Persistence graphical tools reference manual¶
gudhi.__min_birth_max_death()¶ This function returns (min_birth, max_death) from the persistence.
Parameters: - persistence (list of tuples(dimension, tuple(birth, death)).) – The persistence to plot.
- band_boot (float.) – bootstrap band
Returns: (float, float) – (min_birth, max_death).
gudhi.show_palette_values()¶ This function shows palette color values in function of the dimension.
Parameters: alpha (float.) – alpha value in [0.0, 1.0] for horizontal bars (default is 0.6). Returns: plot the dimension palette values.
gudhi.plot_persistence_barcode()¶ This function plots the persistence bar code.
- persistence_file (string) – A persistence file style name (reset persistence if both are set).
- alpha (float.) – alpha value in [0.0, 1.0] for horizontal bars (default is 0.6).
- max_barcodes (int.) – number of maximal barcodes to be displayed (persistence will be sorted by life time if max_barcodes is set)
Returns: plot – An horizontal bar plot of persistence.
gudhi.plot_persistence_diagram()¶ This function plots the persistence diagram with an optional confidence band.
- alpha (float.) – alpha value in [0.0, 1.0] for points and horizontal infinity line (default is 0.6).
- band_boot (float.) – bootstrap band (not displayed if \(\leq\) 0.)
- max_plots (int.) – number of maximal plots to be displayed
Returns: plot – A diagram plot of persistence.
