Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerator Friends Modules Pages
Simplex_tree/simple_simplex_tree.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Vincent Rouvreau
* Copyright (C) 2014 Inria
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/graph_simplicial_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <utility> // for pair
#include <vector>
using Vertex_handle = Simplex_tree::Vertex_handle;
using typeVectorVertex = std::vector<Vertex_handle>;
using typePairSimplexBool = std::pair<Simplex_tree::Simplex_handle, bool>;
int main(int argc, char* const argv[]) {
const Filtration_value FIRST_FILTRATION_VALUE = 0.1;
const Filtration_value SECOND_FILTRATION_VALUE = 0.2;
const Filtration_value THIRD_FILTRATION_VALUE = 0.3;
const Filtration_value FOURTH_FILTRATION_VALUE = 0.4;
// TEST OF INSERTION
std::cout << "********************************************************************" << std::endl;
std::cout << "EXAMPLE OF SIMPLE INSERTION" << std::endl;
// Construct the Simplex Tree
Simplex_tree simplexTree;
/* Simplex to be inserted: */
/* 1 */
/* o */
/* /X\ */
/* o---o---o */
/* 2 0 3 */
// ++ FIRST
std::cout << " * INSERT 0" << std::endl;
typeVectorVertex firstSimplexVector = {0};
typePairSimplexBool returnValue =
simplexTree.insert_simplex(firstSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
if (returnValue.second == true) {
std::cout << " + 0 INSERTED" << std::endl;
} else {
std::cout << " - 0 NOT INSERTED" << std::endl;
// ++ SECOND
std::cout << " * INSERT 1" << std::endl;
typeVectorVertex secondSimplexVector = {1};
returnValue = simplexTree.insert_simplex(secondSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::cout << " + 1 INSERTED" << std::endl;
} else {
std::cout << " - 1 NOT INSERTED" << std::endl;
// ++ THIRD
std::cout << " * INSERT (0,1)" << std::endl;
typeVectorVertex thirdSimplexVector = {0, 1};
returnValue = simplexTree.insert_simplex(thirdSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (0,1) INSERTED" << std::endl;
} else {
std::cout << " - (0,1) NOT INSERTED" << std::endl;
// ++ FOURTH
std::cout << " * INSERT 2" << std::endl;
typeVectorVertex fourthSimplexVector = {2};
returnValue = simplexTree.insert_simplex(fourthSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::cout << " + 2 INSERTED" << std::endl;
} else {
std::cout << " - 2 NOT INSERTED" << std::endl;
// ++ FIFTH
std::cout << " * INSERT (2,0)" << std::endl;
typeVectorVertex fifthSimplexVector = {2, 0};
returnValue = simplexTree.insert_simplex(fifthSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (2,0) INSERTED" << std::endl;
} else {
std::cout << " - (2,0) NOT INSERTED" << std::endl;
// ++ SIXTH
std::cout << " * INSERT (2,1)" << std::endl;
typeVectorVertex sixthSimplexVector = {2, 1};
returnValue = simplexTree.insert_simplex(sixthSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (2,1) INSERTED" << std::endl;
} else {
std::cout << " - (2,1) NOT INSERTED" << std::endl;
// ++ SEVENTH
std::cout << " * INSERT (2,1,0)" << std::endl;
typeVectorVertex seventhSimplexVector = {2, 1, 0};
returnValue = simplexTree.insert_simplex(seventhSimplexVector, Filtration_value(THIRD_FILTRATION_VALUE));
std::cout << " + (2,1,0) INSERTED" << std::endl;
} else {
std::cout << " - (2,1,0) NOT INSERTED" << std::endl;
// ++ EIGHTH
std::cout << " * INSERT 3" << std::endl;
typeVectorVertex eighthSimplexVector = {3};
returnValue = simplexTree.insert_simplex(eighthSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::cout << " + 3 INSERTED" << std::endl;
