
396  }
397  // find the position of the first simplex of a dimension d
398  this->position = 0;
399  while ((this->position != b->data.size()) &&
400  (this->b->get_dimension_of_a_cell(this->position) != this->dimension)) {
401  ++this->position;
402  }
403  }
404
405  Skeleton_simplex_iterator() : b(NULL), position(0), dimension(0) {}
406
407  Skeleton_simplex_iterator operator++() {
408  if (globalDbg) {
409  std::cerr << "Skeleton_simplex_iterator operator++()\n";
410  }
411  // increment the position as long as you did not get to the next element of the dimension dimension.
412  ++this->position;
413  while ((this->position != this->b->data.size()) &&
414  (this->b->get_dimension_of_a_cell(this->position) != this->dimension)) {
415  ++this->position;
416  }
417  return (*this);
418  }
419
420  Skeleton_simplex_iterator operator++(int) {
421  Skeleton_simplex_iterator result = *this;
422  ++(*this);
423  return result;
424  }
425
426  Skeleton_simplex_iterator& operator=(const Skeleton_simplex_iterator& rhs) {
427  if (globalDbg) {
428  std::cerr << "Skeleton_simplex_iterator operator =\n";
429  }
430  this->b = rhs.b;
431  this->position = rhs.position;
432  this->dimension = rhs.dimension;
433  return (*this);
434  }
435
436  bool operator==(const Skeleton_simplex_iterator& rhs) const {
437  if (globalDbg) {
438  std::cerr << "bool operator ==\n";
439  }
440  return (this->position == rhs.position);
441  }
442
443  bool operator!=(const Skeleton_simplex_iterator& rhs) const {
444  if (globalDbg) {
445  std::cerr << "bool operator != ( const Skeleton_simplex_iterator& rhs )\n";
446  }
447  return !(*this == rhs);
448  }
449
450  Simplex_handle operator*() {
451  if (globalDbg) {
452  std::cerr << "Simplex_handle operator*() \n";
453  }
454  return this->position;
455  }
456
457  friend class Skeleton_simplex_range;
458
459  private:
461  std::size_t position;
462  unsigned dimension;
463  };
464
469  // Range over the simplices of the complex in the order of the filtration.
470  // .begin() and .end() return type Filtration_simplex_iterator.
471  public:
472  typedef Skeleton_simplex_iterator const_iterator;
473  typedef Skeleton_simplex_iterator iterator;
474
475  Skeleton_simplex_range(Bitmap_cubical_complex<T>* b, unsigned dimension) : b(b), dimension(dimension) {}
476
477  Skeleton_simplex_iterator begin() {
478  if (globalDbg) {
479  std::cerr << "Skeleton_simplex_iterator begin()\n";
480  }
481  return Skeleton_simplex_iterator(this->b, this->dimension);
482  }
483
484  Skeleton_simplex_iterator end() {
485  if (globalDbg) {
486  std::cerr << "Skeleton_simplex_iterator end()\n";
487  }
488  Skeleton_simplex_iterator it(this->b, this->dimension);
489  it.position = this->b->data.size();
490  return it;
491  }
492
493  private:
495  unsigned dimension;
496  };
497
502  if (globalDbg) {
503  std::cerr << "Skeleton_simplex_range skeleton_simplex_range( unsigned dimension )\n";
504  }
505  return Skeleton_simplex_range(this, dimension);
506  }
507
508  friend class is_before_in_filtration<T>;
509
510  protected:
511  std::vector<std::size_t> key_associated_to_simplex;
512  std::vector<std::size_t> simplex_associated_to_key;
513 }; // Bitmap_cubical_complex
514
515 template <typename T>
517  if (globalDbg) {
518  std::cerr << "void Bitmap_cubical_complex<T>::initialize_elements_ordered_according_to_filtration() \n";
519  }
520  this->simplex_associated_to_key = std::vector<std::size_t>(this->data.size());
521  std::iota(std::begin(simplex_associated_to_key), std::end(simplex_associated_to_key), 0);
522 #ifdef GUDHI_USE_TBB
523  tbb::parallel_sort(simplex_associated_to_key.begin(), simplex_associated_to_key.end(),
524  is_before_in_filtration<T>(this));
525 #else
526  std::sort(simplex_associated_to_key.begin(), simplex_associated_to_key.end(), is_before_in_filtration<T>(this));
527 #endif
528
529  // we still need to deal here with a key_associated_to_simplex:
530  for (std::size_t i = 0; i != simplex_associated_to_key.size(); ++i) {
531  this->key_associated_to_simplex[simplex_associated_to_key[i]] = i;
532  }
533 }
534
535 template <typename T>
536 class is_before_in_filtration {
537  public:
538  explicit is_before_in_filtration(Bitmap_cubical_complex<T>* CC) : CC_(CC) {}
539
540  bool operator()(const typename Bitmap_cubical_complex<T>::Simplex_handle& sh1,
541  const typename Bitmap_cubical_complex<T>::Simplex_handle& sh2) const {
542  // Not using st_->filtration(sh1) because it uselessly tests for null_simplex.
