SimplicialComplexForRips.h
1 /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): Vincent Rouvreau
6  *
7  * Copyright (C) 2016 Inria
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
23 #ifndef CONCEPT_RIPS_COMPLEX_SIMPLICIAL_COMPLEX_FOR_RIPS_H_
24 #define CONCEPT_RIPS_COMPLEX_SIMPLICIAL_COMPLEX_FOR_RIPS_H_
25
26 namespace Gudhi {
27
28 namespace rips_complex {
29
35  typedef unspecified Filtration_value;
36
38  template<class OneSkeletonGraph>
39  void insert_graph(const OneSkeletonGraph& skel_graph);
40
43  void expansion(int max_dim);
44
46  std::size_t num_vertices();
47
48 };
49
50 } // namespace rips_complex
51
52 } // namespace Gudhi
53
54 #endif // CONCEPT_RIPS_COMPLEX_SIMPLICIAL_COMPLEX_FOR_RIPS_H_
Expands the simplicial complex containing only its one skeleton until a given maximal dimension as ex...
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex...
The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial ...
Definition: SimplicialComplexForRips.h:33
Definition: SimplicialComplexForAlpha.h:26
Type used to store the filtration values of the simplicial complex.
Definition: SimplicialComplexForRips.h:35
Returns the number of vertices in the simplicial complex.
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:53 for GUDHI by Doxygen 1.8.13
