This file includes common file reader for GUDHI. More...
Go to the source code of this file.
Namespaces | |
| Gudhi | |
Functions | |
| void | Gudhi::read_points (std::string file_name, std::vector< std::vector< double >> &points) |
| Read a set of points to turn it into a vector< vector<double> > by filling points. More... | |
| template<typename Graph_t , typename Filtration_value , typename Vertex_handle > | |
| Graph_t | Gudhi::read_graph (std::string file_name) |
| Read a graph from a file. More... | |
| template<typename Vertex_handle , typename Filtration_value > | |
| bool | Gudhi::read_simplex (std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil) |
| Read a face from a file. More... | |
| template<typename Simplex_key , typename Filtration_value > | |
| bool | Gudhi::read_hasse_simplex (std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil) |
| Read a hasse simplex from a file. More... | |
| template<typename Filtration_value > | |
| std::vector< std::vector< Filtration_value > > | Gudhi::read_lower_triangular_matrix_from_csv_file (const std::string &filename, const char separator=';') |
| Read a lower triangular distance matrix from a csv file. We assume that the .csv store the whole (square) matrix. More... | |
| template<typename OutputIterator > | |
| void | Gudhi::read_persistence_intervals_and_dimension (std::string const &filename, OutputIterator out) |
| std::map< int, std::vector< std::pair< double, double > > > | Gudhi::read_persistence_intervals_grouped_by_dimension (std::string const &filename) |
| std::vector< std::pair< double, double > > | Gudhi::read_persistence_intervals_in_dimension (std::string const &filename, int only_this_dim=-1) |
| GUDHI Version 2.3.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : GPL v3 | Generated on Tue Sep 4 2018 14:33:00 for GUDHI by Doxygen 1.8.13 |
