#include <boost/variant.hpp>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Points_3D_off_io.h>
#include <CGAL/Periodic_3_regular_triangulation_traits_3.h>
#include <CGAL/Periodic_3_regular_triangulation_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <CGAL/Alpha_shape_cell_base_3.h>
#include <CGAL/Alpha_shape_vertex_base_3.h>
#include <CGAL/iterator.h>
#include <fstream>
#include <cmath>
#include <string>
#include <tuple>
#include <map>
#include <utility>
#include <vector>
#include <cstdlib>
#include "alpha_complex_3d_helper.h"
using Kernel = CGAL::Exact_predicates_inexact_constructions_kernel;
using PK = CGAL::Periodic_3_regular_triangulation_traits_3<Kernel>;
using DsVb = CGAL::Periodic_3_triangulation_ds_vertex_base_3<>;
using Vb = CGAL::Regular_triangulation_vertex_base_3<PK, DsVb>;
using AsVb = CGAL::Alpha_shape_vertex_base_3<PK, Vb>;
using DsCb = CGAL::Periodic_3_triangulation_ds_cell_base_3<>;
using Cb = CGAL::Regular_triangulation_cell_base_3<PK, DsCb>;
using AsCb = CGAL::Alpha_shape_cell_base_3<PK, Cb>;
using Tds = CGAL::Triangulation_data_structure_3<AsVb, AsCb>;
using P3RT3 = CGAL::Periodic_3_regular_triangulation_3<PK, Tds>;
using Alpha_shape_3 = CGAL::Alpha_shape_3<P3RT3>;
using Point_3 = P3RT3::Bare_point;
using Weighted_point_3 = P3RT3::Weighted_point;
using Alpha_value_type = Alpha_shape_3::FT;
using Object = CGAL::Object;
using Dispatch =
CGAL::Dispatch_output_iterator<CGAL::cpp11::tuple<Object, Alpha_value_type>,
CGAL::cpp11::tuple<std::back_insert_iterator<std::vector<Object> >,
std::back_insert_iterator<std::vector<Alpha_value_type> > > >;
using Cell_handle = Alpha_shape_3::Cell_handle;
using Facet = Alpha_shape_3::Facet;
using Edge_3 = Alpha_shape_3::Edge;
using Vertex_handle = Alpha_shape_3::Vertex_handle;
using Vertex_list = std::vector<Alpha_shape_3::Vertex_handle>;
using Alpha_shape_simplex_tree_map = std::map<Alpha_shape_3::Vertex_handle, Simplex_tree_vertex>;
using Simplex_tree_vector_vertex = std::vector<Simplex_tree_vertex>;
void usage(const std::string& progName) {
std::cerr << "Usage: " << progName << " path_to_the_OFF_file path_to_weight_file path_to_the_cuboid_file "
"coeff_field_characteristic[integer > 0] min_persistence[float >= -1.0]\n";
exit(-1);
int main(int argc, char* const argv[]) {
if (argc != 6) {
std::cerr << "Error: Number of arguments (" << argc << ") is not correct\n";
usage(argv[0]);
int coeff_field_characteristic = atoi(argv[4]);
std::string offInputFile(argv[1]);
std::cerr << "Unable to read file " << offInputFile << std::endl;
usage(argv[0]);
std::ifstream iso_cuboid_str(argv[3]);
double x_min, y_min, z_min, x_max, y_max, z_max;
if (iso_cuboid_str.is_open()) {
if (!(iso_cuboid_str >> x_min >> y_min >> z_min >> x_max >> y_max >> z_max)) {
std::cerr << argv[3] << " - Bad file format." << std::endl;
usage(argv[0]);
} else {
std::cerr << "Unable to read file " << argv[3] << std::endl;
usage(argv[0]);
if ((x_max - x_min != y_max - y_min) || (x_max - x_min != z_max - z_min) || (z_max - z_min != y_max - y_min)) {
std::cerr << "The size of the cuboid in every directions is not the same." << std::endl;
exit(-1);
double maximal_possible_weight = 0.015625 * (x_max - x_min) * (x_max - x_min);
std::ifstream weights_ifstr(argv[2]);
std::vector<Weighted_point_3> wp;
if (weights_ifstr.is_open()) {
double weight = 0.0;
std::size_t index = 0;
wp.reserve(lp.size());
while ((weights_ifstr >> weight) && (index < lp.size())) {
if ((weight >= maximal_possible_weight) || (weight < 0)) {
std::cerr << "At line " << (index + 1) << ", the weight (" << weight
<< ") is negative or more than or equal to maximal possible weight (" << maximal_possible_weight
<< ") = 1/64*cuboid length squared, which is not an acceptable input." << std::endl;
