PersistentHomology.h
1  /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): ClĂ©ment Maria
6  *
7  * Copyright (C) 2014 Inria
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
26
32  typedef unspecified Filtered_complex;
33
39  typedef unspecified Coefficient_field;
40
41  };
Concept describing the requirements for a class to compute persistent homology.
Definition: PersistentHomology.h:25
Type of coefficients to be used for computing persistent homology.
Definition: PersistentHomology.h:39
Type of filtered cell complex on which persistent homology is computed.
Definition: PersistentHomology.h:32
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:53 for GUDHI by Doxygen 1.8.13
