All Classes Functions Variables Typedefs Friends Groups Pages
Gudhi::Off_reader Class Reference
OFF file reader top class visitor. More...
#include <gudhi/Off_reader.h>
Public Member Functions
template<typename OffVisitor >
bool read (OffVisitor &off_visitor)
 Read an OFF file and calls the following methods : More...
Detailed Description
OFF file must be conform to format described here : http://www.geomview.org/docs/html/OFF.html
Member Function Documentation
bool Gudhi::Off_reader::read ( OffVisitor &  off_visitor)
inline
void init(int dim,int num_vertices,int num_faces,int num_edges); // from file header - num_edges may not be set
void point(const std::vector<double>& point); // for each point read
void maximal_face(const std::list<int>& face); // for each face read
void done(); // upon file read is finished
of the visitor when reading a point or a maximal face. Edges are not taken into account.
The documentation for this class was generated from the following file:
GUDHI  Version 1.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. Generated on Fri Apr 15 2016 17:36:21 for GUDHI by doxygen 1.8.6