543  typedef typename T::filtration_type Filtration_value;
544  Filtration_value fil1 = CC_->data[sh1];
545  Filtration_value fil2 = CC_->data[sh2];
546  if (fil1 != fil2) {
547  return fil1 < fil2;
548  }
549  // in this case they are on the same filtration level, so the dimension decide.
550  std::size_t dim1 = CC_->get_dimension_of_a_cell(sh1);
551  std::size_t dim2 = CC_->get_dimension_of_a_cell(sh2);
552  if (dim1 != dim2) {
553  return dim1 < dim2;
554  }
555  // in this case both filtration and dimensions of the considered cubes are the same. To have stable sort, we simply
556  // compare their positions in the bitmap:
557  return sh1 < sh2;
558  }
559
560  protected:
562 };
563
564 } // namespace cubical_complex
565
566 namespace Cubical_complex = cubical_complex;
567
568 } // namespace Gudhi
569
570 #endif // BITMAP_CUBICAL_COMPLEX_H_
virtual ~Bitmap_cubical_complex()
Definition: Bitmap_cubical_complex.h:124
Definition: Bitmap_cubical_complex.h:342
std::vector< Simplex_handle >::iterator Boundary_simplex_iterator
Definition: Bitmap_cubical_complex.h:233
Definition: Bitmap_cubical_complex.h:186
void initialize_simplex_associated_to_key()
Definition: Bitmap_cubical_complex.h:516
Definition: Bitmap_cubical_complex.h:148
std::pair< Simplex_handle, Simplex_handle > endpoints(Simplex_handle sh)
Definition: Bitmap_cubical_complex.h:370
Definition: SimplicialComplexForAlpha.h:14
Definition: Bitmap_cubical_complex.h:133
Definition: Bitmap_cubical_complex.h:153
Definition: Bitmap_cubical_complex.h:348
Definition: Bitmap_cubical_complex.h:199
Filtration_simplex_range provides the ranges for Filtration_simplex_iterator.
Definition: Bitmap_cubical_complex.h:306
Definition: Bitmap_cubical_complex.h:212
Cubical complex represented as a bitmap.
Definition: Bitmap_cubical_complex.h:48
Bitmap_cubical_complex(const std::vector< unsigned > &dimensions, const std::vector< Filtration_value > &top_dimensional_cells)
Definition: Bitmap_cubical_complex.h:88
Bitmap_cubical_complex(const std::vector< unsigned > &dimensions, const std::vector< Filtration_value > &top_dimensional_cells, std::vector< bool > directions_in_which_periodic_b_cond_are_to_be_imposed)
Definition: Bitmap_cubical_complex.h:107
Class needed for compatibility with Gudhi. Not useful for other purposes.
Definition: Bitmap_cubical_complex.h:468
Definition: Bitmap_cubical_complex.h:176
Bitmap_cubical_complex(const char *perseus_style_file)
Definition: Bitmap_cubical_complex.h:69
Definition: Bitmap_cubical_complex.h:138
Skeleton_simplex_range skeleton_simplex_range(unsigned dimension)
Definition: Bitmap_cubical_complex.h:501
Definition: Bitmap_cubical_complex.h:164
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:50 for GUDHI by Doxygen 1.8.13
