Cubical complex represented as a bitmap, class with basic implementation. More...
Classes | |
| class | All_cells_iterator |
| Iterator through all cells in the complex (in order they appear in the structure – i.e. in lexicographical order). More... | |
| class | All_cells_range |
| All_cells_range class provides ranges for All_cells_iterator. More... | |
| class | Top_dimensional_cells_iterator |
| Iterator through top dimensional cells of the complex. The cells appear in order they are stored in the structure (i.e. in lexicographical order) More... | |
| class | Top_dimensional_cells_range |
| Top_dimensional_cells_iterator_range class provides ranges for Top_dimensional_cells_iterator_range. More... | |
Public Types | |
| typedef std::vector< size_t >::const_iterator | Boundary_iterator |
| typedef std::vector< size_t >::const_iterator | Coboundary_iterator |
Public Member Functions | |
| Bitmap_cubical_complex_base () | |
| Bitmap_cubical_complex_base (const std::vector< unsigned > &sizes) | |
| Bitmap_cubical_complex_base (const char *perseus_style_file) | |
| Bitmap_cubical_complex_base (const std::vector< unsigned > &dimensions, const std::vector< T > &top_dimensional_cells) | |
| virtual | ~Bitmap_cubical_complex_base () |
| virtual std::vector< size_t > | get_boundary_of_a_cell (size_t cell) const |
| virtual std::vector< size_t > | get_coboundary_of_a_cell (size_t cell) const |
| unsigned | get_dimension_of_a_cell (size_t cell) const |
| T & | get_cell_data (size_t cell) |
| void | impose_lower_star_filtration () |
| unsigned | dimension () const |
| unsigned | size () const |
| void | put_data_to_bins (size_t number_of_bins) |
| void | put_data_to_bins (T diameter_of_bin) |
| std::pair< T, T > | min_max_filtration () |
| All_cells_iterator | all_cells_iterator_begin () |
| All_cells_iterator | all_cells_iterator_end () |
| Boundary_range | boundary_range (size_t sh) |
| Coboundary_range | coboundary_range (size_t sh) |
| Top_dimensional_cells_iterator | top_dimensional_cells_iterator_begin () |
| Top_dimensional_cells_iterator | top_dimensional_cells_iterator_end () |
Friends | |
| template<typename K > | |
| std::ostream & | operator<< (std::ostream &os, const Bitmap_cubical_complex_base< K > &b) |
This is a class implementing a basic bitmap data structure to store cubical complexes. It implements only the most basic subroutines. The idea of the bitmap is the following. Our aim is to have a memory efficient data structure to store d-dimensional cubical complex C being a cubical decomposition of a rectangular region of a space. This is achieved by storing C as a vector of bits (this is where the name 'bitmap' came from). Each cell is represented by a single bit (in case of black and white bitmaps, or by a single element of a type T (here T is a filtration type of a bitmap, typically a double). All the informations needed for homology and persistent homology computations (like dimension of a cell, boundary and coboundary elements of a cell, are then obtained from the position of the element in C. The default filtration used in this implementation is the lower star filtration.
| typedef std::vector< size_t >::const_iterator Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Boundary_iterator |
Boundary_range class provides ranges for boundary iterators.
| typedef std::vector< size_t >::const_iterator Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Coboundary_iterator |
Coboundary_range class provides ranges for boundary iterators.
inline |
Default constructor
| Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Bitmap_cubical_complex_base | ( | const std::vector< unsigned > & | sizes | ) |
There are a few constructors of a Bitmap_cubical_complex_base class. First one, that takes vector<unsigned>, creates an empty bitmap of a dimension equal the number of elements in the input vector and size in the i-th dimension equal the number in the position i-of the input vector.
| Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Bitmap_cubical_complex_base | ( | const char * | perseus_style_file | ) |
The second constructor takes as a input a Perseus style file. For more details, please consult the documentations of Perseus software as well as examples attached to this implementation.
| Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::Bitmap_cubical_complex_base | ( | const std::vector< unsigned > & | dimensions, |
| const std::vector< T > & | top_dimensional_cells | ||
The last constructor of a Bitmap_cubical_complex_base class accepts vector of dimensions (as the first one) together with vector of filtration values of top dimensional cells.
