Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerator Friends Modules Pages
Nerve_GIC/Nerve.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Mathieu Carrière
* Copyright (C) 2017 Inria
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/GIC.h>
#include <string>
#include <vector>
void usage(int nbArgs, char *const progName) {
std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
std::cerr << "Usage: " << progName << " filename.off coordinate resolution gain [-v] \n";
std::cerr << " i.e.: " << progName << " ../../data/points/human.off 2 10 0.3 -v \n";
exit(-1); // ----- >>
int main(int argc, char **argv) {
if ((argc != 5) && (argc != 6)) usage(argc, argv[0]);
using Point = std::vector<float>;
std::string off_file_name(argv[1]);
int coord = atoi(argv[2]);
int resolution = atoi(argv[3]);
double gain = atof(argv[4]);
bool verb = 0;
if (argc == 6) verb = 1;
// Init of a Nerve from an OFF file
SC.set_verbose(verb);
bool check = SC.read_point_cloud(off_file_name);
if (!check) {
std::cout << "Incorrect OFF file." << std::endl;
} else {
SC.set_type("Nerve");
SC.set_gain(gain);
SC.write_info();
SC.create_complex(stree);
SC.compute_PD();
// Display information about the graph induced complex
if (verb) {
std::cout << "Nerve is of dimension " << stree.dimension() << " - " << stree.num_simplices() << " simplices - "
<< stree.num_vertices() << " vertices." << std::endl;
std::cout << "Iterator on Nerve simplices" << std::endl;
for (auto f_simplex : stree.filtration_simplex_range()) {
for (auto vertex : stree.simplex_vertex_range(f_simplex)) {
std::cout << vertex << " ";
std::cout << std::endl;
return 0;
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:32:59 for GUDHI by Doxygen 1.8.13
