Persistence_representations/persistence_landscapes_on_grid/plot_landscapes_on_grid.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/Persistence_landscape_on_grid.h>
#include <iostream>
#include <sstream>
int main(int argc, char** argv) {
std::cout << "This program creates a gnuplot script from a persistence landscape on grid stored in a file (the file "
<< "needs to be created beforehand). Please call the code with the name of a single landscape on grid file"
<< ".\n";
if (argc != 2) {
std::cout << "Wrong parameter list, the program will now terminate \n";
return 1;
l.plot(argv[1]);
return 0;
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:53 for GUDHI by Doxygen 1.8.13
