#include <boost/program_options.hpp>
#include <boost/variant.hpp>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Points_3D_off_io.h>
#include <CGAL/config.h>
#include <CGAL/Regular_triangulation_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <CGAL/Alpha_shape_cell_base_3.h>
#include <CGAL/Alpha_shape_vertex_base_3.h>
#include <CGAL/iterator.h>
#if CGAL_VERSION_NR < 1041100000
#include <CGAL/Regular_triangulation_euclidean_traits_3.h>
#endif // CGAL_VERSION_NR < 1041100000
#include <fstream>
#include <cmath>
#include <string>
#include <tuple>
#include <map>
#include <utility>
#include <vector>
#include <cstdlib>
#include "alpha_complex_3d_helper.h"
using Kernel = CGAL::Exact_predicates_inexact_constructions_kernel;
using Gt = CGAL::Regular_triangulation_euclidean_traits_3<Kernel>;
using Vb = CGAL::Alpha_shape_vertex_base_3<Gt>;
using Fb = CGAL::Alpha_shape_cell_base_3<Gt>;
using Tds = CGAL::Triangulation_data_structure_3<Vb, Fb>;
using Triangulation_3 = CGAL::Regular_triangulation_3<Gt, Tds>;
using Point_3 = Gt::Bare_point;
using Weighted_point_3 = Gt::Weighted_point;
#else // CGAL_VERSION_NR < 1041100000
using Rvb = CGAL::Regular_triangulation_vertex_base_3<Kernel>;
using Vb = CGAL::Alpha_shape_vertex_base_3<Kernel, Rvb>;
using Rcb = CGAL::Regular_triangulation_cell_base_3<Kernel>;
using Cb = CGAL::Alpha_shape_cell_base_3<Kernel, Rcb>;
using Tds = CGAL::Triangulation_data_structure_3<Vb, Cb>;
using Triangulation_3 = CGAL::Regular_triangulation_3<Kernel, Tds>;
using Point_3 = Triangulation_3::Bare_point;
using Weighted_point_3 = Triangulation_3::Weighted_point;
using Alpha_shape_3 = CGAL::Alpha_shape_3<Triangulation_3>;
using Alpha_value_type = Alpha_shape_3::FT;
using Object = CGAL::Object;
using Dispatch =
CGAL::Dispatch_output_iterator<CGAL::cpp11::tuple<Object, Alpha_value_type>,
CGAL::cpp11::tuple<std::back_insert_iterator<std::vector<Object> >,
std::back_insert_iterator<std::vector<Alpha_value_type> > > >;
using Cell_handle = Alpha_shape_3::Cell_handle;
using Facet = Alpha_shape_3::Facet;
using Edge_3 = Alpha_shape_3::Edge;
using Vertex_handle = Alpha_shape_3::Vertex_handle;
using Vertex_list = std::vector<Alpha_shape_3::Vertex_handle>;
using Alpha_shape_simplex_tree_map = std::map<Alpha_shape_3::Vertex_handle, Simplex_tree_vertex>;
using Simplex_tree_vector_vertex = std::vector<Simplex_tree_vertex>;
void program_options(int argc, char *argv[], std::string &off_file_points, std::string &weight_file,
std::string &output_file_diag,
int &coeff_field_characteristic,
Filtration_value &min_persistence);
int main(int argc, char **argv) {
std::string off_file_points;
std::string weight_file;
std::string output_file_diag;
int coeff_field_characteristic;
program_options(argc, argv, off_file_points, weight_file, output_file_diag, coeff_field_characteristic,
min_persistence);
if (!off_reader.is_valid()) {
std::cerr << "Unable to read OFF file " << off_file_points << std::endl;
exit(-1);
std::vector<Point_3> lp = off_reader.get_point_cloud();
std::ifstream weights_ifstr(weight_file);
std::vector<Weighted_point_3> wp;
if (weights_ifstr.good()) {
double weight = 0.0;
std::size_t index = 0;
wp.reserve(lp.size());
while ((weights_ifstr >> weight) && (index < lp.size())) {
wp.push_back(Weighted_point_3(lp[index], weight));
index++;
if (index != lp.size()) {
std::cerr << "Bad number of weights in file " << weight_file << std::endl;
exit(-1);
} else {
std::cerr << "Unable to read weights file " << weight_file << std::endl;
exit(-1);
Alpha_shape_3 as(wp.begin(), wp.end(), 0, Alpha_shape_3::GENERAL);
#ifdef DEBUG_TRACES
std::cout << "Alpha shape computed in GENERAL mode" << std::endl;
#endif // DEBUG_TRACES
std::vector<Object> the_objects;
std::vector<Alpha_value_type> the_alpha_values;
Dispatch disp = CGAL::dispatch_output<Object, Alpha_value_type>(std::back_inserter(the_objects),
std::back_inserter(the_alpha_values));
as.filtration_with_alpha_values(disp);
#ifdef DEBUG_TRACES
std::cout << "filtration_with_alpha_values returns : " << the_objects.size() << " objects" << std::endl;
Alpha_shape_3::size_type count_vertices = 0;
Alpha_shape_3::size_type count_edges = 0;
Alpha_shape_3::size_type count_facets = 0;
Alpha_shape_3::size_type count_cells = 0;
Vertex_list vertex_list;
Alpha_shape_simplex_tree_map map_cgal_simplex_tree;
std::vector<Alpha_value_type>::iterator the_alpha_value_iterator = the_alpha_values.begin();
for (auto object_iterator : the_objects) {
if (const Cell_handle *cell = CGAL::object_cast<Cell_handle>(&object_iterator)) {
