23 #ifndef RIPS_COMPLEX_H_ 24 #define RIPS_COMPLEX_H_ 26 #include <gudhi/Debug_utils.h> 27 #include <gudhi/graph_simplicial_complex.h> 29 #include <boost/graph/adjacency_list.hpp> 41 namespace rips_complex {
56 template<
typename Filtration_value>
62 typedef typename boost::adjacency_list < boost::vecS, boost::vecS, boost::undirectedS
63 , boost::property < vertex_filtration_t, Filtration_value >
67 typedef int Vertex_handle;
82 template<
typename ForwardPo
intRange,
typename Distance >
84 compute_proximity_graph(points, threshold, distance);
96 template<
typename DistanceMatrix>
98 compute_proximity_graph(boost::irange((
size_t)0, distance_matrix.size()), threshold,
99 [&](
size_t i,
size_t j){
return distance_matrix[j][i];});
112 template <
typename SimplicialComplexForRips>
115 std::invalid_argument(
"Rips_complex::create_complex - simplicial complex is not empty"));
135 template<
typename ForwardPo
intRange,
typename Distance >
136 void compute_proximity_graph(
const ForwardPointRange& points,
Filtration_value threshold,
138 std::vector< std::pair< Vertex_handle, Vertex_handle > > edges;
139 std::vector< Filtration_value > edges_fil;
146 Vertex_handle idx_u = 0;
147 for (
auto it_u = std::begin(points); it_u != std::end(points); ++it_u, ++idx_u) {
148 Vertex_handle idx_v = idx_u + 1;
149 for (
auto it_v = it_u + 1; it_v != std::end(points); ++it_v, ++idx_v) {
151 if (fil <= threshold) {
152 edges.emplace_back(idx_u, idx_v);
153 edges_fil.push_back(fil);
164 rips_skeleton_graph_.~OneSkeletonGraph();
165 new(&rips_skeleton_graph_)
OneSkeletonGraph(edges.begin(), edges.end(), edges_fil.begin(), idx_u);
167 auto vertex_prop = boost::get(vertex_filtration_t(), rips_skeleton_graph_);
169 using vertex_iterator =
typename boost::graph_traits<OneSkeletonGraph>::vertex_iterator;
170 vertex_iterator vi, vi_end;
171 for (std::tie(vi, vi_end) = boost::vertices(rips_skeleton_graph_);
172 vi != vi_end; ++vi) {
173 boost::put(vertex_prop, *vi, 0.);
178 OneSkeletonGraph rips_skeleton_graph_;
185 #endif // RIPS_COMPLEX_H_ void create_complex(SimplicialComplexForRips &complex, int dim_max)
Initializes the simplicial complex from the Rips graph and expands it until a given maximal dimension...
Definition: Rips_complex.h:113
Rips_complex(const DistanceMatrix &distance_matrix, Filtration_value threshold)
Rips_complex constructor from a distance matrix.
Definition: Rips_complex.h:97
void expansion(int max_dim)
Expands the simplicial complex containing only its one skeleton until a given maximal dimension as ex...
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex...
The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial ...
Definition: SimplicialComplexForRips.h:33
Definition: SimplicialComplexForAlpha.h:26
Rips complex data structure.
Definition: Rips_complex.h:57
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:32
boost::adjacency_list< boost::vecS, boost::vecS, boost::undirectedS, boost::property< vertex_filtration_t, Filtration_value >, boost::property< edge_filtration_t, Filtration_value > > OneSkeletonGraph
Type of the one skeleton graph stored inside the Rips complex structure.
Definition: Rips_complex.h:64
std::size_t num_vertices()
Returns the number of vertices in the simplicial complex.
Rips_complex(const ForwardPointRange &points, Filtration_value threshold, Distance distance)
Rips_complex constructor from a list of points.
Definition: Rips_complex.h:83
