All Classes Functions Variables Typedefs Friends Groups Pages
PersistentHomology Struct Reference
Concept describing the requirements for a class to compute persistent homology. More...
#include <Persistent_cohomology/PersistentHomology.h>
Public Types
typedef unspecified Filtered_complex
 Type of filtered cell complex on which persistent homology is computed. More...
typedef unspecified Coefficient_field
 Type of coefficients to be used for computing persistent homology. More...
Detailed Description
Member Typedef Documentation
Must be a model of concept CoefficientField.
Must be a model of concept FilteredComplex.
The documentation for this struct was generated from the following file:
GUDHI  Version 1.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. Generated on Fri Apr 15 2016 17:36:21 for GUDHI by doxygen 1.8.6
