23 #ifndef EUCLIDEAN_WITNESS_COMPLEX_H_ 24 #define EUCLIDEAN_WITNESS_COMPLEX_H_ 26 #include <gudhi/Witness_complex.h> 27 #include <gudhi/Active_witness/Active_witness.h> 28 #include <gudhi/Kd_tree_search.h> 37 namespace witness_complex {
48 template<
class Kernel_ >
50 :
public Witness_complex<std::vector<typename Gudhi::spatial_searching::Kd_tree_search<Kernel_,
51 std::vector<typename Kernel_::Point_d>>::INS_range>> {
54 typedef typename K::Point_d Point_d;
55 typedef std::vector<Point_d> Point_range;
58 typedef typename std::vector<Nearest_landmark_range> Nearest_landmark_table;
60 typedef typename Nearest_landmark_range::Point_with_transformed_distance Id_distance_pair;
61 typedef typename Id_distance_pair::first_type Landmark_id;
62 typedef Landmark_id Vertex_handle;
65 Point_range landmarks_;
66 Kd_tree landmark_tree_;
82 template<
typename LandmarkRange,
83 typename WitnessRange >
85 const WitnessRange & witnesses)
86 : landmarks_(std::begin(landmarks), std::end(landmarks)), landmark_tree_(landmarks) {
87 nearest_landmark_table_.reserve(boost::size(witnesses));
88 for (
auto w : witnesses)
96 return landmarks_[vertex];
106 #endif // EUCLIDEAN_WITNESS_COMPLEX_H_
Incremental_neighbor_search INS_range
The range returned by an incremental nearest or furthest neighbor search. Its value type is std::pair...
Definition: Kd_tree_search.h:110
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space...
Definition: Euclidean_witness_complex.h:49
Definition: SimplicialComplexForAlpha.h:26
INS_range incremental_nearest_neighbors(Point const &p, FT eps=FT(0)) const
Search incrementally for the nearest neighbors from a query point.
Definition: Kd_tree_search.h:200
Point_d get_point(Vertex_handle vertex) const
Returns the point corresponding to the given vertex.
Definition: Euclidean_witness_complex.h:95
Constructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses...
Definition: Witness_complex.h:50
Euclidean_witness_complex(const LandmarkRange &landmarks, const WitnessRange &witnesses)
Initializes member variables before constructing simplicial complex.
Definition: Euclidean_witness_complex.h:84
