Gudhi::skeleton_blocker::Skeleton_blocker_link_superior< ComplexType > Member List
This is the complete list of members for Gudhi::skeleton_blocker::Skeleton_blocker_link_superior< ComplexType >, including all inherited members.
add_blocker(const Root_simplex_handle &blocker_root)Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inline
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_blocker(const Simplex &blocker)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
add_edge(Vertex_handle a, Vertex_handle b)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
add_edge(const Simplex &s)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
add_edge_without_blockers(Root_vertex_handle v1_root, Root_vertex_handle v2_root)Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inline
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_edge_without_blockers(Vertex_handle a, Vertex_handle b)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_edge_without_blockers(Simplex s)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
add_simplex(const Simplex &sigma)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
add_vertex(Root_vertex_handle global)Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inline
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_vertex()Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
blocker_range(Vertex_handle v)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
blocker_range()Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
build_link(const ComplexType &parent_complex, const Simplex &alpha_parent_adress, bool is_alpha_blocker=false, bool only_vertices=false)Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType >inline
clear()Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inlinevirtual
coboundary_range(const Simplex &s) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
Complex_coboundary_range typedefGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
Complex_simplex_around_vertex_range typedefGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
complex_simplex_range() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
const_blocker_range(Vertex_handle v) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
const_blocker_range() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contains(const Simplex &s) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inlinevirtual
contains_blocker(const Blocker_handle s) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contains_blocker(const Simplex &s) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contains_edge(Vertex_handle a, Vertex_handle b) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contains_edges(const Simplex &sigma) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contains_vertices(const Simplex &sigma) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contract_edge(Edge_handle edge)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
contract_edge(Vertex_handle a, Vertex_handle b)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
convert_handle_from_another_complex(const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
degree(Vertex_handle local) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
delete_blocker(Blocker_handle sigma)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
edge_range() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
edge_range(Vertex_handle v) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
first_vertex(Edge_handle edge_handle) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
get_address(Root_vertex_handle global) constGudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inline
Gudhi::skeleton_blocker::Skeleton_blocker_complex::get_address(Root_vertex_handle id) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inlinevirtual
get_addresses(const Root_simplex_handle &s) constGudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inline
get_id(Vertex_handle local) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
get_id(const Simplex &local_simplex) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
get_simplex_address(const Root_simplex_handle &s) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
get_vertices(Edge_handle edge_handle) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
Graph_edge typedefGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
Graph_vertex typedefGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
is_cone() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
is_contractible() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inlinevirtual
is_popable_blocker(Blocker_handle sigma) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
keep_only_vertices()Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
link(Vertex_handle v) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
link(Edge_handle edge) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
link(const Simplex &simplex) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
link_condition(Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
link_condition(Edge_handle e, bool ignore_popable_blockers=false) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
make_restricted_complex(const ComplexType &parent_complex, const Simplex &simplex)Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >inline
num_connected_components() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator==(const Skeleton_blocker_complex &other) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator[](Root_vertex_handle global) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator[](Vertex_handle address)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator[](Vertex_handle address) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator[](const std::pair< Vertex_handle, Vertex_handle > &ab) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator[](Edge_handle edge_handle)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
operator[](Edge_handle edge_handle) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
remove_all_popable_blockers(Vertex_handle v)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_blocker(const Blocker_handle sigma)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
remove_blockers()Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
remove_edge(Vertex_handle a, Vertex_handle b)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inlinevirtual
remove_edge(Edge_handle edge)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
remove_popable_blockers()Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_popable_blockers(Vertex_handle v)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_star(Vertex_handle v)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_star(Vertex_handle a, Vertex_handle b)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_star(Edge_handle e)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_star(const Simplex &sigma)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
remove_vertex(Vertex_handle address)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
second_vertex(Edge_handle edge_handle) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
set_visitor(Visitor *other_visitor)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
Skeleton_blocker_complex(size_t num_vertices_=0, Visitor *visitor_=NULL)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inlineexplicit
Skeleton_blocker_complex(SimpleHandleOutputIterator simplices_begin, SimpleHandleOutputIterator simplices_end, bool is_flag_complex=false, Visitor *visitor_=NULL)Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
Skeleton_blocker_link_complex(const ComplexType &parent_complex, const Simplex &alpha_parent_adress, bool only_superior_vertices=false, bool only_vertices=false)Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType >inline
Skeleton_blocker_link_complex(const ComplexType &parent_complex, Vertex_handle a_parent_adress, bool only_superior_vertices=false)Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType >inline
Skeleton_blocker_link_complex(const ComplexType &parent_complex, Edge_handle edge, bool only_superior_vertices=false)Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType >inline
star_simplex_range(Vertex_handle v) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
triangle_range(Vertex_handle v) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
triangle_range() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
vertex_range() constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
vertex_range(Vertex_handle v) constGudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inline
~Skeleton_blocker_complex()Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >inlinevirtual
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:56 for GUDHI by Doxygen 1.8.13