} else {
std::cout << " - 3 NOT INSERTED" << std::endl;
// ++ NINETH
std::cout << " * INSERT (3,0)" << std::endl;
typeVectorVertex ninethSimplexVector = {3, 0};
returnValue = simplexTree.insert_simplex(ninethSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (3,0) INSERTED" << std::endl;
} else {
std::cout << " - (3,0) NOT INSERTED" << std::endl;
// ++ TENTH
std::cout << " * INSERT 0 (already inserted)" << std::endl;
typeVectorVertex tenthSimplexVector = {0};
// With a different filtration value
returnValue = simplexTree.insert_simplex(tenthSimplexVector, Filtration_value(FOURTH_FILTRATION_VALUE));
} else {
// ++ ELEVENTH
std::cout << " * INSERT (2,1,0) (already inserted)" << std::endl;
typeVectorVertex eleventhSimplexVector = {2, 1, 0};
returnValue = simplexTree.insert_simplex(eleventhSimplexVector, Filtration_value(FOURTH_FILTRATION_VALUE));
} else {
// ++ GENERAL VARIABLE SET
std::cout << "********************************************************************\n";
// Display the Simplex_tree - Can not be done in the middle of 2 inserts
std::cout << "* The complex contains " << simplexTree.num_simplices() << " simplices\n";
std::cout << " - dimension " << simplexTree.dimension() << "\n";
std::cout << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
for (auto f_simplex : simplexTree.filtration_simplex_range()) {
std::cout << " "
<< "[" << simplexTree.filtration(f_simplex) << "] ";
for (auto vertex : simplexTree.simplex_vertex_range(f_simplex)) std::cout << "(" << vertex << ")";
std::cout << std::endl;
// [0.1] 0
// [0.1] 1
// [0.1] 2
// [0.1] 3
// [0.2] 1 0
// [0.2] 2 0
// [0.2] 2 1
// [0.2] 3 0
// [0.3] 2 1 0
// Find in the simplex_tree
Simplex_tree::Simplex_handle simplexFound = simplexTree.find(secondSimplexVector);
std::cout << "**************IS THE SIMPLEX {1} IN THE SIMPLEX TREE ?\n";
if (simplexFound != simplexTree.null_simplex())
std::cout << "***+ YES IT IS!\n";
else
std::cout << "***- NO IT ISN'T\n";
typeVectorVertex unknownSimplexVector = {15};
simplexFound = simplexTree.find(unknownSimplexVector);
std::cout << "**************IS THE SIMPLEX {15} IN THE SIMPLEX TREE ?\n";
else
simplexFound = simplexTree.find(fifthSimplexVector);
std::cout << "**************IS THE SIMPLEX {2,0} IN THE SIMPLEX TREE ?\n";
else
typeVectorVertex otherSimplexVector = {1, 15};
simplexFound = simplexTree.find(otherSimplexVector);
std::cout << "**************IS THE SIMPLEX {15,1} IN THE SIMPLEX TREE ?\n";
else
typeVectorVertex invSimplexVector = {1, 2, 0};
simplexFound = simplexTree.find(invSimplexVector);
std::cout << "**************IS THE SIMPLEX {1,2,0} IN THE SIMPLEX TREE ?\n";
else
simplexFound = simplexTree.find({0, 1});
std::cout << "**************IS THE SIMPLEX {0,1} IN THE SIMPLEX TREE ?\n";
else
std::cout << "**************COFACES OF {0,1} IN CODIMENSION 1 ARE\n";
for (auto& simplex : simplexTree.cofaces_simplex_range(simplexTree.find({0, 1}), 1)) {
for (auto vertex : simplexTree.simplex_vertex_range(simplex)) std::cout << "(" << vertex << ")";
std::cout << "**************STARS OF {0,1} ARE\n";
for (auto& simplex : simplexTree.star_simplex_range(simplexTree.find({0, 1}))) {
std::cout << "**************BOUNDARIES OF {0,1,2} ARE\n";
for (auto& simplex : simplexTree.boundary_simplex_range(simplexTree.find({0, 1, 2}))) {
return 0;
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:32:59 for GUDHI by Doxygen 1.8.13