vertex_list = from_cell<Vertex_list, Cell_handle>(*cell);
count_cells++;
} else if (const Facet *facet = CGAL::object_cast<Facet>(&object_iterator)) {
vertex_list = from_facet<Vertex_list, Facet>(*facet);
count_facets++;
} else if (const Edge_3 *edge = CGAL::object_cast<Edge_3>(&object_iterator)) {
vertex_list = from_edge<Vertex_list, Edge_3>(*edge);
count_edges++;
} else if (const Vertex_handle *vertex = CGAL::object_cast<Vertex_handle>(&object_iterator)) {
count_vertices++;
vertex_list = from_vertex<Vertex_list, Vertex_handle>(*vertex);
Simplex_tree_vector_vertex the_simplex;
for (auto the_alpha_shape_vertex : vertex_list) {
Alpha_shape_simplex_tree_map::iterator the_map_iterator = map_cgal_simplex_tree.find(the_alpha_shape_vertex);
if (the_map_iterator == map_cgal_simplex_tree.end()) {
#ifdef DEBUG_TRACES
std::cout << "vertex [" << the_alpha_shape_vertex->point() << "] not found - insert " << vertex << std::endl;
the_simplex.push_back(vertex);
map_cgal_simplex_tree.emplace(the_alpha_shape_vertex, vertex);
} else {
#ifdef DEBUG_TRACES
std::cout << "vertex [" << the_alpha_shape_vertex->point() << "] found in " << vertex << std::endl;
#ifdef DEBUG_TRACES
std::cout << "filtration = " << filtr << std::endl;
if (the_alpha_value_iterator != the_alpha_values.end())
++the_alpha_value_iterator;
else
std::cout << "This shall not happen" << std::endl;
#ifdef DEBUG_TRACES
std::cout << "vertices \t\t" << count_vertices << std::endl;
std::cout << "edges \t\t" << count_edges << std::endl;
std::cout << "facets \t\t" << count_facets << std::endl;
std::cout << "cells \t\t" << count_cells << std::endl;
std::cout << "Information of the Simplex Tree: " << std::endl;
std::cout <<
" Number of vertices = " << simplex_tree.
num_vertices() <<
std::cout <<
" Number of simplices = " << simplex_tree.
num_simplices() << std::endl << std::endl;
std::cout <<
" Dimension = " << simplex_tree.
dimension() <<
#ifdef DEBUG_TRACES
std::cout << "Iterator on vertices: " << std::endl;
std::cout << vertex << " ";
std::cout <<
"Simplex_tree dim: " << simplex_tree.
dimension() << std::endl;
pcoh.init_coefficients(coeff_field_characteristic);
pcoh.compute_persistent_cohomology(min_persistence);
if (output_file_diag.empty()) {
pcoh.output_diagram();
} else {
std::cout << "Result in file: " << output_file_diag << std::endl;
std::ofstream out(output_file_diag);
pcoh.output_diagram(out);
out.close();
return 0;
std::string &output_file_diag, int &coeff_field_characteristic,
namespace po = boost::program_options;
po::options_description hidden("Hidden options");
hidden.add_options()("input-file", po::value<std::string>(&off_file_points),
"Name of file containing a point set. Format is one point per line: X1 ... Xd ")(
"weight-file", po::value<std::string>(&weight_file),
"Name of file containing a point weights. Format is one weigt per line: W1\n...\nWn ");
po::options_description visible("Allowed options", 100);
visible.add_options()("help,h", "produce help message")(
"output-file,o", po::value<std::string>(&output_file_diag)->default_value(std::string()),
"Name of file in which the persistence diagram is written. Default print in std::cout")(
"field-charac,p", po::value<int>(&coeff_field_characteristic)->default_value(11),
"Characteristic p of the coefficient field Z/pZ for computing homology.")(
"min-persistence,m", po::value<Filtration_value>(&min_persistence),
"Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length "
"intervals");
po::positional_options_description pos;
pos.add("input-file", 1);
pos.add("weight-file", 2);
po::options_description all;
all.add(visible).add(hidden);
po::variables_map vm;
po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
po::notify(vm);
if (vm.count("help") || !vm.count("input-file") || !vm.count("weight-file")) {
std::cout << std::endl;
std::cout << "Compute the persistent homology with coefficient field Z/pZ \n";
std::cout << "of a weighted 3D Alpha complex defined on a set of input points.\n \n";
std::cout << "The output diagram contains one bar per line, written with the convention: \n";
std::cout << " p dim b d \n";
std::cout << "where dim is the dimension of the homological feature,\n";
std::cout << "b and d are respectively the birth and death of the feature and \n";
std::cout << "p is the characteristic of the field Z/pZ used for homology coefficients." << std::endl << std::endl;
std::cout << "Usage: " << argv[0] << " [options] input-file weight-file" << std::endl << std::endl;
std::cout << visible << std::endl;
std::abort();
