#include <gudhi/Alpha_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epick_d.h>
#include <iostream>
#include <string>
void usage(int nbArgs, char * const progName) {
  std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
  std::cerr << "Usage: " << progName << " filename.off alpha_square_max_value [ouput_file.txt]\n";
  std::cerr << "       i.e.: " << progName << " ../../data/points/alphacomplexdoc.off 60.0\n";
  exit(-1);
int main(int argc, char **argv) {
  if ((argc != 3) && (argc != 4)) usage(argc, (argv[0] - 1));
  std::string off_file_name {argv[1]};
  double alpha_square_max_value {atof(argv[2])};
  using Kernel = CGAL::Epick_d< CGAL::Dynamic_dimension_tag >;
  std::streambuf* streambufffer;
  std::ofstream ouput_file_stream;
  if (argc == 4) {
    ouput_file_stream.open(std::string(argv[3]));
    streambufffer = ouput_file_stream.rdbuf();
  } else {
    streambufffer = std::cout.rdbuf();
  if (alpha_complex_from_file.
create_complex(simplex, alpha_square_max_value)) {
     std::ostream output_stream(streambufffer);
    output_stream <<
"Alpha complex is of dimension " << simplex.
dimension() <<
    output_stream << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" <<
        std::endl;
      output_stream << "   ( ";
        output_stream << vertex << " ";
      output_stream <<
"[" << simplex.
filtration(f_simplex) <<
      output_stream << std::endl;
  ouput_file_stream.close();
  return 0;
