Rips complex reference manual¶
class
gudhi.
RipsComplex
¶ Bases:
object
The data structure is a one skeleton graph, or Rips graph, containing edges when the edge length is less or equal to a given threshold. Edge length is computed from a user given point cloud with a given distance function, or a distance matrix.
__init__
()¶ RipsComplex constructor.
Parameters: - max_edge_length (int) – Rips value.
- points (list of list of double) – A list of points in d-Dimension.
Or
Parameters: off_file (string) – An OFF file style name. Or
Parameters: distance_matrix – A distance matrix (full square or lower triangular). :type points: list of list of double
Or
Parameters: csv_file – A csv file style name containing a full square or a lower triangular distance matrix. :type csv_file: string
create_simplex_tree
()¶ Parameters: max_dimension (int) – graph expansion for rips until this given maximal dimension. Returns: A simplex tree created from the Delaunay Triangulation. Return type: SimplexTree
