Persistence_diagram.h
1 /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author: François Godi
6  *
7  * Copyright (C) 2015 Inria
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
23 #ifndef CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
24 #define CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
25
26 namespace Gudhi {
27
28 namespace persistence_diagram {
29
37 struct DiagramPoint{};
38
45
46 } // namespace persistence_diagram
47
48 } // namespace Gudhi
49
50 #endif // CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
Concept of persistence diagram. It is a range of DiagramPoint. std::begin(diagram) and std::end(diagr...
Definition: Persistence_diagram.h:44
Definition: SimplicialComplexForAlpha.h:26
Concept of point in a persistence diagram. std::get<0>(point) must return the birth of the correspond...
Definition: Persistence_diagram.h:37
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:32:59 for GUDHI by Doxygen 1.8.13