exit(-1);
wp.push_back(Weighted_point_3(lp[index], weight));
index++;
if (index != lp.size()) {
std::cerr << "Bad number of weights in file " << argv[2] << std::endl;
usage(argv[0]);
} else {
std::cerr << "Unable to read file " << argv[2] << std::endl;
usage(argv[0]);
P3RT3 prt(PK::Iso_cuboid_3(x_min, y_min, z_min, x_max, y_max, z_max));
prt.insert(wp.begin(), wp.end(), true);
if (prt.is_triangulation_in_1_sheet()) {
prt.convert_to_1_sheeted_covering();
} else {
std::cerr << "ERROR: we were not able to construct a triangulation within a single periodic domain." << std::endl;
exit(-1);
std::cout << "Weighted Periodic Delaunay computed." << std::endl;
Alpha_shape_3 as(prt, 0, Alpha_shape_3::GENERAL);
std::vector<Object> the_objects;
std::vector<Alpha_value_type> the_alpha_values;
Dispatch disp = CGAL::dispatch_output<Object, Alpha_value_type>(std::back_inserter(the_objects),
std::back_inserter(the_alpha_values));
as.filtration_with_alpha_values(disp);
#ifdef DEBUG_TRACES
std::cout << "filtration_with_alpha_values returns : " << the_objects.size() << " objects" << std::endl;
#endif // DEBUG_TRACES
Alpha_shape_3::size_type count_vertices = 0;
Alpha_shape_3::size_type count_edges = 0;
Alpha_shape_3::size_type count_facets = 0;
Alpha_shape_3::size_type count_cells = 0;
Vertex_list vertex_list;
Alpha_shape_simplex_tree_map map_cgal_simplex_tree;
std::vector<Alpha_value_type>::iterator the_alpha_value_iterator = the_alpha_values.begin();
for (auto object_iterator : the_objects) {
if (const Cell_handle* cell = CGAL::object_cast<Cell_handle>(&object_iterator)) {
vertex_list = from_cell<Vertex_list, Cell_handle>(*cell);
count_cells++;
} else if (const Facet* facet = CGAL::object_cast<Facet>(&object_iterator)) {
vertex_list = from_facet<Vertex_list, Facet>(*facet);
count_facets++;
} else if (const Edge_3* edge = CGAL::object_cast<Edge_3>(&object_iterator)) {
vertex_list = from_edge<Vertex_list, Edge_3>(*edge);
count_edges++;
} else if (const Vertex_handle* vertex = CGAL::object_cast<Vertex_handle>(&object_iterator)) {
count_vertices++;
vertex_list = from_vertex<Vertex_list, Vertex_handle>(*vertex);
Simplex_tree_vector_vertex the_simplex;
for (auto the_alpha_shape_vertex : vertex_list) {
Alpha_shape_simplex_tree_map::iterator the_map_iterator = map_cgal_simplex_tree.find(the_alpha_shape_vertex);
if (the_map_iterator == map_cgal_simplex_tree.end()) {
#ifdef DEBUG_TRACES
std::cout << "vertex [" << the_alpha_shape_vertex->point() << "] not found - insert " << vertex << std::endl;
the_simplex.push_back(vertex);
map_cgal_simplex_tree.emplace(the_alpha_shape_vertex, vertex);
} else {
#ifdef DEBUG_TRACES
std::cout << "vertex [" << the_alpha_shape_vertex->point() << "] found in " << vertex << std::endl;
#ifdef DEBUG_TRACES
std::cout << "filtration = " << filtr << std::endl;
if (the_alpha_value_iterator != the_alpha_values.end())
++the_alpha_value_iterator;
else
std::cout << "This shall not happen" << std::endl;
#ifdef DEBUG_TRACES
std::cout << "vertices \t\t" << count_vertices << std::endl;
std::cout << "edges \t\t" << count_edges << std::endl;
std::cout << "facets \t\t" << count_facets << std::endl;
std::cout << "cells \t\t" << count_cells << std::endl;
std::cout << "Information of the Simplex Tree: " << std::endl;
std::cout <<
" Number of vertices = " << simplex_tree.
num_vertices() <<
std::cout <<
" Number of simplices = " << simplex_tree.
num_simplices() << std::endl << std::endl;
std::cout <<
" Dimension = " << simplex_tree.
dimension() <<
#ifdef DEBUG_TRACES
std::cout << "Iterator on vertices: " << std::endl;
std::cout << vertex << " ";
std::cout <<
"Simplex_tree dim: " << simplex_tree.
dimension() << std::endl;
return 0;