inlinevirtual |
Destructor of the Bitmap_cubical_complex_base class.
inline |
Function returning a All_cells_iterator to the first cell of the bitmap.
inline |
Function returning a All_cells_iterator to the last cell of the bitmap.
inline |
boundary_simplex_range creates an object of a Boundary_simplex_range class that provides ranges for the Boundary_simplex_iterator.
inline |
inline |
Returns dimension of a complex.
inlinevirtual |
The functions get_boundary_of_a_cell, get_coboundary_of_a_cell, get_dimension_of_a_cell and get_cell_data are the basic functions that compute boundary / coboundary / dimension and the filtration value form a position of a cell in the structure of a bitmap. The input parameter of all of those function is a non-negative integer, indicating a position of a cube in the data structure. In the case of functions that compute (co)boundary, the output is a vector if non-negative integers pointing to the positions of (co)boundary element of the input cell.
Reimplemented in Gudhi::cubical_complex::Bitmap_cubical_complex_periodic_boundary_conditions_base< T >.
inline |
In the case of get_cell_data, the output parameter is a reference to the value of a cube in a given position. This allows reading and changing the value of filtration. Note that if the value of a filtration is changed, the code do not check if we have a filtration or not. i.e. it do not check if the value of a filtration of a cell is not smaller than the value of a filtration of its boundary and not greater than the value of its coboundary.
inlinevirtual |
The functions get_coboundary_of_a_cell, get_coboundary_of_a_cell, get_dimension_of_a_cell and get_cell_data are the basic functions that compute boundary / coboundary / dimension and the filtration value form a position of a cell in the structure of a bitmap. The input parameter of all of those function is a non-negative integer, indicating a position of a cube in the data structure. In the case of functions that compute (co)boundary, the output is a vector if non-negative integers pointing to the positions of (co)boundary element of the input cell.
inline |
In the case of get_dimension_of_a_cell function, the output is a non-negative integer indicating the dimension of a cell.
| void Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::impose_lower_star_filtration | ( | ) |
Typical input used to construct a baseBitmap class is a filtration given at the top dimensional cells. Then, there are a few ways one can pick the filtration of lower dimensional cells. The most typical one is by so called lower star filtration. This function is always called by any constructor which takes the top dimensional cells. If you use such a constructor, then there is no need to call this function. Call it only if you are putting the filtration of the cells by your own (for instance by using Top_dimensional_cells_iterator).
| std::pair< T, T > Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::min_max_filtration | ( | ) |
Functions to find min and max values of filtration.
| void Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::put_data_to_bins | ( | size_t | number_of_bins | ) |
Function that put the input data to bins. By putting data to bins we mean rounding them to a sequence of values equally distributed in the range of data. Sometimes if most of the cells have different birth-death times, the performance of the algorithms to compute persistence gets worst. When dealing with this type of data, one may want to put different values on cells to some number of bins. The function put_data_to_bins( size_t number_of_bins ) is designed for that purpose. The parameter of the function is the number of bins (distinct values) we want to have in the cubical complex.
| void Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >::put_data_to_bins | ( | T | diameter_of_bin | ) |
Function that put the input data to bins. By putting data to bins we mean rounding them to a sequence of values equally distributed in the range of data. Sometimes if most of the cells have different birth-death times, the performance of the algorithms to compute persistence gets worst. When dealing with this type of data, one may want to put different values on cells to some number of bins. The function put_data_to_bins( T diameter_of_bin ) is designed for that purpose. The parameter of it is the diameter of each bin. Note that the bottleneck distance between the persistence diagram of the cubical complex before and after using such a function will be bounded by the parameter diameter_of_bin.
inline |
Returns number of all cubes in the data structure.
inline |
Function returning a Top_dimensional_cells_iterator to the first top dimensional cell of the bitmap.
inline |
Function returning a Top_dimensional_cells_iterator to the last top dimensional cell of the bitmap.
friend |
Writing to stream operator. By using it we get the values T of cells in order in which they are stored in the structure. This procedure is used for debugging purposes.
| GUDHI Version 2.0.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. |
Generated on Mon Oct 2 2017 10:20:49 for GUDHI by
1.8.11
