Contraction/Rips_contraction.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): David Salinas
* Copyright (C) 2014 Inria
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/Edge_contraction.h>
#include <gudhi/Skeleton_blocker.h>
#include <gudhi/Off_reader.h>
#include <gudhi/Point.h>
#include <gudhi/Clock.h>
#include <iostream>
struct Geometry_trait {
typedef Point_d Point;
using Profile = Gudhi::contraction::Edge_profile<Complex>;
template<typename ComplexType>
void build_rips(ComplexType& complex, double offset) {
if (offset <= 0) return;
auto vertices = complex.vertex_range();
for (auto p = vertices.begin(); p != vertices.end(); ++p)
for (auto q = p; ++q != vertices.end(); ) {
if (squared_dist(complex.point(*p), complex.point(*q)) < 4 * offset * offset)
complex.add_edge_without_blockers(*p, *q);
int main(int argc, char *argv[]) {
if (argc != 3) {
std::cerr << "Usage " << argv[0] << " ../../../data/meshes/SO3_10000.off 0.3 to load the file " <<
"../../data/SO3_10000.off and contract the Rips complex built with paremeter 0.3.\n";
return -1;
Complex complex;
// load only the points
if (!off_reader.is_valid()) {
std::cerr << "Unable to read file:" << argv[1] << std::endl;
return EXIT_FAILURE;
std::cout << "Build the Rips complex with " << complex.num_vertices() << " vertices" << std::endl;
build_rips(complex, atof(argv[2]));
Gudhi::Clock contraction_chrono("Time to simplify and enumerate simplices");
std::cout << "Initial complex has " <<
complex.num_vertices() << " vertices and " <<
complex.num_edges() << " edges" << std::endl;
Complex_contractor contractor(complex,
Gudhi::contraction::make_first_vertex_placement<Profile>(),
Gudhi::contraction::make_link_valid_contraction<Profile>(),
Gudhi::contraction::make_remove_popable_blockers_visitor<Profile>());
contractor.contract_edges();
std::cout << "Counting final number of simplices \n";
unsigned num_simplices = std::distance(complex.complex_simplex_range().begin(), complex.complex_simplex_range().end());
std::cout << "Final complex has " <<
complex.num_vertices() << " vertices, " <<
complex.num_edges() << " edges, " <<
complex.num_blockers() << " blockers and " <<
num_simplices << " simplices" << std::endl;
std::cout << contraction_chrono;
return EXIT_SUCCESS;
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:32:59 for GUDHI by Doxygen 1.8.13
