Gudhi::Persistence_representations::Persistence_landscape Member List
This is the complete list of members for Gudhi::Persistence_representations::Persistence_landscape, including all inherited members.
abs()Gudhi::Persistence_representations::Persistence_landscape
add_two_landscapes(const Persistence_landscape &land1, const Persistence_landscape &land2)Gudhi::Persistence_representations::Persistence_landscapefriend
compute_average(const std::vector< Persistence_landscape *> &to_average)Gudhi::Persistence_representations::Persistence_landscapeinline
compute_distance_of_landscapes(const Persistence_landscape &first, const Persistence_landscape &second, double p)Gudhi::Persistence_representations::Persistence_landscapefriend
compute_inner_product(const Persistence_landscape &l1, const Persistence_landscape &l2)Gudhi::Persistence_representations::Persistence_landscapefriend
compute_integral_of_a_level_of_a_landscape(size_t level) constGudhi::Persistence_representations::Persistence_landscape
compute_integral_of_landscape() constGudhi::Persistence_representations::Persistence_landscape
compute_integral_of_landscape(double p) constGudhi::Persistence_representations::Persistence_landscape
compute_max_norm_distance_of_landscapes(const Persistence_landscape &first, const Persistence_landscape &second)Gudhi::Persistence_representations::Persistence_landscapefriend
compute_maximum() constGudhi::Persistence_representations::Persistence_landscapeinline
compute_scalar_product(const Persistence_landscape &second) constGudhi::Persistence_representations::Persistence_landscapeinline
compute_value_at_a_given_point(unsigned level, double x) constGudhi::Persistence_representations::Persistence_landscape
distance(const Persistence_landscape &second, double power=1) constGudhi::Persistence_representations::Persistence_landscapeinline
find_max(unsigned lambda) constGudhi::Persistence_representations::Persistence_landscape
get_y_range(size_t level=0) constGudhi::Persistence_representations::Persistence_landscapeinline
load_landscape_from_file(const char *filename)Gudhi::Persistence_representations::Persistence_landscape
number_of_projections_to_R() constGudhi::Persistence_representations::Persistence_landscapeinline
number_of_vectorize_functions() constGudhi::Persistence_representations::Persistence_landscapeinline
operator!=(const Persistence_landscape &rhs) constGudhi::Persistence_representations::Persistence_landscapeinline
operator()(unsigned level, double x) constGudhi::Persistence_representations::Persistence_landscapeinline
operator*(const Persistence_landscape &first, double con)Gudhi::Persistence_representations::Persistence_landscapefriend
operator*(double con, const Persistence_landscape &first)Gudhi::Persistence_representations::Persistence_landscapefriend
operator*=(double x)Gudhi::Persistence_representations::Persistence_landscapeinline
operator+(const Persistence_landscape &first, const Persistence_landscape &second)Gudhi::Persistence_representations::Persistence_landscapefriend
operator+=(const Persistence_landscape &rhs)Gudhi::Persistence_representations::Persistence_landscapeinline
operator-(const Persistence_landscape &first, const Persistence_landscape &second)Gudhi::Persistence_representations::Persistence_landscapefriend
operator-=(const Persistence_landscape &rhs)Gudhi::Persistence_representations::Persistence_landscapeinline
operator/=(double x)Gudhi::Persistence_representations::Persistence_landscapeinline
operator<<(std::ostream &out, Persistence_landscape &land)Gudhi::Persistence_representations::Persistence_landscapefriend
operator==(const Persistence_landscape &rhs) constGudhi::Persistence_representations::Persistence_landscape
Persistence_landscape()Gudhi::Persistence_representations::Persistence_landscapeinline
Persistence_landscape(const std::vector< std::pair< double, double > > &p, size_t number_of_levels=std::numeric_limits< size_t >::max())Gudhi::Persistence_representations::Persistence_landscape
Persistence_landscape(const char *filename, size_t dimension=std::numeric_limits< unsigned >::max(), size_t number_of_levels=std::numeric_limits< size_t >::max())Gudhi::Persistence_representations::Persistence_landscape
print_to_file(const char *filename) constGudhi::Persistence_representations::Persistence_landscape
project_to_R(int number_of_function) constGudhi::Persistence_representations::Persistence_landscapeinline
size() constGudhi::Persistence_representations::Persistence_landscapeinline
subtract_two_landscapes(const Persistence_landscape &land1, const Persistence_landscape &land2)Gudhi::Persistence_representations::Persistence_landscapefriend
vectorize(int number_of_function) constGudhi::Persistence_representations::Persistence_landscapeinline
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:55 for GUDHI by Doxygen 1.8.13
