Tangential complex reference manual
class gudhi.TangentialComplex
Bases: object
The class Tangential_complex represents a tangential complex. After the computation of the complex, an optional post-processing called perturbation can be run to attempt to remove inconsistencies.
__init__()
TangentialComplex constructor.
Parameters:points (list of list of double) – A list of points in d-Dimension.
Or
Parameters:off_file (string) – An OFF file style name.
create_simplex_tree()
Exports the complex into a simplex tree.
Returns:A simplex tree created from the complex.
Return type:SimplexTree
fix_inconsistencies_using_perturbation()
Attempts to fix inconsistencies by perturbing the point positions.
Parameters:
  • max_perturb (double) – Maximum length of the translations used by the perturbation.
  • time_limit (double) – Time limit in seconds. If -1, no time limit is set.
get_point()
This function returns the point corresponding to a given vertex.
Parameters:vertex (int.) – The vertex.
Returns:The point.
Return type:list of float
num_inconsistent_simplices()
Returns:The number of inconsistent simplices.
Return type:unsigned
num_inconsistent_stars()
Returns:The number of stars containing at least one inconsistent simplex.
num_simplices()
Returns:Total number of simplices in stars (including duplicates that appear in several stars).
num_vertices()
Returns:The number of vertices.
