Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerator Friends Modules Pages
Simplex_tree/cech_complex_cgal_mini_sphere_3d.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Vincent Rouvreau
* Copyright (C) 2017 Inria
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/graph_simplicial_complex.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Points_off_io.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Min_sphere_of_spheres_d.h>
#include <CGAL/Min_sphere_of_points_d_traits_d.h>
#include <boost/program_options.hpp>
#include <string>
#include <vector>
#include <limits> // infinity
#include <utility> // for pair
#include <map>
// cech_complex_cgal_mini_sphere_3d is an example of each step that is required to
// build a Cech over a Simplex_tree. Please refer to cech_persistence to see
// how to do the same thing with the Cech_complex wrapper for less detailed
// steps.
// Types definition
using Vertex_handle = Simplex_tree::Vertex_handle;
using Simplex_handle = Simplex_tree::Simplex_handle;
using Siblings = Simplex_tree::Siblings;
using Graph_t = boost::adjacency_list<boost::vecS, boost::vecS, boost::undirectedS,
boost::property<Gudhi::vertex_filtration_t, Filtration_value>,
boost::property<Gudhi::edge_filtration_t, Filtration_value> >;
using Edge_t = std::pair<Vertex_handle, Vertex_handle>;
using Kernel = CGAL::Epick_d<CGAL::Dimension_tag<3> >;
using Point = Kernel::Point_d;
using Traits = CGAL::Min_sphere_of_points_d_traits_d<Kernel, Filtration_value, 3>;
using Min_sphere = CGAL::Min_sphere_of_spheres_d<Traits>;
class Cech_blocker {
public:
bool operator()(Simplex_handle sh) {
std::vector<Point> points;
#if DEBUG_TRACES
std::cout << "Cech_blocker on [";
#endif // DEBUG_TRACES
for (auto vertex : simplex_tree_.simplex_vertex_range(sh)) {
points.push_back(point_cloud_[vertex]);
#if DEBUG_TRACES
std::cout << vertex << ", ";
Min_sphere ms(points.begin(), points.end());
Filtration_value radius = ms.radius();
#if DEBUG_TRACES
std::cout << "] - radius = " << radius << " - returns " << (radius > threshold_) << std::endl;
simplex_tree_.assign_filtration(sh, radius);
return (radius > threshold_);
Cech_blocker(Simplex_tree& simplex_tree, Filtration_value threshold, const std::vector<Point>& point_cloud)
: simplex_tree_(simplex_tree), threshold_(threshold), point_cloud_(point_cloud) {}
private:
Simplex_tree simplex_tree_;
Filtration_value threshold_;
std::vector<Point> point_cloud_;
template <typename InputPointRange>
Graph_t compute_proximity_graph(InputPointRange& points, Filtration_value threshold);
void program_options(int argc, char* argv[], std::string& off_file_points, Filtration_value& threshold, int& dim_max);
int main(int argc, char* argv[]) {
std::string off_file_points;
Filtration_value threshold;
int dim_max;
program_options(argc, argv, off_file_points, threshold, dim_max);
// Extract the points from the file filepoints
Points_off_reader off_reader(off_file_points);
// Compute the proximity graph of the points
Graph_t prox_graph = compute_proximity_graph(off_reader.get_point_cloud(), threshold);
// Min_sphere sph1(off_reader.get_point_cloud()[0], off_reader.get_point_cloud()[1], off_reader.get_point_cloud()[2]);
// Construct the Rips complex in a Simplex Tree
// insert the proximity graph in the simplex tree
st.insert_graph(prox_graph);
// expand the graph until dimension dim_max
st.expansion_with_blockers(dim_max, Cech_blocker(st, threshold, off_reader.get_point_cloud()));
std::cout << "The complex contains " << st.num_simplices() << " simplices \n";
std::cout << " and has dimension " << st.dimension() << " \n";
// Sort the simplices in the order of the filtration
st.initialize_filtration();
#if DEBUG_TRACES
std::cout << "********************************************************************\n";
// Display the Simplex_tree - Can not be done in the middle of 2 inserts
std::cout << "* The complex contains " << st.num_simplices() << " simplices - dimension=" << st.dimension() << "\n";
std::cout << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
for (auto f_simplex : st.filtration_simplex_range()) {
std::cout << " "
<< "[" << st.filtration(f_simplex) << "] ";
for (auto vertex : st.simplex_vertex_range(f_simplex)) {
std::cout << static_cast<int>(vertex) << " ";
std::cout << std::endl;
return 0;
void program_options(int argc, char* argv[], std::string& off_file_points, Filtration_value& threshold, int& dim_max) {
namespace po = boost::program_options;
po::options_description hidden("Hidden options");
hidden.add_options()("input-file", po::value<std::string>(&off_file_points),
"Name of an OFF file containing a 3d point set.\n");
po::options_description visible("Allowed options", 100);
visible.add_options()("help,h", "produce help message")(
"max-edge-length,r",
po::value<Filtration_value>(&threshold)->default_value(std::numeric_limits<Filtration_value>::infinity()),
"Maximal length of an edge for the Cech complex construction.")(
"cpx-dimension,d", po::value<int>(&dim_max)->default_value(1),
"Maximal dimension of the Cech complex we want to compute.");
po::positional_options_description pos;
pos.add("input-file", 1);
po::options_description all;
all.add(visible).add(hidden);
po::variables_map vm;
po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
po::notify(vm);
if (vm.count("help") || !vm.count("input-file")) {
std::cout << "Construct a Cech complex defined on a set of input points.\n \n";
std::cout << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
std::cout << visible << std::endl;
exit(-1);
Graph_t compute_proximity_graph(InputPointRange& points, Filtration_value threshold) {
std::vector<Edge_t> edges;
std::vector<Filtration_value> edges_fil;
Kernel k;
Vertex_handle idx_u, idx_v;
idx_u = 0;
for (auto it_u = points.begin(); it_u != points.end(); ++it_u) {
idx_v = idx_u + 1;
for (auto it_v = it_u + 1; it_v != points.end(); ++it_v, ++idx_v) {
fil = k.squared_distance_d_object()(*it_u, *it_v);
// For Cech Complex, threshold is a radius (distance /2)
fil = std::sqrt(fil) / 2.;
if (fil <= threshold) {
edges.emplace_back(idx_u, idx_v);
edges_fil.push_back(fil);
++idx_u;
Graph_t skel_graph(edges.begin(), edges.end(), edges_fil.begin(),
idx_u); // number of points labeled from 0 to idx_u-1
auto vertex_prop = boost::get(Gudhi::vertex_filtration_t(), skel_graph);
boost::graph_traits<Graph_t>::vertex_iterator vi, vi_end;
for (std::tie(vi, vi_end) = boost::vertices(skel_graph); vi != vi_end; ++vi) {
boost::put(vertex_prop, *vi, 0.);
return skel_graph;
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:32:59 for GUDHI by Doxygen 1.8.13
