Rips complex user manual¶
Definition¶
| Rips complex user manual | Rips complex reference manual |
Rips complex is a one skeleton graph that allows to construct a simplicial complex from it. The input can be a point cloud with a given distance function, or a distance matrix.
The filtration value of each edge is computed from a user-given distance function, or directly from the distance matrix.
All edges that have a filtration value strictly greater than a given threshold value are not inserted into the complex.
When creating a simplicial complex from this one skeleton graph, Rips inserts the one skeleton graph into the data structure, and then expands the simplicial complex when required.
Vertex name correspond to the index of the point in the given range (aka. the point cloud).
Rips-complex one skeleton graph representation
On this example, as edges (4,5), (4,6) and (5,6) are in the complex, simplex (4,5,6) is added with the filtration value set with \(max(filtration(4,5), filtration(4,6), filtration(5,6))\). And so on for simplex (0,1,2,3).
If the Rips_complex interfaces are not detailed enough for your need, please refer to rips_persistence_step_by_step.cpp example, where the graph construction over the Simplex_tree is more detailed.
Point cloud¶
Example from a point cloud¶
This example builds the one skeleton graph from the given points, and max_edge_length value. Then it creates a Simplex_tree with it.
Finally, it is asked to display information about the simplicial complex.
import gudhi
rips_complex = gudhi.RipsComplex(points=[[1, 1], [7, 0], [4, 6], [9, 6], [0, 14], [2, 19], [9, 17]],
max_edge_length=12.0)
simplex_tree = rips_complex.create_simplex_tree(max_dimension=1)
result_str = 'Rips complex is of dimension ' + repr(simplex_tree.dimension()) + ' - ' + \
repr(simplex_tree.num_simplices()) + ' simplices - ' + \
repr(simplex_tree.num_vertices()) + ' vertices.'
print(result_str)
fmt = '%s -> %.2f'
for filtered_value in simplex_tree.get_filtration():
print(fmt % tuple(filtered_value))
When launching (Rips maximal distance between 2 points is 12.0, is expanded until dimension 1 - one skeleton graph in other words), the output is:
Rips complex is of dimension 1 - 18 simplices - 7 vertices.
[0] -> 0.00
[1] -> 0.00
[2] -> 0.00
[3] -> 0.00
[4] -> 0.00
[5] -> 0.00
[6] -> 0.00
[2, 3] -> 5.00
[4, 5] -> 5.39
[0, 2] -> 5.83
[0, 1] -> 6.08
[1, 3] -> 6.32
[1, 2] -> 6.71
[5, 6] -> 7.28
[2, 4] -> 8.94
[0, 3] -> 9.43
[4, 6] -> 9.49
[3, 6] -> 11.00
Example from OFF file¶
This example builds the Rips_complex from the given points in an OFF file, and max_edge_length value. Then it creates a Simplex_tree with it.
Finally, it is asked to display information about the Rips complex.
import gudhi
rips_complex = gudhi.RipsComplex(off_file='alphacomplexdoc.off', max_edge_length=12.0)
print(result_str)
fmt = '%s -> %.2f'
the program output is:
[0] -> 0.00
[1] -> 0.00
[2] -> 0.00
[3] -> 0.00
[4] -> 0.00
[5] -> 0.00
[6] -> 0.00
[2, 3] -> 5.00
[4, 5] -> 5.39
[0, 2] -> 5.83
[0, 1] -> 6.08
[1, 3] -> 6.32
[1, 2] -> 6.71
[5, 6] -> 7.28
[2, 4] -> 8.94
[0, 3] -> 9.43
[4, 6] -> 9.49
[3, 6] -> 11.00
Distance matrix¶
Example from a distance matrix¶
This example builds the one skeleton graph from the given distance matrix, and max_edge_length value. Then it creates a Simplex_tree with it.
import gudhi
rips_complex = gudhi.RipsComplex(distance_matrix=[[],
[6.0827625303],
[5.8309518948, 6.7082039325],
[9.4339811321, 6.3245553203, 5],
[13.0384048104, 15.6524758425, 8.94427191, 12.0415945788],
[18.0277563773, 19.6468827044, 13.152946438, 14.7648230602, 5.3851648071],
[17.88854382, 17.1172427686, 12.0830459736, 11, 9.4868329805, 7.2801098893]],
print(result_str)
fmt = '%s -> %.2f'
[0] -> 0.00
[1] -> 0.00
[2] -> 0.00
[3] -> 0.00
[4] -> 0.00
[5] -> 0.00
[6] -> 0.00
[2, 3] -> 5.00
[4, 5] -> 5.39
[0, 2] -> 5.83
[0, 1] -> 6.08
[1, 3] -> 6.32
[1, 2] -> 6.71
[5, 6] -> 7.28
[2, 4] -> 8.94
[0, 3] -> 9.43
[4, 6] -> 9.49
[3, 6] -> 11.00
Example from csv file¶
import gudhi
rips_complex = gudhi.RipsComplex(csv_file='full_square_distance_matrix.csv', max_edge_length=12.0)
print(result_str)
fmt = '%s -> %.2f'
[0] -> 0.00
[1] -> 0.00
[2] -> 0.00
[3] -> 0.00
[4] -> 0.00
[5] -> 0.00
[6] -> 0.00
[2, 3] -> 5.00
[4, 5] -> 5.39
[0, 2] -> 5.83
[0, 1] -> 6.08
[1, 3] -> 6.32
[1, 2] -> 6.71
[5, 6] -> 7.28
[2, 4] -> 8.94
[0, 3] -> 9.43
[4, 6] -> 9.49
[3, 6] -> 11.00
