Cubical complex reference manual¶
class
gudhi.CubicalComplex¶ Bases:
objectThe CubicalComplex is an example of a structured complex useful in computational mathematics (specially rigorous numerics) and image analysis.
__init__()¶ CubicalComplex constructor from dimensions and top_dimensional_cells or from a Perseus-style file name.
Parameters: - dimensions (list of int) – A list of number of top dimensional cells.
- top_dimensional_cells (list of double) – A list of cells filtration values.
Or
Parameters: perseus_file (string) – A Perseus-style file name.
betti_numbers()¶ This function returns the Betti numbers of the simplicial complex.
Returns: list of int – The Betti numbers ([B0, B1, ..., Bn]). Note: betti_numbers function requires persistence function to be launched first.
dimension()¶ This function returns the dimension of the simplicial complex.
Returns: int – the simplicial complex dimension.
num_simplices()¶ This function returns the number of simplices of the simplicial complex.
Returns: int – the simplicial complex number of simplices.
persistence()¶ This function returns the persistence of the simplicial complex.
Parameters: - homology_coeff_field (int.) – The homology coefficient field. Must be a prime number
- min_persistence (float.) – The minimum persistence value to take into account (strictly greater than min_persistence). Default value is 0.0. Sets min_persistence to -1.0 to see all values.
Returns: list of pairs(dimension, pair(birth, death)) – the persistence of the simplicial complex.
persistence_intervals_in_dimension()¶ This function returns the persistence intervals of the simplicial complex in a specific dimension.
Parameters: dimension – The specific dimension. Returns: The persistence intervals. Return type: list of pair of float Note: intervals_in_dim function requires persistence function to be launched first.
persistent_betti_numbers()¶ This function returns the persistent Betti numbers of the simplicial complex.
Parameters: - from_value (float.) – The persistence birth limit to be added in the numbers (persistent birth <= from_value).
- to_value (float.) – The persistence death limit to be added in the numbers (persistent death > to_value).
Returns: list of int – The persistent Betti numbers ([B0, B1, ..., Bn]).
Note: persistent_betti_numbers function requires persistence function to be launched first.
