Tangential complex reference manual¶
class
gudhi.TangentialComplex¶ Bases:
objectThe class Tangential_complex represents a tangential complex. After the computation of the complex, an optional post-processing called perturbation can be run to attempt to remove inconsistencies.
__init__()¶ TangentialComplex constructor.
Parameters: points (list of list of double) – A list of points in d-Dimension. Or
Parameters: off_file (string) – An OFF file style name.
create_simplex_tree()¶ Exports the complex into a simplex tree.
Returns: A simplex tree created from the complex. Return type: SimplexTree
fix_inconsistencies_using_perturbation()¶ Attempts to fix inconsistencies by perturbing the point positions.
Parameters: - max_perturb (double) – Maximum length of the translations used by the perturbation.
- time_limit (double) – Time limit in seconds. If -1, no time limit is set.
get_point()¶ This function returns the point corresponding to a given vertex.
Parameters: vertex (int.) – The vertex. Returns: The point. Return type: list of float
num_inconsistent_simplices()¶ Returns: The number of inconsistent simplices. Return type: unsigned
num_inconsistent_stars()¶ Returns: The number of stars containing at least one inconsistent simplex. Return type: unsigned
num_simplices()¶ Returns: Total number of simplices in stars (including duplicates that appear in several stars). Return type: unsigned
num_vertices()¶ Returns: The number of vertices. Return type: unsigned
